Old 01-26-2008, 10:46 AM   #1
NJ2.5RS
Member#: 110353
2006 WRX
black
Default Low rpm knock?
I've been getting a bit of knock at low rpm during my pulls in 3rd gear. And when i was cruising on the highway in 5th it seems when i Step on the gas to change lanes or something or to go up a large hill i get knock between 2200 and 3800rpm. I'm starting to think that its due to a sudden rich cycle with the onset of boost?
Code:
Time AFRsen#1 Load g/rev)(rpm) FBKC  IAM    Base Timing  IAT    KC ManiRelCorPSI  MAF  PWDC Target Boost Throttle  mph IgniTimeAdv IDC	Intake VVT Advance Angle Left (degrees)
0	14.7	0.61	1995	0	1	42.21	28	2	-6.82	20.19	0	-2.81	11.37	28	2	6.4	21
397	13.9	1.49	2065	0	1	10.92	28	6	0.73	51.22	10.98	5.16	47.06	29	5.98	14.43	20
785	11.37	1.73	2128	-1.4	1	6.34	28	4.5	3.77	61.93	49.41	11.28	94.12	29	5.98	19.6	19
1187	11.37	2.04	2291	-1.4	1	5.59	28	4.5	6.96	78.79	49.41	12.39	100	29	5.98	25.17	19
1580	11.14	2.34	2443	-1.4	1	4.32	28	5	10.74	95.74	48.63	13.06	100	30	5.98	32.04	19
1964	11.14	2.65	2636	-1.05	1	3.9	28	5	14.22	118.89	40.39	13.33	100	32	5.98	41.37	19
2353	11.14	2.61	2864	-1.05	1	4.56	28	5	15.09	127.48	30.98	13.6	100	35	5.98	43.39	20
2753	11.14	2.55	3073	-0.7	1	5.27	28	5.5	13.2	131.4	29.8	13.86	100	38	5.98	47.11	20
3147	11.14	2.53	3283	-0.7	1	5.8	28	5.5	12.91	142.34	30.2	13.82	100	42	5.98	52.14	21
3532	11.14	2.64	3522	-0.7	1	6.24	28	5.5	12.33	156.83	29.02	13.03	100	42	5.98	56.83	20
3919	11.14	2.65	3712	-0.35	1	6.47	28	5.5	12.33	163.88	29.02	12.74	100	45	5.98	60.86	20
4300	11.14	2.65	3935	-0.35	1	6.67	28	5.5	12.19	173.22	29.41	12.57	100	50	5.98	64.03	17
4687	11.14	2.63	4114	0	1	7.1	28	6	12.19	183.55	30.2	12.38	100	53	5.98	67.5	15
5070	11.14	2.63	4342	0	1	7.65	28	6	12.19	192.59	30.98	12.22	100	57	5.98	70.47	13
5469	11.14	2.61	4506	0	1	8.36	28	6	12.19	198.35	31.76	12.04	100	57	5.98	72.72	12
5867	11.14	2.57	4716	0	1	9.41	28	6	11.75	206.95	32.55	11.9	100	60	5.98	75.92	10
6251	11.14	2.62	4917	0	1	9.88	28	6	11.75	213.63	33.33	11.74	100	63	5.98	77.94	9
6639	11.14	2.63	5093	0	1	9.88	28	6	11.75	222.09	33.33	11.59	100	67	5.98	81.37	7
7023	11.14	2.56	5254	0	1	10.13	28	6	11.32	225.83	36.47	11.39	100	70	5.98	81.04	6
7420	11.14	2.51	5435	0	1	10.46	28	6	11.03	228.72	40.78	11.25	100	73	5.98	82.84	5
7804	11.14	2.49	5590	0	1	11.13	28	6	10.74	229.68	44.71	11.13	100	73	5.98	82.56	3
8192	11.14	2.46	5732	0	1	11.72	28	6	10.74	231.6	40.78	10.74	100	76	5.98	83.88	2
8591	11.14	2.36	5869	0	1	12.4	27	6	10.3	231.12	34.9	10.26	100	80	5.98	83.89	1
8984	11.14	2.31	6062	0	1	12.95	27	6	10.01	231.6	29.8	9.89	100	82	5.98	84.41	0
9368	11.14	2.26	6164	0	1	13.32	27	6	9.72	233.05	23.92	9.62	100	85	5.98	84.32	0
9758	11.14	2.22	6294	0	1	13.69	28	6	9.58	232.57	19.61	9.42	100	86	5.98	84.62	0
10156	11.48	0.21	6309	0	1	23.95	28	0	-9	21.36	0	-10.76	12.16	86	0	4.01	0
10552	14.93	0.24	5550	0	1	24.53	28	0	-11.17	21.82	0	-10.59	11.37	89	0	8.06	0
10942	16.65	2.33	4538	0	1	13.07	28	6	6.53	170.57	34.51	12.06	100	90	5.98	66.65	1
11340	12.17	2.73	4628	0	1	8.98	28	6	13.2	209.18	27.45	11.95	100	91	5.98	79.34	8
11719	11.14	2.47	4711	0	1	9.59	28	6	11.17	196.71	15.69	9.57	81.96	92	5.98	72.12	9
12108	11.14	2.4	4822	0	1	10.69	28	6	9.72	193	30.98	11.8	100	94	5.98	71.15	8
12485	11.14	0.74	4836	0	1	16.9	28	6	-1.02	78.78	0	-9.97	22.75	94	5.98	21.53	8
12872	11.94	0.24	4852	0	1	23.95	28	0	-11.46	18.85	0	-9.92	10.98	96	0	3.07	0
NJ2.5RS is offline   Reply With Quote
Old 01-27-2008, 02:03 AM   #2
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Hey, fix your column names so we have a prayer of reading your log!
Old 01-27-2008, 02:14 AM   #3
mickeyd2005
Member#: 122595
2005 LGT Wagon
ABP
I think it's more likely a lean spike due to throttle tip-in.
Get a WBO2 and log using the dedicated logger so that you can get a very high sampling rate.
mickeyd2005 is offline   Reply With Quote
Old 01-27-2008, 02:21 AM   #4
mickeyd2005
Member#: 122595
2005 LGT Wagon
ABP
Here's an example. It's a FMIC equipped stage 2 LGT. This car has a very tiny turbo, VF40, so boost comes on very fast.
The injectors are stock with stock tip-in values and this is what we saw when the throttle was opened suddenly. We would also get occasional knock when the throttle was opened suddenly.
We corrected this by doubling the slope of the tip-in table. This also corrected the knock at initial throttle input.
Old 01-27-2008, 10:05 AM   #5
NJ2.5RS
Member#: 110353
2006 WRX
black
ok that makes alot more sence. Well i flashed back over to the stock map till my wideband and downpipe get here. I'll start reading up on the Throttle tip in some more. Thanks
Getting engine knock @ low RPMs & also running lean after Stg2 Map zigforjustice Open Source Reflashes 3 01-09-2010 07:55 AM
Faint tick/knock at low RPMS FCPremixx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 09-14-2009 04:49 PM
Low rpm knock! 5th gear pull imprezilization Open Source Reflashes 1 03-28-2008 11:24 AM
Low RPM/low boost knocking? Fred Fredburger UTEC 8 11-22-2007 11:59 AM
Knock at low rpm and throttle PharmCo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 02-02-2004 11:28 PM
