North West Impreza Club
Go Back   NASIOC > NASIOC Chapters > North West Impreza Club Forum -- NWIC
Old 01-25-2008, 03:51 AM   #1
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
Default It's out! My DIY swap thread...
Well, quite a few of you already know, but I am in the midst of doing a good ol' EJ257 shortblock swap into my WRX. I decided to make a thread here locally to give thanks to a few different people who have helped along the way and get feedback from the locals...comments and flames welcome and appreciated! I'll continue to edit and add as I remember crap.
This project started back in Mayish 2007 when I acquired a "blown up" EJ257 shortblock from a good friend for a good price. It had two broken pistons (teh notorious ringlang failures) and one pretty ugly cylinder wall as a result. I foresaw that my car would be close to 80k miles within a year and figured I might as well rebuild my purchase into a usable shortblock and do all of the other maintenances and mods my car would soon need anyways -- timing belt, clutch, TGV deletes, injectors, etc. -- all at once. My goal was to increase the OEM SB's strength and reliability without spending significant amounts of money on forged internals because well...I'm poor I was then introduced to an engine builder who was able to use my block as a core and trade me a usable block to mate up with my usable rotating assembly (sans pistons). Through some very good friends and connections, I was able to acquire new OEM STi pistons, rings, wristpins and cams for an outrageous deal, and the build was on. I got the engine back and finally got all of my parts together and began tearing my car apart about a week ago. The frigid weather has kept my work to 2 hours spurts.
Enough babbling, onto teh build--
Current Setup:
OEM EJ205
VF39/565s/Meth/FMIC/3" TBE/APS Inlet/blah blah
Susp/Brakes/Interior/blah blah
New Setup:
EJ257 SB
OEM Crank
OEM Rods, Shotpeened
OEM Pistons, Coated
ACL Street Main & Rod Bearings
JDM 12mm Oil Pump
EJ205 Heads
USDM STi Cams
Brian Crower Springs & Retainers
Light Cleanup of Bowls/CC
Coated CCs/Valves
OEM STi Headgaskets
18G-TD05H 8cm^2 Turbo by TEC
STi Oilpan, Pickup, Baffle & Dipstick
Perrin Topfeed Fuel Rails
Modded & Flowtested WRX Injectors
STi Group N Motor Mounts and Pitch Stop
PE Kevlar Timing Belt
New OEM WRX Water Pump, T-Stat, Clutch
NGK BKR7E Spark Plugs
Day 1 - The beginning:
Day 2
Day 3 -- Another reason for my swap For the last 15k miles or so, the passenger side head has been pushing some oil from somewhere. The headgasket is intact, so could be the valve cover. I hope to find out on teardown:
Today -- Removal!
Tada! Mr. BREWPUBEAVER came by today to help me with the final removal. I will say that this job has been done 100% with hand tools (although a complete assortment) in a garage, so if you are thinking of undertaking a similar job yourself, it can be done! Research and patience are your friends.
Next all exhaust hardware goes off to the coaters and the engine goes for final assembly. I'll be reusing lots of the current parts on the 2L, such as cam gears and such.
BIG THANKS GO TO, in no particular order:
Dave Oathes
Chris Henry
Sean McCormick (RIP Dr. Injector)
Kendrick Gray
Geoff Johnson
Audio Integrations (www.audiointegrations.net)
Peter Ryakhovskiy
Mike Gent
Dale Daugherty (NW Subaru Service Group)
Brian Schutzler (Bearing Service Company)
Pam Johnson (Tufcoat)
Mike Talbot (Pacific Import Auto)
Scott and Ben (Carr Subaru Parts Dept.)
My parents for usage of garage
Lots of other people
Reinstall, coming soon...
lancelucas is offline   Reply With Quote
Old 01-25-2008, 03:54 AM   #2
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
Sidethoughts:
TGV deletes are not hard, just time consuming. I was able to use a saw to remove the dividers and various bits in an electric die grinder. I took the chance to do mine during the engine removal process-
I used a 10mmx1.5 tap and some set screws and JB weld to plug the ends.
