Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 01-28-2008, 12:31 AM   #1
casionerd
Member#: 151929
0h! subigal
needs summer's eve
Default Not able to see boost PSI in live data mode
I hadn't updated my APV2 since June or July 2007. I recently did the latest firmware update and like everything but the live data. Where did the boost in psi go? Am I just not looking hard enough or in the right place or is this something Cobb did away with?
casionerd is offline   Reply With Quote
Old 01-28-2008, 08:40 AM   #2
newbluerex
Member#: 152073
07 WRX TR
look for relative pressure in the live data mode, should be there..
newbluerex is offline   Reply With Quote
Old 02-06-2008, 02:28 PM   #3
jobber
Member#: 164043
2015 WRX and FozzyXT
just a note that i tried this feature today, even though i've had my AP v2 a while. I am stage 2 Cobb 91 map with downpipe and upppipe. The max psi I could grab in 3rd gear was like 14.8-14.9PSI with WOT starting about 3000rpms. Should it be higher or is that pretty close to normal?
jobber is offline   Reply With Quote
Old 02-06-2008, 05:10 PM   #4
a6n6d6y
Member#: 123347
1993 POS
burgandy legacy
http://www.accessecu.com/accessport/...091%20v130.pdf
looks like your on target
a6n6d6y is offline   Reply With Quote
Old 02-06-2008, 05:13 PM   #5
jobber
Member#: 164043
Originally Posted by a6n6d6y View Post
sweet. I saw 16.1 psi ONCE when everything was just right. I came from 1.8T and 2.0T VW turbos where peaks of 19-22psi were common, so I guess I expected more.
Old 02-06-2008, 05:25 PM   #6
jobber
Member#: 164043
duplicate cause of this slow server.
Old 02-06-2008, 05:26 PM   #7
jobber
Member#: 164043
That link is for stage 1. I will find the stage 2 PDF and check also. Thanks for pointing me in the right direction.
Ya its close enough to what it should be:
"Boost Targets: ~16.5psi +/- 0.7psi peak boost pressure tapering down
to ~13psi, depending on vehicle and conditions.
Not able to hold boost at .1 ???Crap Therodstu Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 01-30-2010 10:49 AM
cruise not working, will I be able to see why with enginuity or ecuflash? shipjumper Open Source Reflashes 3 01-05-2008 06:35 PM
On AP2 in the live data mode what is...... subpreza AccessPort 22 07-23-2007 10:27 PM
any one here not able to see their feet?? joe z Off-Topic 21 09-29-2004 02:22 PM
Stage 2 user not able to hit target boost vitaminwrx Engine Management & Tuning 1 09-13-2004 03:17 PM
