Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 01-28-2008, 03:47 AM   #1
savageblitz
Member#: 78394
03 Euro WRX MY03
Dirty White
Default Road Dyno using Enginuity
Hi,
Is it possible to do a road dyno using the logging facility of Enguinuity? Do I need to get any other tools to generate the dyno chart, etc?
Thanks.
savageblitz is offline   Reply With Quote
Old 01-28-2008, 05:29 AM   #2
VladiWrX
Member#: 145658
On my 5th scoob
and lovin it
as far as i know its not possible with enginuity
VladiWrX is offline   Reply With Quote
Old 01-28-2008, 11:32 AM   #3
mickeyd2005
Member#: 122595
2005 LGT Wagon
ABP
Check out Airboy's interpolation spreadsheet. There is a road dyno built in.
For best results, you would log only rpm and time in milliseconds.
mickeyd2005 is offline   Reply With Quote
Old 01-28-2008, 02:01 PM   #4
testes1010
Member#: 47145
2012 Gas Saver
testes1010 is offline   Reply With Quote
Old 01-28-2008, 04:27 PM   #5
gabedude
Member#: 10108
07 STI
60Trim spun rod bearing
I use it, it works great.
Gabe
XPT APS 65 MM Road Dyno map run (Gabedude's tweaked XPT map) included in the 07 STI map package:
gabedude is offline   Reply With Quote
Old 01-28-2008, 08:39 PM   #6
mickeyd2005
Member#: 122595
2005 LGT Wagon
ABP
Wow. That looks nice. You must have a lot of data points.
Has anyone tried using the dedicated WBO2 loggers? They sample AFR and rpm at a very high frequency. You can just cut and paste your data into Airboy's interpolation spreadsheet.
The nice thing about any road dyno is that it's useful for comparisons. Even if they are miscalibrated, they are still good comparisons from one change to another on your own car.
where i can get a map for my 06 wrx, using enginuity jonnies Engine Management & Tuning 6 07-12-2007 05:16 PM
where i can get a map for my 06 wrx, using enginuity jonnies Newbies & FAQs 13 07-12-2007 02:34 PM
anyone in AZ use enginuity? kkam030 South West Impreza Club Forum -- SWIC 30 11-16-2006 07:40 PM
Anyone local using enginuity, ecuflash tools? Panic Tri-State Area Forum 0 07-22-2006 12:08 AM
Home Dyno/Road Dyno Thumper Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-20-2002 10:23 PM