I don't know what I was expecting, but I thought the Group N pitchstop would look "different" for some reason. I know the rubber is much harder, but visually they are identical:
Old 01-25-2008, 03:59 AM   #3
David Glasscock
Member#: 25033
06 sti my $$ pit
05 xt my DD
sweet, glad to see everythings going good for ya. cant wait for you to get her back on hte road. going to be a beast..
David Glasscock is offline   Reply With Quote
Old 01-25-2008, 04:11 AM   #4
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
CGM
Sweet, BTW gaskets are on the way. Cant wait to see her purrr. BTW hows the block running for you Dave?
Sinister redlines is offline   Reply With Quote
Old 01-25-2008, 04:13 AM   #5
kirkeemonster
Member#: 113721
WRBP
Hmm.... iiiiinnnttteeerrreeesting.........
kirkeemonster is offline   Reply With Quote
Old 01-25-2008, 04:17 AM   #6
David Glasscock
Member#: 25033
06 sti my $$ pit
05 xt my DD
great, love how she sounds. not sure if it the pistons or cam that gives the tinging sound. kinda reminds me of a muscle car sound. you can really tell the difference when its next to another subie. i know its not the exhaust thats making that sound.. just need to get a bigger intercooler on her so i can get som decent power..
Old 01-25-2008, 04:21 AM   #7
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
CGM
Some sound is from those forged slugs runnin.
Old 01-25-2008, 04:22 AM   #8
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
CGM
Tommorow I will post some pics of my darton sleeved stroker engine that should be runnin VERY soon Sexy, sexy time!!!!!
Old 01-25-2008, 01:48 PM   #9
geoffj
Member#: 9
Niiiiiice. I'm excited to see how much faster your car is with the 2.5, although I don't think you ever went WOT with me in the car.
geoffj is offline   Reply With Quote
Old 01-25-2008, 01:51 PM   #10
nikswrx
Member#: 27493
03 AW WRX wagon
girl powered stg 2 :)
Sweeet, any ETA on when it will be done?
nikswrx is offline   Reply With Quote
Old 01-25-2008, 02:00 PM   #11
Dyno Authority
Member#: 144480
OBP 05' STi, 02 WRX
01 RS-EJ205, EG33 GM6
Looks good!
*grabs popcorn & waits for the results*
Dyno Authority is offline   Reply With Quote
Old 01-25-2008, 03:09 PM   #12
gregor2001
Member#: 84443
2012 STI Ltd WRB Sdn
2009 OBS Silver WifeWagon
Thanks for posting - can't wait to see the next updates.
Good luck the rest of the way!
gregor2001 is offline   Reply With Quote
Old 01-27-2008, 01:01 AM   #13
twigg107
Member#: 119718
2008 STI
Dont you love it when you have everything planned out ant then the cold weather comes..... I know I dont! lol
Good luck with the build man..... cant wait to see it on the read again.
twigg107 is offline   Reply With Quote
Old 01-27-2008, 02:02 AM   #14
SedonaScooby
Member#: 143522
1987 Brat GL 4 Speed
98 Forester L (RIP)
you've helped me a ton in the past so if you ever need someone to get in the way i'm more then willing to help.
SedonaScooby is offline   Reply With Quote
Old 01-27-2008, 01:12 PM   #15
02WRX2.5
Member#: 63192
02 wrx
161mph Trapspeeds
Tranny time. Might as well replace while you have everything out, or else it will be the next thing in the back of your mind while boosting. "Is it going to hold"
Good luck and good job on the build. Nice parents you have to let you clog up there garage like that. No personal garage sucks.
02WRX2.5 is offline   Reply With Quote
Old 01-27-2008, 01:52 PM   #16
olskool_al
Member#: 153380
07 Impreza WRX TR
OBP FTW
I have be wondering how serious it was to get the motor out. I see a lot of people mod all types of stuff. But when it comes to pulling the engine, " lets just take that somewhere". Good luck, can't wait to see it done.
olskool_al is offline   Reply With Quote
Old 01-27-2008, 02:19 PM   #17
slvr02scooby
Member#: 86628
2002 WRX EJ257
COBB Tuning Surgeline
Nice work Lance, good luck with the rest of the swap!
