Old 01-28-2008, 02:44 AM   #1
B03scooby
Member#: 102929
2003 07STi,03,07 STi
SWP/ WRB/UGM#239
Default Cusco rear sub-frame brace/diffuser w/after market sway bar
I curious to see if any one has used the cusco diffuser kit with an upgraded sway bar and if so are there any fitment issues. Their site says that it will not work with upgraded swaybars that do not utilize the stock mounts. I have a cusco swaybar so I am good on that end but I don't want to go to install the diffuser kit and find out that it won't work. Any insight would be appreciate I know that the diffuser can be mounted without the brace but I would like to avoid doing more than just bolt it ie drilling/welding on brackets
B03scooby is offline   Reply With Quote
Old 01-28-2008, 08:23 AM   #2
Knightmare69
Member#: 25039
2005 CGM Stage 2 WRX
SQC 275
I'm about to install mine next sat with a whiteline rsb, I was told that as long as you aren't running a huge rsb or one that requires upgraded mounts then you should be fine.
Knightmare69 is offline   Reply With Quote
Old 01-28-2008, 10:27 AM   #3
Steve Nastoff
Member#: 52052
03 Subaru WRX
Midnight Black Pearl
I'm running the diffuser kit and really like the whole package. Cusco is refering to after market sway bar mounts when they referance fitness issues. I run MRT sway bars and endlinks. I had Whiteline sway bar mounts initially but had to replace them in order to install the Cusco brace, diffuser mount. I went with 04 and up WRX factory mounts which are beefed up considerably as compared to the 02/03 mounts. Everything fit very well. I did have to trim the diffuser in order to clear my HKS Carbon Ti exhaust. No problem, barely noticable.
Steve Nastoff is offline   Reply With Quote
Old 01-28-2008, 11:27 AM   #4
Knightmare69
Member#: 25039
SQC 275
These are what Cusco is referring to
Old 01-28-2008, 12:07 PM   #5
axelthrasher
Member#: 144779
200X ZOMG a car 100%
crabon fibre girlfrendorz
Why won't it fit with the Perrin sway bar mounts?
axelthrasher is offline   Reply With Quote
Old 01-28-2008, 12:52 PM   #6
Knightmare69
Member#: 25039
SQC 275
Ask cusco?
Old 01-28-2008, 12:53 PM   #7
B03scooby
Member#: 102929
SWP/ WRB/UGM#239
thanks that is what I thought I just wanted to make sure so that I did waste time trying to install something that would work.
thanks everyone, now I can install this thing without worries
FS GT35R turbo, TurboXS EWG up pipe, Perrin sub frame brace and rear sway bar Aggent15 Engine/Power/Exhaust 64 03-26-2009 08:15 AM
Cusco rear sub-frame brace and Sti rear diffuser B03scooby Suspension/Brakes/Handling 3 02-03-2008 07:13 PM
Quick questions RE: installing Cusco lower frame brace + diffuser ghibli99 Brakes, Steering & Suspension 4 05-20-2006 01:18 PM
Cusco Japan Rear Sub Frame Brace and Diffuser GTWORX.com Suspension/Brakes/Handling 21 11-10-2005 02:14 PM
