Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 01-27-2008, 11:10 PM   #1
Blu_Scobbie
Member#: 67849
2003 WRX Wagon
Default Tuning a Prodrive BCS
I recently got a Prodrive BCS from a friend of mine. I've been trying unsuccessfully to tuning it to get back to my stage 2 17psi. I've adjusted the wastegate duty cycle up past where my original map was but I'm still only hitting 13.58psi max. I read somewhere about adjusting turbo dynamics but I can't find it and dont know which map to modify. Can someone please help me. Thanks
Blu_Scobbie is offline   Reply With Quote
Old 01-28-2008, 12:41 AM   #2
Infamous1
Member#: 133692
2003 Chevy Z06
Black/Black
Your WGDC should be a good amount lower, did you remove the restricter pill? How do you have it connected?
Infamous1 is offline   Reply With Quote
Old 01-28-2008, 10:45 AM   #3
Blu_Scobbie
Member#: 67849
2003 WRX Wagon
I removed all the stock hoses so there is no pill. I connected all the hoses according to this http://www.tarmacwolf.org/dokuwiki/d...boost_solenoid
Old 01-28-2008, 10:56 AM   #4
Sausage
Member#: 104998
2007 vf39 SuperWagon
I haz teh bed gramers
I would like to do this as well... more info please
Sausage is offline   Reply With Quote
Old 01-28-2008, 12:45 PM   #5
Manbike26
Member#: 72122
2015 SUPER AWESOME
TEST VEHICLE
I still have a stock downpipe and target 16psi at sea level...but I live at 6000ft, so i really only see about 13-14 psi. I had 85-95 WGDC at 100% throttle with the stock BCS.
With a Prodrive BCS, my base WGDC at 100% throttle is around 55-60...so it's still pretty high. Interestingly enough, when I head back to sea level, I don't hit 16psi...I fall a short by 0.5-1.0 psi. This is with zero atmospheric compensation in the WGDC.
I have no idea if I'm completely unique or if this is consistent across a range of cars...but maybe my anecdotal experience can help.
-Mike
Manbike26 is offline   Reply With Quote
Old 01-28-2008, 12:50 PM   #6
Nuke209
Member#: 108089
2003 WRX
NF Performance
Stock map or tuned?
Nuke209 is offline   Reply With Quote
Old 01-28-2008, 01:26 PM   #7
mickeyd2005
Member#: 122595
2005 LGT Wagon
ABP
-Mike
I think this is very normal regardless of the BCS type.
I have noticed that at sealevel we need more WGDC to hit target boost because the target boost is higher.
Here's an example. Let's say we have a 10 psi actuator and the target boost is 13 psi at sealevel and 11 psi at high altitude. The WGDC necessary to hold boost at 14 psi would definitely be higher.
If the target boost is much greater than the actuator spring load then the difference in WGDC between high altitude and sea level appears to be less.
I have noticed this on stage 2 LGTs but unfortunately, some cars are tuned at high altitude and some cars are tuned at sealevel. I don't have logs of the same car at both altitudes. IMHO, the WGDC by atmospheric compensation should be used but I don't adjust it due to the lack of data.
mickeyd2005 is offline   Reply With Quote
Old 01-28-2008, 01:37 PM   #8
Manbike26
Member#: 72122
2015 SUPER AWESOME
TEST VEHICLE
Originally Posted by Nuke209 View Post
Stock map or tuned?
I have done some tinkering in Enginuity, so I suppose it would be considered a tuned map. Most of my efforts have been on the boost/wastegate/turbo dynamics maps.
Old 01-28-2008, 01:52 PM   #9
testes1010
Member#: 47145
2012 Gas Saver
Here's you a good starting point for the Prodrive BCS as far as TD goes.
TD Burst:
Code:
[Table2D]
-2.94	-1.70	-0.77	-0.31	0.00	0.31	0.77	1.70	2.94
-1.50	-0.49	-0.38	-0.19	0.00	0.75	1.00	2.00	3.00
TD Continuous:
Code:
[Table2D]
-3.00	-2.00	-1.09	-0.70	0.00	0.70	1.20	1.95	3.20
As far as WGD% 46.5% = 21.5psi on this particular car.
testes1010 is offline   Reply With Quote
Old 01-28-2008, 02:19 PM   #10
Tea cups
Member#: 103136
-Mike
There are several issues with tuning at altitude:
1. The standard ECU defs display target boost with the assumption of sea level. however, the ECU only deals in absolute pressures. So, 16 psig as viewed in Enginuity is really 30.7psi absolute (16 psig + 14.7 psi). If your local atmospheric pressure was 12 psi (and assuming no atmopsheric boost comp see #2), then your actual relative boost target would be 18.7 psig (30.7psia - 12 psi).
2. All ROMs progressively reduce target boost as atmospheric pressure drops to keep the turbo in its efficiency range. At my altitude (5000 feet), this is about -12% (I'm around 12 psi AP typically). However, this is applied to absolute pressure, not relative. So, in the same example, 30.7 psia target * .88 = 27.02 psia new target. This would be a target of 15 psig at the given altitude (27.02 psia - 12 psi). Yours might even lower because you are a 1000 feet higher than me.
Tea cups is offline   Reply With Quote
Old 01-29-2008, 11:08 AM   #11
Blu_Scobbie
Member#: 67849
2003 WRX Wagon
TD Burst:
Code:
[Table2D]
TD Continuous:
Code:
[Table2D]
Thanks, I'm going to give this a try and see what happens
FS in MI: Prodrive BCS and Forge BOV MrDrift Engine/Power/Exhaust 6 05-17-2007 12:00 PM
WTB: Prodrive BCS 06rexwagon Private 'Wanted' Classifieds 0 03-24-2007 04:53 PM
FS MI: Forge Atmospheric BOV and Prodrive BCS MrDrift Engine/Power/Exhaust 3 01-17-2007 09:20 PM
Prodrive BCS and tha pill (2.0 wrx) Imprezav Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 12-22-2006 12:12 PM
Appropriate vacuum line size for prodrive BCS? overdose Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 08-15-2006 04:27 PM
