Old 01-28-2008, 01:44 PM   #1
GuitsBoy
Member#: 61721
2006 WRX
Steel Grey Metallic
Default MPG tuning?
Hi all -
Ive been tuning cars in the GM / LSx world for a few years, and now im ready to start playing around with the tuning on my daily driver (2006 WRX). I just ordered my tactrix cable, I downloaded ecuflash and enginuity. I found the latest stock hex files and poked around and found a few popular examples of some stage 1 modified bins. Im leaning towards starting with Gabe's r29 to start with.
Im wondering if anyones been tweaking their fueling in order to get a couple more MPG out of these cars. I see there looks to be plenty of room to work with the open loop fueling tables on the low end, however I dont see any way to adjust the O2 sensor switchpoints for closed loop fueling. Is there some other method of adjusting closed loop fueling? Or will it always shoot for stoich no matter what? I dont think im ready to run an openloop tune in my daily driver.
In the LSx world, ive got my 430 RWHP heads+cam '02 camaro doing about 28MPG through 4'10s, big injectors and heavy tires, not to mention a laundry list of other mods, all through a very conservative tune. With a little more aggressive open loop + MAF tune, i brush up against 30 MPH on the highway. If I can get that big 'ol motor doing that kind of mileage, I really hope I can get a little turbo motor to hit similar marks even through the AWD.
Thanks,
-Tony
GuitsBoy is offline   Reply With Quote
Old 01-28-2008, 02:02 PM   #2
rkramer
Member#: 118209
2002 WRX Sedan
You can set stoich, as well as timing. (increase stoich within limits, and then advance timing to back the EGT's down) Keep doing that until you are comfortable with the numbers and aren't running on the edge of 1 bad tank of gas.
Old 01-28-2008, 02:06 PM   #3
rkramer
Member#: 118209
2002 WRX Sedan
Thanks,
-Tony
Also, keep in mind wrx's/sti's have a horrible drag coeffecient, no matter what you do to them, they never will generate great MPG. The camaro already has that going for it.
Old 01-28-2008, 03:37 PM   #4
GuitsBoy
Member#: 61721
2006 WRX
Steel Grey Metallic
Ill make sure im not running it on the ragged edge by any means...
Where can stoich be set? I dont see a table or option for it in Enginuity. Also, does DFCO (decel fuel cutoff) exist in this world? I think I feel it kick in during decel, although not as pronounced as in other cars.
I had assumed that coefficient of drag had played some role in gas maileage, but after looking into it, it seems that the Cd is very similar to one another. The 2007 WRX is stated as having a Cd of .33 while the 2002 Camaro was stated as having a Cd of .34. If anything that puts the scoobie at an advantage. In real world experience, though, the camaro certainly seems to cut through the air more easily. Its not nearly as battered about by the wind. It also coasts much longer at higher speeds before slowing, although that could also be attributed to the higher parasitic drivetrain loss.
Old 01-28-2008, 05:45 PM   #5
bucket7788
Member#: 124263
2004 WRX Wagon
RomRaider + UTEC Tuned
Under "Fuel"
-Closed Loop Base Fueling Target
bucket7788 is offline   Reply With Quote
Old 01-28-2008, 05:59 PM   #6
GuitsBoy
Member#: 61721
2006 WRX
Steel Grey Metallic
Originally Posted by bucket7788 View Post
Under "Fuel"
Apparently 32 bit O/S's dont have this. I dont know if that will change once they discover all the vars and tables in the rom and update the definition files. I guess im out of luck until that happens.
Old 01-29-2008, 12:40 PM   #7
bucket7788
Member#: 124263
2004 WRX Wagon
Bummer. Wasn't aware of that. Hopefully new defs will help you out.
Good Luck,
Buck
Lower MPG, Is a tune the fix? xxxjuhstenxxx Factory 2.5L Turbo Powertrain 17 10-16-2009 11:23 PM
Less MPG with these upgrades...? (+ Tuning question) BeBop86 Newbies & FAQs 15 07-15-2008 11:24 AM
What kind of mpg increase does one see after a tune? Capt Crunch Factory 2.0L Turbo Powertrain 14 04-09-2007 02:00 PM
NNJ dyno tune place? getting bad mpg. imprezaBlue Tri-State Area Forum 26 01-19-2006 12:27 AM
Cobb Tuning CAI MPG challenge Bankheist Normally Aspirated Powertrain 9 11-06-2001 03:26 PM
Message Board Statistics All times are GMT -4. The time now is 06:01 AM.
