Old 01-29-2008, 04:07 PM   #76
saab-on-the-cobb
Member#: 116330
2005 Saabaru 9-2x
desert sand metallic
How about UCECU ?
OR UC-ECU ?
OR ECU-UC ?
sotc
saab-on-the-cobb is offline   Reply With Quote
Old 01-29-2008, 04:23 PM   #77
Jon [in CT]
Member#: 2992
02 WRX Sedan
Originally Posted by gabedude View Post
I stole your idea! No really I just did not see your post. I like that name too. Since the enginuity is coupled w/ ECUFlash, it makes sense to name it that because you flash with ECUFlash and tune using enginuity.
Since (eventually) enginuity will integrate ECUFlash (basically enginuity will just launch ECUFlash and start the flash process with the current loaded ROM), this name makes good sense to me. Also, once CAN Flashing is done enginuity will support a ton of different ECUs.
I think trying to piggyback on another project's name and fame, openecu, is just a bad idea.
Also, CAN support in ecuFlash won't provide access to any other ECUs beyond the new Subarus and Evos.
Jon [in CT] is offline   Reply With Quote
Old 01-29-2008, 05:37 PM   #78
gaveup
Member#: 116036
2015 WRX STi
Oh man, I have it: Cheaper-than-cobbs-accessport-so-give-it-a-shot.com
Any takers?
gaveup is offline   Reply With Quote
Old 01-29-2008, 05:55 PM   #79
bigdweeb
Member#: 31035
13 Ford Explorer
14 ISM STi
How about ALOTEMS (Automotive/Automobile Logging and Offline Tuning Engine Management System)
Not the sexiest name, but it would evoke the idea that it can be leveraged for other cars in the future. Offline could be changed to something else if RAMTune or whatever it's called ever gets added in. And .com/net/org are available!
bigdweeb is offline   Reply With Quote
Old 01-29-2008, 06:28 PM   #80
Barge
Member#: 62941
2004 WRX
Rally Blue
For those of us that might like to contribute to the project what skills will help?
And things like map decoding and stuff like there... is there info out there to give people a place to start?
Barge is offline   Reply With Quote
Old 01-29-2008, 07:00 PM   #81
Freon
Member#: 88322
2009 BMW 135i
Start reading through old threads on openecu.org forums. There is a fair amount of background information there. This started back in 2005, so hope you've got some time to kill.
Freon is offline   Reply With Quote
Old 01-29-2008, 09:08 PM   #82
gabedude
Member#: 10108
07 STI
60Trim spun rod bearing
Although it may require new hardware, it can be done. 2007 emissions standards made every automobile sold in the USA adhere to the J2534 API which includes reading and writing ECUs. You can obtain a reflash CD from any automaker. Disassembly (of the ROMS) and coding all of that flash process is what will be hard. It will take more effort, yes, but we are not limitted to EVOs and Subarus or one specific ECU brand. Figuring out the flash process for a manufacturer will be easy once a cable is made and software written for it. The specification for the CAN Bus J2534 API can be had for 49.95. I already have the Subaru reflash CD. Then it is as simple as making the cable (if we need to as this standard can go over RS232), adding tracing to the driver, and viola, you have your flash process by using the manufacturer's reflash CD.
http://www.sae.org/servlets/productD...J2534/1_200412
http://www.drewtech.com/support/j2534/
What I am missing is a test ECU that is listed on the Subaru reflash CD (to put it on a bench).
Gabe
gabedude is offline   Reply With Quote
Old 01-29-2008, 10:59 PM   #83
illmatic
Member#: 3536
2015 IMS BRZ Limited
2002/2003 AW/PSM WRX
I'd be interested in helping build a CAN Bus cable. Do you know if the creator if the tactrix cable (cboles) from openecu.org intends to make one?
I'm thinking about purchasing that document in that link.
jay
Gabe
illmatic is offline   Reply With Quote
Old 01-29-2008, 11:42 PM   #84
Worxman02
Member#: 66563
2002 Impreza WRX
WR Blue Pearl
PM sent to qoncept about logo.
Worxman02 is offline   Reply With Quote
Old 01-30-2008, 03:35 AM   #85
SuperDuper
Member#: 131101
2004 AW STi
Are we done with the name calling?? I would call it YouTune. SEXY!
SuperDuper is offline   Reply With Quote
Old 01-30-2008, 04:32 AM   #86
Remnex
Member#: 83790
I said the uTune thingy first!
Remnex is offline   Reply With Quote
Old 01-30-2008, 04:43 AM   #87
SuperDuper
Member#: 131101
2004 AW STi
UTune....YouTune...Close!! BUT!! UTune would be too much like UTEC!
YouTune = MAGNANIMOUS!!
Old 01-30-2008, 05:51 AM   #88
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
Originally Posted by qoncept View Post
That reminds of of MDK. I think I've decided on a name. I'm working with a new host to get everything back up ASAP.
