Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC
Old 02-04-2002, 05:48 PM   #1
ImprezaKev
Member#: 11816
2001 2.5 RS Coupe
Default Anyone free this weekend (Spfld MA)
I need someone who knows a bit about exaust. Possibly meet up with me at some point in the near future. Just put on the full brullen setup and i think i have a leak. I know there is a reported ticking sound but only at higher rpm's, this is happening as soon as the engine bogs a little no matter what the rpm. Also im running rich i think? When i let off the gas and decel it sounds like a rattle at higher rpm's and as soon as i hit the gas its usually pops but not a backfire sound. This is what i think anyways so who knows cause im no expert. any help or advice would be great. I will try to post a sound clip today as well...
ImprezaKev
Would an AFC cure the "rich" problem if it does in fact exist
ImprezaKev is offline   Reply With Quote
Old 02-04-2002, 05:54 PM   #2
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
yes, AFC would fix that problem. But I would get an Air/fuel gauge and/or an EGT to make sure it is rich.
that burble sound when decelerating is normal, I have a cat-back system, and I get it, too...I love it as for the occasional "pop", I get that, too
to check for leaks is easy...look under the car as it's running (preferably when engine is cold, as exhaust is easier to see), and you will see if anything is coming out... (of course, there are better ways of checking for leaks, but that's how I do it )
JGard is offline   Reply With Quote
Old 02-04-2002, 06:26 PM   #3
paultg
Member#: 437
'91 Miata MX5 (Red)
'09 Impreza OBS (Blk/Gry)
Also,
Have someone plug the tailpipe with their shoe bottom or something like that while you look under the car for gas escaping. Don't plug it too long though.
Paul G.
paultg is offline   Reply With Quote
Old 02-04-2002, 06:36 PM   #4
ImprezaKev
Member#: 11816
2001 2.5 RS Coupe
anyone know were i can post a vid clip to put the link here? I tried yahoo briefcase but its down at the moment
Old 02-04-2002, 06:39 PM   #5
Ginseng
Member#: 3800
2002 WRB WRX Sedan
2011 Sky Blue Forester Pr
How long have you run this exhaust? Did you do an ECU reset? By "full" setup do you mean catback or from the header including a new cat? Another way to check for leaks when you start up is to get under the car and squirt some diluted dish detergent on the joints. I would do this before the exhaust piping gets hot enough to vaporize the liquid straight away. If you're blowing bubbles, you got a leak.
What makes you think you're running rich? Are you getting more of a fuel smell in the exhaust? Are you sooting up the tail pipe? The burble-pop is an added perk that comes with NA motors.
Good luck diagnosing. But I am not even sure you have a problem. In fact, it might even be that your new pipes are just clicking against a heat shield or some other underbody member. This is particularly likely if the piping is of uprated diameter or does not fit *perfectly*. In fact, it might even be possible that the setup is jostling around on the exhaust hangers when the motor torques a bit as when you quickly get on or off the go pedal.
Wilkey
Ginseng is offline   Reply With Quote
Old 02-04-2002, 06:40 PM   #6
RSmatt
Member#: 8039
94 v2 STi RA - RHD
I'll most likely be around this weekend, if you want to get together. I don't know what your schedule is like, but we could try and meet up on Sat. Let me know.
Later
Matt
RSmatt is offline   Reply With Quote
Old 02-04-2002, 06:47 PM   #7
ImprezaKev
Member#: 11816
2001 2.5 RS Coupe
Sounds good Matt PM me with your cell. Sat would be perfect. Thanks,
ImprezaKev
Old 02-05-2002, 05:56 PM   #8
Ru fan
Member#: 1605
1997 1.8L Brighton
NESIC TrackH0z member#1
Talking
Why not meet at the kart trak?
Later,
Seth E.
Ru fan is offline   Reply With Quote
Old 02-05-2002, 08:13 PM   #9
kyles70
Member#: 14508
What part of western mass are u guys going to meet up?? i am thinking about to get a cat back too do u guys mind if i check it out too??
kyles70 is offline   Reply With Quote
Old 02-05-2002, 11:44 PM   #10
RSmatt
Member#: 8039
94 v2 STi RA - RHD
Hey Seth, I'm going to try and come by kart trak around noon Sat. I'm not sure I will definitely be there as I haven't talked to Kevin about when we are going to meet up. Maybe he will want to do some karting.
Kyles70- Where do u live in western mass? I'm in Southwick and Kevins in Chicopee. I'm sure we will meet at either his place or mine. We can let you know what we are going to do.
Later
Matt
Old 02-06-2002, 12:38 AM   #11
lenyx
Member#: 8221
2011 Legacy 2.5i Ltd
<------- In Chicopee, have been under my car more times than I'd like to admit tinkering with my exhaust (scoobysport turbo back).
Just in case you guys needed a hand..
Oh, and if yer catless you're probably running rich.
lenyx is offline   Reply With Quote
Old 02-06-2002, 10:18 AM   #12
kyles70
Member#: 14508
i am in springfield so either place will be good for me just let me know the place and time
Old 02-06-2002, 12:25 PM   #13
Macka
Member#: 13830
On a cold day, start your car and look for leaks (your exhaust will be white)..I would not recommend plugging the tailpipe!
Found a leak in my friend's '79 corvette this way...it looked like he had side pipes, but nope, just a big leak.
Macka is offline   Reply With Quote
Old 02-06-2002, 05:22 PM   #14
ImprezaKev
Member#: 11816
2001 2.5 RS Coupe
thanks for the info guys. I would definitely be down for some karting. Lets just meet there if you guys want and we can go from there. Sat noon?
Ive never been so i need directions also.
MattI'll call you tommorow around lunch
Old 02-06-2002, 06:31 PM   #15
RSmatt
Member#: 8039
94 v2 STi RA - RHD
Saturday at noon sounds good to me. I'll meet you at the kart trak.
Later
Matt
Old 02-06-2002, 06:54 PM   #16
kyles70
Member#: 14508
yeah i am going to need directions too thanks
Old 02-07-2002, 12:16 AM   #17
lenyx
Member#: 8221
So kev.. was that you I passed on Memorial drive before both of us turned onto Britton in different directions?
Old 02-07-2002, 08:50 PM   #18
RSmatt
Member#: 8039
94 v2 STi RA - RHD
To get to kart trak, just take 91 south to exit 42. I believe the exit is for 159 Windsor Locks. When you get off the ramp, take a right. The trak is about 1/2 mile or so down the road on the left side.
Later
Matt
Old 02-07-2002, 09:43 PM   #19
Ru fan
Member#: 1605
1997 1.8L Brighton
So you guys are gona be there? If so, C ya there!
Later,
Seth E.
Old 02-08-2002, 07:24 AM   #20
ImprezaKev
Member#: 11816
2001 2.5 RS Coupe
More than likely it was me i think i remember that.
Install Day- Anyone free next weekend (4/8 or 9)? idkew Mid West Subaru Owners Club Forum -- MWSOC 66 06-03-2006 12:32 PM
Anyone near holmdel free this weekend to help get center diff in kx02wr Tri-State Area Forum 1 11-10-2005 11:59 AM
Anyone in Central Jersey free this weekend to help me get my center diff in kx02wr Tri-State Area Forum 6 11-04-2005 03:38 PM
Anyone free this weekend to help me throw on some springs? BrysImpreza New England Impreza Club Forum -- NESIC 3 06-05-2002 03:59 PM
Anyone, snow this weekend?(ie Tahoe) HomerJay Bay Area Impreza Club Forum -- BAIC 9 12-12-2000 05:58 PM
