Old 01-26-2008, 04:51 PM   #1
subari87
Member#: 167422
1987 3 main
Question 98 forestor older engine swap
I just found a junked 98 forestor for 1 dollar, usual plague of overheating, no cures, needs engine. Body, as the usual story goes is great and inspectable. This is the only way I would be looking to have one sit around until work is done. This year I have learned is notorious for very bad engine, especially my car killing locale.
What N/A engine would be of choice? I have a good idea already, and it would be an older engine stepped up just so slightly to be close to the 165hp, but would like specific year opinion instead of generalization.Somebody must be dealing with this same problem year car that stays looking good and premature driveline demise somewhere...
Thanks for replies. I hope this thread does not disappear with suby negativity as the motivation. NASOIC can be real can it not?
subari87 is offline   Reply With Quote
Old 01-26-2008, 05:15 PM   #2
flstffxe
Member#: 155358
2008 Forester
Steel Silver
just about any subaru engine will fit. I would check the classifieds for some one who has swapped their 2.5L NA car to a turbo and is selling their old parts. complete engine, wiring harness and ecu. Guys who have done more swaps could chime in here and go into other options also, like a 2.5l shortblock with 2.0/2.2 heads and what ecus will run those set ups. The plague of over heating is more then likely head gaskets. it is fairly common.
flstffxe is offline   Reply With Quote
Old 01-26-2008, 10:25 PM   #3
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Sounds to me like someone is throwing away a perfectly good car that just needs to have the head gaskets done. "No cure" means that whoever is selling the car is clueless. The cure is new head gaskets and the engine will be good for as long as you own it.
But, if you insist on replacing the engine, then as flstffxe said, any EJ-series engine will fit.
Old 01-26-2008, 10:51 PM   #4
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
The Phase I EJ25 had overheating issues, but the new revised HG seems to have fixed that problem.
part # 11044AA610 is the new 4-layer MLS HG that subaru uses.
If you can fix the car for a couple hundred then you have a pretty cheap car.
~Josh~
Old 01-28-2008, 08:16 AM   #5
Calamity Jesus
Member#: 44501
1984 "Skeletor from
"He-Man"
Yeah.. bad for a Subaru.. which isn't bad at all. As was said.. look into replacing the head gaskets. You may need to get the heads shaved since it's been allowed to overheat.
If you're still leery of the engine after fixing it.. sell it for a massive profit. Even with a busted engine, that thing was worth two thousand (assuming the mileage is semi reasonable).
Old 02-10-2009, 01:05 AM   #6
gt35rRotatedSTI
Member#: 185233
2004 wrx sti
wrb
cant shave the heads on a subaru the intake want line up
gt35rRotatedSTI is offline   Reply With Quote
Old 02-10-2009, 01:32 AM   #7
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Shaving heads doesn't take that much material off. There are plenty of built motors running around with shaved heads.
Old 02-10-2009, 01:33 AM   #8
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Yes you can, done it many times
Old 02-10-2009, 03:59 AM   #9
98foz
Member#: 197293
just rebuilt my 2.5 out of my 98 forester, took a couple days but it went smooth and was about 350 to 400 bucks. kind of want to sell it now though. good luck with the motor!
98foz is offline   Reply With Quote
Old 02-10-2009, 06:57 AM   #10
Storm
Member#: 5218
96L Most Over-
Developed Beater
Where is this car? I need a better DD for my better half......
Jay
swap to older engine 98skuby Subaru Conversions 4 08-10-2009 07:56 PM
98 RS WRX engine swap - lagalities in VA WRXJIM Mid Atlantic Impreza Club -- MAIC 23 10-31-2007 04:16 PM
98 Outback Legacy Engine Swap question johnnnnny5 Subaru Conversions 2 09-13-2007 08:41 AM
98 RS-T Engine/Trans/Suspension Swap w/ 98 OBS RS25Tuner Subaru Conversions 4 10-04-2004 03:27 PM
engine swap worth the work? 2.5NA motor in older gc warpspeedwrx Subaru Conversions 6 08-29-2003 11:27 PM
Message Board Statistics All times are GMT -4. The time now is 05:36 AM.