So will it be LTF
Also, I am more than happy to provide free webhosting for you. My webhost of 5 years allows me unimited domain hosting with 500GB of server space and 5TBmonth data transfer/traffic - and I'm lucky to use 500MB of space and 100MB of traffic a month
Way more than enough for you to set up forums, ftp, website, emails, wiki, blog etc - Just let me know and I can have it up and running for you in a jiffy - I will also install cms, forums, blog, wiki packages for you you like
wrxsti.l is offline   Reply With Quote
Old 01-30-2008, 07:44 AM   #89
gabedude
Member#: 10108
07 STI
jay
I already have it all. I need an ECU (any ECU on the Subaru CD reflash list, which I may be able to get a broken one for cheap (05 STI) and fix it myself once I buy the appropriate tools). I think the Tactrix cable will work and yes, I have contacted Colby about this. So far he is only working on a DLL for the cable to enable Subaru and Mitsu CAN Flashing. His code is tightly integrated with the GUI (yes I have a copy), so I may start from scratch so any car can work (2003+ models is what is in the emissions standards). This, however would de-couple enginuity from ecuflash. I want to avoid this.
Gabe
Old 01-30-2008, 08:24 AM   #90
STFU STi
Member#: 39528
2005 STi
Black and TiC Cows
just 2 little cents..
i hate anything with "ECU" in the title..
too many syllables... when pronounced.. I agree with Bill on his parameters..
easy to spell, easy to pronounce
youtune
utune.
whatever.. is kinda catchy
like itunes (and all that other apple i-crap) and like you-tube.. also very current..
damn it.. when old people are refering to youtube... it has to be current..
STFU STi is offline   Reply With Quote
Old 01-30-2008, 08:31 AM   #91
Tea cups
Member#: 103136
You should google these names. Youtune, like some of the other suggestions, has a ton of hits and is already used as a title to software, sites, businesses, etc. And the domain name is already taken.
Tea cups is offline   Reply With Quote
Old 01-30-2008, 08:36 AM   #92
STFU STi
Member#: 39528
2005 STi
Black and TiC Cows
sorry, hadn't had the chance... but something liek that would be sweet.. (along with an e-mail version of the program with LC... for the STU car )
Old 01-30-2008, 11:53 AM   #93
JustinS STi
Member#: 65125
05 STi
I was very happy to run across this thread today.
In the end the name won't mean much to anybody but us, but I think it should include "open" or "free" and "tune" somehow.
JustinS STi is offline   Reply With Quote
Old 01-30-2008, 01:52 PM   #94
javanaut
Member#: 107274
2008 STi
I'm very glad to see this project continuing. There have been several decent selections, so all I could think of were:
OStunify
freetunify
I like "tunify" but it looks like the Natural Language Processing geeks have already claimed that word.
javanaut is offline   Reply With Quote
Old 01-30-2008, 02:39 PM   #95
qoncept
Member#: 44762
2013 BRZ
Alright guys, the name is decided on. I'm working with a new web host to get things ready to go. I'm not going to give any time estimates at all this time as they always come back and bite me in the ass, but things are finally moving again.
qoncept is offline   Reply With Quote
Old 01-30-2008, 02:49 PM   #96
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Gonna tell us the name?
Old 01-30-2008, 02:56 PM   #97
hurricane123
Member#: 121116
2004 WRX
v7 w/VF30
Will all the posts and knowledge from the old site be integrated into the new one?
Jeff
hurricane123 is offline   Reply With Quote
Old 01-30-2008, 03:42 PM   #98
ExpO
Member#: 115819
2006 vf39 R0mRa1DeR
Darknessess Wagon
Jeff
^ +1
ExpO is offline   Reply With Quote
Old 01-30-2008, 04:03 PM   #99
qoncept
Member#: 44762
2013 BRZ
Yep, basically the site should be exactly the same as it was with a new name. I've pulled everything from the old host and migated it to the new one. I'm holding off with announcing anything but you'll know soon enough. Depending on what we're able to get done, we may be going live with some things not working properly but it'll get there eventually.
Old 01-30-2008, 04:58 PM   #100
crispyduck
Member#: 98680
Jared, more than happy to lend a hand mate ... again ....
-Steve.
P.S: Will this be an annual thing - changing the name?
crispyduck is offline   Reply With Quote
Monthly state of the OT address IggDawg Off-Topic 38 10-14-2004 10:22 AM
State of the Union Address is on right now! Janq Political Playground 45 01-22-2004 03:43 PM
Does a state of the union address affect a president's popularity? imprezton Political Playground 19 01-22-2004 12:51 PM
State of the Union Address (on crack) Project Jennifer Off-Topic 2 01-22-2004 09:27 AM
State of the Union address.... comments? (merged threads) Erudition Off-Topic 78 01-29-2003 11:56 PM
