Old 01-26-2008, 12:35 PM   #1
drmx
Member#: 95773
15 GBP STI
90 300zx Twin Turbo
Default ring failure ?
Perhaps someone can confirm my theory. Car starts and runs fine, idles a bit high at first then smooths out. If I remove the oil cap when the engine is cold you can feel it pushing air out and it stalls after a few seconds. Once the engine warms up and cylinder tolerances are reduced - removing the oil cap doesn't cause a stall, but a lower/rougher idle and I can still feel it pushing air out.
I'm also having to add a 1/2 quart of oil every other week or so. I don't drive it much but always short distances so it rarely warms up fully. About every 5-10 starts it puffs a big smoke cloud like oil was sitting in the cylinder.
Does it make sense that the rings aren't sealing properly? I will be doing a compression test after work tonight and will edit with results.
drmx is offline   Reply With Quote
Old 01-26-2008, 01:40 PM   #2
flstffxe
Member#: 155358
2008 Forester
Steel Silver
rings, valve seals, potentially even a cracked but not yet broken piston. part of it could also be a plugged pcv. compression test as mentioned also a leak down test would be good to do.
flstffxe is offline   Reply With Quote
Old 01-28-2008, 06:33 PM   #3
drmx
Member#: 95773
15 GBP STI
90 300zx Twin Turbo
PCV valve seemed ok, rattled when I shook it, also swapped it out with another known good one and checked all its related hoses to the block for clogs...all clear.
Compression test results:
#1 - 220 #2 - 200
#3 - 210 #4 - 215
Cylinder 2 pushes a lot of air out of the plug hole when cranking and seems to make a loud whooshing noise with every pulse of air. None of the other cylinders seem to do this.
I'm pulling the intake manifold off now as I noticed there is oil leaking from the area of the cylinder 4 runner. The manifold was recently off to merge EGR wiring in after the swap to pass state emissions testing. I don't see how that would affect this problem but I can't say I recall this happening prior to that.
Old 01-28-2008, 11:02 PM   #4
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
98 OBS-T, 91 Legacy SS
Are we talking the EJ18 or EJ22 engine here?
If its the EJ22 I'd redo my compression test if I were you as over 200 psi is quite high. According to my local mechanic, 185 psi is what you should expect from an EJ22 and that's a 98 EJ22 with 9.7:1 CR vs yours which is said to have 9.5:1 CR. One key thing is to do the compression test on a warm engine and with all spark plugs removed and at least the coil disconnected.
Plus or minus 10% across all cylinders is healthy regardless of what you're getting for readings so long as they're not dreadfully low.
PhilSine is offline   Reply With Quote
2008+ STI Piston Ring Land Failure List Mach V Dan Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 508 01-31-2016 11:05 PM
Ring ring ring ring ring ring ring roffle Off-Topic 52 10-16-2008 11:05 PM
Ring Failure... what piston rings to get? exekious Built Motor Discussion 24 06-04-2007 01:05 PM
Ring ring ring ring ring....BANAPHONE! (part 2) GooseMan Off-Topic 4 07-13-2004 05:28 PM
Ring Ring Ring Ring Ring huckedup16 Off-Topic 18 06-14-2004 09:41 PM
