Old 11-12-2008, 08:05 PM   #1
superfast_wrx
Member#: 144852
2002 impreza wrx
MBP
Default open source problem?
hey guys i have a 02 wrx and i was stage two with a cobb ap v2 and i sold it to help restore my dads car and when i did i went to a local tuner and wanted him to do a basic open ecu tune and when i got there he ran it on the dyno got my base number then when he went to put his tune on it and run it again about 2k rpms the motor would like it fuel cut and the motor would die he even tried rewritting the whole tune and still nothing so we went back to stock and the car ran fine.... the only things i can see being the problem was i was in some type of limp mode or something because i had a bad fuse i fixed that and i had a cheap turbo timmer that i took out i just dont know whats going wrong with it i dont know if it could be the ap or what any help would be great thanks.
superfast_wrx is offline   Reply With Quote
Old 11-12-2008, 08:43 PM   #2
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
Punctuation helps
First and foremost - you need to change your thread's heading, it is misleading. This IS NOT a problem with opensource tuning at all, but rather your "tuners" inability to actually tune your Subaru.
SO as I understand it, you:
1. Reflashed back to stock to do a base run - and all was good.
2. Your "local tuner" fashed "his tune" the car started to run very poor
3. Flashed back to stock and it run normal again.
Not to be an ass, but perhaps your local "tuner" has no idea what he is doing?
How did he come up with his "tune"??? Did he log your car and then adjust your ROM to suit your car??? Or did he just download a "stage" ROM and expect it to work???
Sure you can download a "stage" ROM for your car, but most times they will need to be fine tuned to suit your particular mods.
If I was you, I'd take your car to a tuner that knows what he/she is doing - before you end up breaking your engine.
P.S. A list of your exact mods always helps
wrxsti.l is offline   Reply With Quote
Old 11-12-2008, 09:36 PM   #3
superfast_wrx
Member#: 144852
2002 impreza wrx
MBP
Sorry about not having any Punctuation its a bad habit of mine. But your right about the way the car runs, fine stock, and ****ty when he puts his tune on it. The tuner is not a bad tuner at all the shop has been doing this for a while and i have personaly seen great results from the shop. I dont really know where else to put this ? so i figured the only time i had a prob with the car is when i use open ecu flash. sorry for the bad post ill try to keep myself stright.
a list of mods done to the car are as follow
Full catless ehxaust from the up pipe back
a spt intake
a six speed swap with a spiider dccd controler
smc meth kit
thats about it. Also if it matter when i had the ap the car took the maps from ap fine and worked great. i dont want to have to spend all the money on another ap but i dont want to put my new motor in my car if i cant tune it . Thanks for the help and if any of this makes sence and helps thank u.
Old 11-12-2008, 09:54 PM   #4
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
Have you got a tactrix (openport) cable and WB02? The mods you have are common and quite easy to tune for - any decent tuner should be able to tune for them. Which is why I am suprised that your "tuner" couldn't!
Anyhoo, you could check out one of the free base-maps over on RomRaider.com or osecuroms.org to suit your car and mods and then log and make any extra changes required. There shouldn't be much changes needed if you choose the right base map.
I'd hazard a guess that the ROM you were trying to flash was running more boost, different fuel, or more timing - which didn't suit your car and caused it to hit one of the failsafe limiters.
Old 11-12-2008, 10:15 PM   #5
eminehart
Member#: 11205
2015 WRX
Did he flash the correct rom on your car. He could be flashing the wrong rom. Like a 2005 rom over a 2002 ecu.
Also does he have launch control on it. It could be he doesn't know how to use the launch control patch properly. He could have set launch control for 5000 rpm which is actually a 5000 rpm REDUCTION of the rev limiter.
There is nothing you can do with an AP that you can't do with OpenSource.
It really is a case of USER ERROR if they can't get your car to run properly. It is 100% Tuner error. I hope they didn't charge you.
eminehart is offline   Reply With Quote
Old 11-12-2008, 10:21 PM   #6
superfast_wrx
Member#: 144852
2002 impreza wrx
MBP
ya ill talk to them and see if it was a mistake on the wrong rom. i really dont know i just dont want anything to be wrong with my car because i got big plans for it. the last thing i want is to have to fix somthing like that. I will take it back and see if he can do it again because they owe me a tune haha but ya thanks for the help guys
Old 11-12-2008, 11:19 PM   #7
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
^^Then seek another tuner now before something goes wrong
As I asked earlier, do you have a tactrix cable?
Old 11-12-2008, 11:38 PM   #8
superfast_wrx
Member#: 144852
2002 impreza wrx
MBP
na i got no cable but i was looking at them i might buy one it dosent look to hard to use. just need to find the right base map
Old 11-12-2008, 11:49 PM   #9
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
Yeah. Get yourself a cable - then you could get an internet tune by asomeone who knows what they are doind
Old 11-12-2008, 11:51 PM   #10
superfast_wrx
Member#: 144852
2002 impreza wrx
MBP
ya i think i will its not bad priced its just finding a close enough map so i dont have to do a whole lot to it. thanks
Old 11-13-2008, 08:32 AM   #11
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
np. There should be several free stage 1 or stage 2 maps around for your car to suit your mods.
What is the exact ROM id? Is it A4SGE01C?
Post what ROM you have and I'll link a few free stage ROMs to suit.
Post Open Source Clothing here Porter Off-Topic 15 06-19-2006 11:07 PM
Purchase of ECU Maps for use with Open Source Flash Utilities? f4phantomii General Community 10 03-30-2006 11:06 AM
Open Source equivalent to Outlook? FunkerVogt Off-Topic 6 10-15-2005 12:18 AM
Math/Excel/Chart Wizards: Open source alternative to Excel?? mexicanpizza Off-Topic 14 09-29-2005 08:46 PM
Open-Source ECU Tuning sajohnson Engine Management & Tuning 1 02-12-2003 12:28 AM
