Welcome to the North American Subaru Impreza Owners Club Tuesday August 23, 2016
Old 01-25-2008, 10:00 PM   #1
alejo
Member#: 170081
2004 2.5RS
blue
Default ej25 intake on an ej22
Well, the question is clear I guess. Does it fit? any gains? or is there anything from a 2002 ej25 that would fit on a 1999 ej22 without doing a complete swap?thanx a lot
alejo is offline   Reply With Quote
Old 01-25-2008, 11:52 PM   #2
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
I dont think so. The ports on the EJ25 are larger, and IIRC spaced differently.
~Josh~
Old 01-26-2008, 03:26 PM   #3
Storm
Member#: 5218
96L Most Over-
Developed Beater
Close, but not quite. If the EJ22 is the earlier type, the EJ25 wont fit. Since it's a 99, it should be doable.
Jay Storm
Old 01-26-2008, 10:26 PM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Intake manifold, or intake?
Old 01-26-2008, 10:30 PM   #5
ballitch
Member#: 74907
98 cam'd EJ251
I thought the EJ22 didnt go phase 2 heads until 2000-2001, when the heads closely ressemble sohc EJ25 heads.
I have both at my dad's house, maybe I should compare.
~Josh~
Old 01-27-2008, 12:16 AM   #6
GrundleJuice
Member#: 165749
Yeah! +1
Old 01-27-2008, 09:03 PM   #7
alejo
Member#: 170081
2004 2.5RS
blue
sorry, my bad... Intake manifold. thought I said i but I didn't
Old 01-28-2008, 02:05 AM   #8
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
I think based on what I've read in the past that they EJ22 and EJ25 intake manifolds are not compatible. Check here. Granted, that's just one thread, so there could be some bad info there.
Old 01-28-2008, 10:32 AM   #9
alejo
Member#: 170081
2004 2.5RS
blue
ok, but will there be any gains? is there any other part (except from the block which is dead) that may give me any gains? thanx a lot
Old 01-28-2008, 05:06 PM   #10
Storm
Member#: 5218
96L Most Over-
Developed Beater
I've got an 01 EJ22 manifold and a 99 EJ25 manifold in the garage at the moment. They appear to be identical. That would make me think that there wouldn't be any gain in swapping.
You can study the FSM specs on the cams to see if the EJ25 cams will drop in to your heads (I'd like to try this myself) and see what happens. Other than that, slip a phase II EJ25 block under those EJ22 heads and have alot of fun cheaply!
Jay Storm
boosting on an ej22 shortblock not a ej22t sime Normally Aspirated with bolt-on Forced Induction Powertrain 10 09-11-2014 06:05 PM
Turbo on an ej22 question pilfflip Normally Aspirated with bolt-on Forced Induction Powertrain 6 04-16-2013 04:27 AM
I'm back! And I need help on an EJ22 swap cbickell Subaru Conversions 0 05-30-2008 11:30 PM
When doing a timing belt change on an EJ22... SubarNoober Normally Aspirated Powertrain 7 02-21-2008 01:44 PM
Injectors on an ej22? cueball89 Normally Aspirated Powertrain 4 08-19-2005 09:54 AM
