Old 01-27-2008, 08:02 PM   #1
maxbserr
Member#: 148417
WRB XPTStg2/GMBCS
Default Knocking
Being that I'm not fully aware of the number relation of FLKC, FBKC and their severity, I thought that I would make a post to get some input from this log where I cruised in 5th gear on my daily ride from work. Apparently there is some knock correction that has been going on while in the lower range of my map.
My question is how do the numbers relate to knock severity? I’ve attached a log where I’ve filtered out all of the non-knock events and there is also a log of the entire ride home.
My next question for those who are familiar with timing tuning is, when knock is present do you pull the total of the fine learning knock from the base timing or do you pull total of feedback knock out of base for that specific range?
http://www.box.net/shared/vjo6yrw8ww
Long Version
http://www.box.net/shared/07gkkb98g8
Short Version
maxbserr is offline   Reply With Quote
Old 01-28-2008, 09:00 AM   #2
MatchstiK
Member#: 162417
1994 WRX-RA
RED
I'm not anywhere near good at tuning, but I've been trying to read a lot of logs and interpret them better, so here's my shot.
The FLKC looks to be just pulling some timing here or there to maintain stoich, (at these throttle and load readings, it's still CL fueling no?), so I wasn't to worried about that. The FBKC seems to only occur going from a 0% throttle, to a ~15% throttle, so I would imagine it has an occasional knock right there. It hasn't affected your IAM, and it's only happening a very small percentage of time, so I'd say it's fairly normal.
Please wait for someone with experience to chime in though, I'm still very new to this.
MatchstiK is offline   Reply With Quote
Knock, knock, knocking.. 05 STi | UTEC Timmy Burns UTEC 15 02-24-2006 07:09 PM
Knock knock scoobydude1999 Service & Maintenance 9 01-09-2006 07:18 PM
*knock knock knock* at my front door.... eurojax Off-Topic 17 05-09-2005 09:03 AM
Knock knock... scoobydude1999 Service & Maintenance 0 06-26-2002 10:54 PM
