Welcome to the North American Subaru Impreza Owners Club Saturday July 4, 2015
Old 01-26-2008, 11:58 AM   #1
SPOOLME
Member#: 91210
2004 WRx
Default Idling problems and wierd Cel problem.. Help please
Ok.. so i've been having these wierd idling problems for quite a while now. Im thinking the iacv is messed up, I tried cleaning it a bunch of times, it worked but would **** up again.. So im guessing I need to buy a new one.
But my question is, after the car runs for like 10-15 miles on this messed up idle( like around 1.8k) The check engine like comes on.. But everytime I try to pull the code, my accessport reads no cel's were found? wtf? every single time.. I cant get the code but the check engine light always comes back on?
SPOOLME is offline   Reply With Quote
Old 01-26-2008, 12:36 PM   #2
Arctic Penguin
Member#: 119532
2006 WRX
your ap isnt a code reader
Arctic Penguin is offline   Reply With Quote
Old 01-26-2008, 01:15 PM   #3
SPOOLME
Member#: 91210
2004 WRx
Old 01-26-2008, 01:51 PM   #4
ddub22
Member#: 156727
The AP should be able to pull the code, I always use it to pull codes. I had a idle problem for a while with a cell, turned out to be my intake. I only started having the problem after i cleaned my MAF, which was weird. I had the short ram on for 50k+ without a problem, until i cleaned the MAF. Do you have a aftermarket intake? Try swapping back to the stock intake if you have an aftermarket. It worked for me.
ddub22 is offline   Reply With Quote
Old 01-26-2008, 02:07 PM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The AP can read some codes, but it is NOT an OBDII device so it does not accurately report all codes.
Get the car scanned with a proper OBDII scanner at Autozone, a local shop, dealer, or by another member in your area with the right equipment.
problems after downpipe install need help please The_Black_Pearl Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 09-12-2007 08:17 PM
problems with engine? fuel? something? help please. aznatama Engine Management & Tuning 1 06-04-2005 05:46 PM
Help! MAP problems. And a CEL. Daveish Normally Aspirated with bolt-on Forced Induction Powertrain 5 12-12-2004 04:17 PM
Problem after clearing MIL, little help please UTEC fatray Engine Management & Tuning 9 08-29-2003 03:12 AM
('93-'01) problem with a couple lights. Help please! gimpless Impreza Forum 2 04-10-2001 02:29 PM
