Old 04-13-2009, 10:34 PM   #1
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Default Car Hesitates, misfires, stutters. Log attached
Car is acting funny over 3k rpms and sounds funny across the entire powerband. Exhaust note is off. Please take a look at attached log to see if you can make anything out. Thanks.
EDIT: it won't let me attach log... How can I attach a log?
Superorb is offline   Reply With Quote
Old 04-14-2009, 08:43 AM   #2
anarchyburger
Member#: 173654
2004 STi
Wonder if you're having the same probelm I had...
Is this after a reflash only or did you perform any physical mods on the car?
I ask because after I installed my VF39 turbo one of the TGVs was re-installed incorrectly and the car ran like complete ***** over 3k RPM.
anarchyburger is offline   Reply With Quote
Old 04-14-2009, 09:22 AM   #3
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Timing belt cover exploded, so I had the timing belt replaced. Still tension on the belt, and it was in time. Shop has checked timing 3 times already and it's in time. Compression and leakdown both OK, plugs gapped correctly. No CEL either. Nothing else was touched. They're going to put a known working crank sensor to see if that's it.
It was working for over a year on this map before the cover grenaded.
Old 04-15-2009, 02:06 AM   #4
noops77
Member#: 177929
u checked ur coils? i had the same issue and it was due to a crack on the ign coil. after replacing them problem solved.
noops77 is offline   Reply With Quote
Old 04-15-2009, 09:58 AM   #5
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Well, nothing wrong with the car before going into the shop, but it runs like crap after leaving the shop. You replaced ALL your coils?
Old 04-15-2009, 09:38 PM   #6
noops77
Member#: 177929
Nah. just for cyl 3 coils. I hope this helps.
Old 04-15-2009, 10:15 PM   #7
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
How do you know which coil is bad?
Old 04-15-2009, 11:01 PM   #8
noops77
Member#: 177929
i had a cel for cyl 3 misfiring 6 mths back and told them and got lucky i guess.
but when i had the stutter issue, no cel was to be found.
try to swap out the coils with a spare from the shop if you can.
Old 04-16-2009, 11:22 AM   #9
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Well, I think they found the problem. My map had TGV codes disabled, and it appears to be a failed TGV sensor. I'm not sure how in the hell it's related to timing belt install, but it died. Thanks for the help.
Old 04-17-2009, 01:45 PM   #10
bcblues
Member#: 17256
04 STi
Blue w/ custom bug splat
Those sensors are very fragile, and they are in a vulnerable position.
bcblues is online now   Reply With Quote
Old 04-17-2009, 02:09 PM   #11
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
So they fixed that problem, but now there's a crack in the radiator. This shop is my car's CURSE.
High RPM misfire/stutter SW00P_G Built Motor Discussion 104 09-07-2011 09:56 AM
Misfire / Stutter only under WOT? SonicYeller Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 03-03-2010 12:47 AM
Not Reaching Target Boost! (02 wrx GM stg 2) **Logs attached recruitX Open Source Reflashes 11 10-08-2008 10:32 PM
Odd IDC's.... log attached TexRex2002 Engine Management & Tuning 1 04-05-2004 12:21 AM
Getting Knock, Log attached mili727 Engine Management & Tuning 9 08-04-2003 12:20 PM
