Old 02-04-2002, 10:04 AM   #1
BuickturboV6
Member#: 12080
07 STi Ltd
Satin
Default Cheating ODB-II ??
Does anyone make a O2 "simulator" for our cars?
I'm not sure exactly how they work, if they use heat to create resistance or by some other means. Is there a way to send a false signal to the OBD computer so when I gut the last cat, I don't run around with a CEL. A friends WRX runs around with a CEL and he actually has a high flow cat.... What are my options, if any?
BuickturboV6
BuickturboV6 is offline   Reply With Quote
Old 02-04-2002, 03:20 PM   #2
BuickturboV6
Member#: 12080
07 STi Ltd
Satin
TTT
Old 02-04-2002, 06:12 PM   #3
jclick
Member#: 4525
2002 WRX Wagon
You'd think one of the Unichip vendors could send a signal to the ECU, so it would never give the low cat efficiency alert.
jclick is offline   Reply With Quote
Old 02-04-2002, 08:24 PM   #4
WRX'r
Member#: 13231
2001 Cobra
used to have 2002 WRX
Just FYI I gutted my last cat and have no cels yet.
WRX'r is offline   Reply With Quote
Old 02-04-2002, 08:50 PM   #5
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Look at my response over here -- http://www.i-club.com/forums/showthr...7&pagenumber=2
It's being worked on...
Old 02-05-2002, 12:01 AM   #6
Jung918
Member#: 10969
How did you gut your down-pipe? Did you cut it open, drill it out and then weld it back on?
Jung918 is offline   Reply With Quote
anyone with an odb-II scanner in clearwater area sylvar South East Region Forum 1 11-15-2002 03:30 PM
Where to buy ODB-II software? SubaruLover Mid Atlantic Impreza Club -- MAIC 5 08-15-2002 07:01 PM
Best ODB-II software? Poppa smurf Normally Aspirated Powertrain 2 07-19-2002 09:47 AM
ODB-II software setup SubaruStu Normally Aspirated Powertrain 0 02-25-2002 03:50 PM
Codes for ODB-II scanner output minx General Community 5 01-09-2002 10:23 AM
