Old 01-25-2008, 02:49 PM   #1
SNYDER'S-SCOOBY
Member#: 157543
1996 Brighton AWD
Coupe
Default 96 brighton: clutch grabbing very high, but only 15k on it??
I just bought this car the other day knowing that the clutch was grabbing high and I figured that it was probably the original clutch and just needed to be replaced (car is at 92k). HOWEVER, I just found service records that show the clutch was replaced @78k along with the timing belt. There's no way someone put this much wear on this clutch in 14k so I'm wondering is there some sort of ajustment for the clutch in these cars? or maybe something else that could cause the clutch to grab at the very top? the pedal feels normal and theres no slipping.
:edit:should have put this in the Transmission section. my mistake.
SNYDER'S-SCOOBY is offline   Reply With Quote
Old 01-25-2008, 03:56 PM   #2
Storm
Member#: 5218
96L Most Over-
Developed Beater
It's cable actuated.....and it needs adjusted.
Jay Storm
Old 01-25-2008, 05:57 PM   #3
SNYDER'S-SCOOBY
Member#: 157543
1996 Brighton AWD
Coupe
Jay Storm
where is the adjustment? I know of the one above the pedal, but i thought that only changed pedal hight not where in the swing of the pedal it engages (i.e. i can make the pedal stop 2 inches closer to the floor, but clutch will still engage in the last inch of pedal travel)
am i wrong? or is there another way nto adjust it?
Old 01-25-2008, 06:27 PM   #4
novacivic
Member#: 117980
2005 sti
wr blue
if you look on top of the trans/engine near the firewall on drivers side you will see the clutch fork with the cable attached. loosen the lock nut then adjust the cable until it feels better then re tighten the lock nut against the adjusting nut and enjoy the improved clutch travel
novacivic is offline   Reply With Quote
Old 01-26-2008, 12:28 PM   #5
SNYDER'S-SCOOBY
Member#: 157543
1996 Brighton AWD
Coupe
thnx novacivic. clutch feels like it should now.
Old 01-26-2008, 07:58 PM   #6
Subyroo2.5
Member#: 168129
2013 WRX
WRBP
Make sure to check the specs...freeplay is important.
Subyroo2.5 is offline   Reply With Quote
Old 01-27-2008, 12:00 PM   #7
Storm
Member#: 5218
96L Most Over-
Developed Beater
^^^ Yup...the adjustment under the dash is for the pedal freeheight. The engagement point is adjusted on top of the transmission with the 2 nuts.
Glad you got it working good.
Jay Storm
Clutch Pedal Becomes "Loose", but Only After Spirited Driving - Ideas? brianbot5000 Transmission (AT/MT) & Driveline 3 03-19-2010 06:02 PM
FS: Catted up pipe and heatshield, 15k on it, great shape ejoy1220 NESIC Private Classifieds 6 01-13-2010 03:00 PM
Clutch issue - Very high grab point Akshunhiro Transmission (AT/MT) & Driveline 14 08-19-2009 10:21 PM
Hey real quick im looking to get a wrx very soon but cant decide on 05 or 06... TurboLover25 Newbies & FAQs 54 05-16-2008 02:34 PM
LOL I just got a gift but wrong name on it.. Sephro Off-Topic 5 12-18-2003 02:48 PM
