Old 01-28-2008, 03:41 PM   #1
testes1010
Member#: 47145
2012 Gas Saver
Default DataLogLab RoadDyno Enginuity Definition.
For those using DataLogLab for road dynoing here is my latest definitions using Enginuity's latest Logger Definitions.
Its now setup to display 'Manifold Relative Pressure (Direct)* (psi relative sea level)', 'Engine Load (Direct)* (g/rev)', 'Knock Correction Advance (degrees)', & 'LC-1 (AFR)' although the LC-1 Enginuity datalog column name may have changed since the last revision to the enginuity logger definitions. Just change the ColumnTitle=, the file should be put in:
C:\Program Files\DataLogLab\Universal Data Log Formats\Enginuity_WRX_DataLogDefinition.txt
On DLL: Under Customize>Options>File Locations & Power Graph> Path & File Name of Univ. Data Log Defintion File. Find the file, Click Load.
If you don't like the 'Knock Correction Advance (degrees)' simply change the ColumTitle= to FLKC or FBKC as it is displayed in the datalog. You may have to change the conversion factor as well to get it in the viewable area of the graph.
Code:
[DataLogDefinition]
 Name=Enginuity WRX
 FileExtension=csv
 DelimiterAsciiCharacter=44
[Column]
 Name=Time
 Description=Time
 ColumnTitle=Time
 DataItemID=63
 Type=1
 ColumnDecimalPlaces=3
 Offset=0
 ConversionFactor=0.001
 DisplayDecimalPlaces=3
 DisplayColour=630000
 DisplayLineWidth=3
 DisplayLineStyle=1
[Column]
  Name=Boost*100
  Description=Boost
  ColumnTitle=Manifold Relative Pressure (Direct)* (psi relative sea level)
  DataItemID=37
  Type=1
  ColumnDecimalPlaces=2
  Offset=0
  ConversionFactor=10.0
  DisplayDecimalPlaces=2
  DisplayLineWidth=3
 DisplayLineStyle=1
[Column]
  Name=Load*1000
  Description=Load
  ColumnTitle=Engine Load (Direct)* (g/rev)
  DataItemID=76
  Type=1
  Offset=0
  ConversionFactor=1000.00
  DisplayLineWidth=3
 DisplayLineStyle=1
[Column]
   Name=Knock Correction*100
   Description=Knock Correction
   ColumnTitle=Knock Correction Advance (degrees)
   DataItemID=62
   Type=1
   ColumnDecimalPlaces=1
   Offset=0
   ConversionFactor=100.00
   DisplayLineWidth=3
 DisplayLineStyle=1
[Column]
   Name=AFR*10
   Description=AFR
   ColumnTitle=LC-1 (AFR)
   DataItemID=36
   Type=1
   Offset=0
   ConversionFactor=10.00
   DisplayLineWidth=3
 DisplayLineStyle=1
[Column]
 Name=Engine Speed/10
 Description=Engine Speed/10
 ColumnTitle=Engine Speed (rpm)
 DataItemID=3
 Type=1
 ColumnDecimalPlaces=0
 Offset=0
 ConversionFactor=1
 DisplayDecimalPlaces=0
 DisplayFactor=0
 DisplayColour=4227072
 DisplayLineWidth=3
 DisplayLineStyle=1
An example, don't worry the car didn't go home this way:
testes1010 is offline   Reply With Quote
Old 01-28-2008, 05:23 PM   #2
benw
Member#: 103320
1998 swapped
Forester L
thank you for posting this. back when I was looking for it, I had to register on a puerto rican forum just to get the DL link.
benw is offline   Reply With Quote
Old 01-28-2008, 05:33 PM   #3
testes1010
Member#: 47145
2012 Gas Saver
no problem, I've had several requests here recently for the definition file. Figured I'd just post it up.
Old 05-10-2008, 10:19 AM   #4
highmark
Member#: 164128
2004 STi
None of the values from my log seem to be showing up? Any suggestions?
highmark is offline   Reply With Quote
Old 05-10-2008, 03:16 PM   #5
testes1010
Member#: 47145
2012 Gas Saver
Did you make sure the timestamp was not absolute on the logger?
Old 05-10-2008, 05:17 PM   #6
fujiillin
Member#: 171344
2006 STi Wagon
Black HTA Green
Thanks!
Have any opinions on the accuracy of DataLogLab vs Mick's spreadsheet dyno?
fujiillin is offline   Reply With Quote
Old 05-10-2008, 06:59 PM   #7
highmark
Member#: 164128
2004 STi
Yes, not absolute in the logger. I did another log yesterday and used that and it now seems to work. I've noticed that when Enginuity logs sometimes it doesn't fully log what is going on every time. Thanks for your help!
Old 05-16-2008, 04:41 AM   #8
Farnk
Member#: 91093
2002 Wrx
I tried to use several logs old and new but when i hit draw its just a flat line, and i did select values on the left to include but it doesnt look like anything. I looked and its not set for absolute time.
Farnk is offline   Reply With Quote
Old 05-16-2008, 09:22 AM   #9
testes1010
Member#: 47145
2012 Gas Saver
^post up a bit of the log in [code] brackets.
Old 12-17-2008, 05:25 PM   #10
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
is this program worth the money if we're already good with airboys sheet?
Old 12-17-2008, 06:05 PM   #11
jays05
Member#: 78165
05 STI 35r + e85
I tried some logs back to back in both the spreadsheet and dataloglab and got the same numbers. Dataloglab is nice for comparing different runs and stuff though.
You should be able to download a 30 day eval.
jays05 is offline   Reply With Quote
Old 12-19-2008, 08:21 PM   #12
nj1266
Member#: 197637
2006 Evo IX
You must make the txt definition file compatible with your log. The column title in the txt file must be the same as the column title in your log.
nj1266 is offline   Reply With Quote
Old 04-03-2009, 01:46 AM   #13
05wrx09
Member#: 204111
2005 WRX
I know I'm a noob and I'm sorry but all I can get to display looks like this:
http://i4.photobucket.com/albums/y10...e/Picture1.png
What am I doing wrong?
05wrx09 is offline   Reply With Quote
Old 04-06-2009, 06:33 PM   #14
STI_KLR
Member#: 189660
'02 WRX
Element Tuning Race Team
Ok, I couldn't get this to work at all. I successfully loaded what you put in the first post, but I can't get the program to recognize the car. It's an '05 STI. Is there something special you have to do (like in RomRaider when you have to select COM4)?
STI_KLR is offline   Reply With Quote
Old 04-06-2009, 08:59 PM   #15
testes1010
Member#: 47145
2012 Gas Saver
you need to open the romraider generate .csv file.
Old 04-06-2009, 09:28 PM   #16
STI_KLR
Member#: 189660
'02 WRX
ahhhh that would make sense now.
i'll try it tomorrow.
GT3076 airboy roaddyno 24psi...E85 TDagen Proven Power Bragging 30 11-02-2009 10:19 AM
DatalogLab worth the cost? jblaine Engine Management & Tuning 0 09-22-2005 06:46 PM
DataLogLab adds 3.6 to my boost NavyBlueSubaru Engine Management & Tuning 7 04-09-2005 10:48 PM
Dataloglab Compatability with Tuna WB02 NavyBlueSubaru Engine Management & Tuning 2 05-17-2004 05:08 PM
300+WHP measured by dataloglab NavyBlueSubaru Proven Power Bragging 48 09-02-2003 02:06 PM