And I do worry about my tranny every time I get on it since my swap Get something stronger asap!
slvr02scooby is offline   Reply With Quote
Old 01-27-2008, 04:08 PM   #18
spoolindc2
Member#: 72972
2003 WRX Stage 2 HKS
looks like fun man good luck with the build!!!
spoolindc2 is offline   Reply With Quote
Old 01-27-2008, 04:16 PM   #19
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
Thanks for all of the kind words, I really appreciate it! Can't wait to see everyone this summer and check out everyone's winter projects
We can fix that
Engine parts will head to the assembler within the next few days. The assembly is technically a "day job" but will probably take 2 or 3 total. Hopefully have the car back on the road within 14 days from now (ya right)
I would like to upgrade now but I can't afford it, so I'll continue saving in the tranny fund and hopefully have enough if I ever do break the 5spd
+1 to the parents thing, they are very supportive of me and I would be paying $1000+ to have this done at a shop if it wasn't for them.
Old 01-27-2008, 05:00 PM   #20
Audio Integrations
Member#: 110224
2005 WRX Sedan
PDX Tuned 295 hp 265 tq
Damn all you and your 2.5 swaps! Is there any 2.0's running around still besides me? Looks good though - can't wait to see it on the road again and feel the difference!
Audio Integrations is offline   Reply With Quote
Old 01-27-2008, 05:00 PM   #21
BREWPUBEAVER
Member#: 84547
06, Lafawnduh
Fender rolling king
Looking good Lance.
cant wait to get it running again. Was the heat treating place FinishLine?
BREWPUBEAVER is offline   Reply With Quote
Old 01-27-2008, 09:02 PM   #22
Gray Ghost
Member#: 162790
Still sporting the 2.0 as well. Those guys do make me jealous though I was fine until I drove an STi. Hmmmmm...............Torque!
Gray Ghost is offline   Reply With Quote
Old 01-28-2008, 11:22 PM   #23
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
Yeah the torque of the 2.5L was just too much to pass up
I dropped off my exhaust manifolds, x-pipe, uppipe, downpipe and turbo heatshield for coatings today. I chose black after seeing some pics of the black coating, it really looks sharp. The manifolds are a set of GrimmSpeed P&P's that I installed about 8 months ago -- after being used, you can really see how rough the OEM castings are in the areas you can't reach with a die grinder. I am hoping the media blasting during the prep process for coating helps clean them up even more.
I also ordered up a set of OBX Fuel Rails I normally don't touch the generic parts, but I just need a basic set of aftermarket rails to get rid of the complicated OEM setup while it is already all apart. They are a knockoff of a Perrin design and have gotten some good reviews. I wish I could have sprung for real Perrin or TurboXS, but I couldn't justify the extra cost. Next time around I'll go for Aeromotive rails & FPR with all AN lines/fittings
Old 02-08-2008, 02:03 AM   #24
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
Exhaust parts are back from the coaters
Grimmspeed P&P Manifolds
TurboXS Catless UP
Titek Catless DP
Cusco Turbo Heat Shield
Old 02-08-2008, 03:07 AM   #25
olskool_al
Member#: 153380
07 Impreza WRX TR
OBP FTW
Lookin' good. So think it's gonna be a go for next weekend?? Or will we see you as a ride along??
My DIY endlink thread Bad Noodle Custom Fabrication, Welding & Tools 24 04-16-2010 02:59 PM
Nexus One:We know it's out. Find a new thread. skywaffles Off-Topic 666 01-07-2010 01:25 PM
The parting out my car feeler thread vision.dynamix NESIC Private Classifieds 51 04-25-2009 06:00 AM
My RS swap thread nme187 Rocky Mountains Impreza Club Forum -- RMIC 18 02-06-2007 11:09 AM
my ej257 swap thread with holset dukeduster Built Motor Discussion 204 12-09-2006 02:28 PM
