Closed Thread
Old 01-26-2008, 03:56 PM   #1
RoadTrippin
Member#: 161175
Exclamation Cooling issues?
Im not sure if these two things are related but my cooling system was fine up until yesterday when I put on a new alt. Today I lost a pretty hefty amount of coolant, it didnt overheat just I noticed coolant was puddling under the car. I cant tell for sure until I can pull out the rad but I think the bottom of the rad is cracked....could putting in a new alt cause this to happen? Also what is the best way to go about pulling the rad....obviously waiting till it cools down but will clamping off the hoses be ok?
Thanks
RoadTrippin is offline
Old 01-26-2008, 04:41 PM   #2
flstffxe
Member#: 155358
2008 Forester
Steel Silver
you may have leaned on the radiator when putting in the alternator. If the radiator was weak leaning on it may have been more then it could take, the straw that broke the camels back. Drain the coolant out, pulling the lower radiator hose is the easiest. Then pull the upper hose. Remove the two mounting points on the top and carefully guide it out when removing it.
flstffxe is offline
Old 01-26-2008, 05:34 PM   #3
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
please, no cross posting.
post 1 thread in the correct forum.
thank you.
Subie Gal is offline
Closed Thread
Cooling issues... chip4761 Normally Aspirated Powertrain 7 08-17-2007 08:05 PM
Turbocharger oil cooling...issues? WRX_UA Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 10-15-2006 02:08 PM
Cooling Issues with Seibon Carbon Fiber CW Style? HerculesPeanut Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 05-15-2005 11:19 AM
cooling issues, problems, eeek. ScreaminFast Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-01-2004 07:27 PM
cooling issues for the TURBO Scooby South Technical Forum Archive 5 05-16-2000 08:39 AM
