Welcome to the North American Subaru Impreza Owners Club Friday July 3, 2015
Old 01-28-2008, 03:59 PM   #1
methaddict
Member#: 159738
2004 WRB STi
Full Race TS, BW 8374 EFR
Default Perrin modified sti sidefeed latency values on Enginuity?
Anyone know what the latency values are for the Perrin modified 816cc sti yellow sidefeed injectors? I'll be using Enginuity to reflash the latency values. Thanks in advance.
methaddict is offline   Reply With Quote
Old 01-28-2008, 04:06 PM   #2
06rexwagon
Member#: 114730
2006 WRX Limited Wag
9.8@150
They claim that they're stock, but they are not. I have found this to work:
Code:
6.00	9.00	12.00	14.00	16.00
5.40	1.89	0.97	0.74	0.53
06rexwagon is offline   Reply With Quote
Old 01-29-2008, 01:56 PM   #3
wittmer25
Member#: 102970
2004 STi gt30r
What about the injector scalar?
wittmer25 is offline   Reply With Quote
Old 01-29-2008, 03:12 PM   #4
06rexwagon
Member#: 114730
9.8@150
816cc
Old 01-29-2008, 04:06 PM   #5
wittmer25
Member#: 102970
2004 STi gt30r
I was just wandering because the stock sti injector scalar value is less than the rated flow. I have always heard that most people use less than 100% of the rated flow for their injector scalars.
Old 01-29-2008, 05:19 PM   #6
Jon [in CT]
Member#: 2992
02 WRX Sedan
Do you have Denso spec sheets for the stock STI injectors? How did you determine their "rated" flow?
Jon [in CT] is offline   Reply With Quote
Old 01-30-2008, 06:38 PM   #7
wittmer25
Member#: 102970
2004 STi gt30r
I thought everyone knew their "rated" flow. Correct me if I am wrong, but aren't they rated at like 550 cc/min? The stock scalar is closer to 500 cc/min...I can't remember the stock value exactly.
Old 01-30-2008, 07:27 PM   #8
R4ND0M_AX3
Member#: 67483
2005 WRX STi
Stock STi sidefeed injectors are close to 500cc/min.
R4ND0M_AX3 is offline   Reply With Quote
Old 01-30-2008, 10:07 PM   #9
mickeyd2005
Member#: 122595
2005 LGT Wagon
ABP
One person I know had his sidefeed injectors tested and they are close to 520 cc/min. The 2005 LGT side feed injectors are the same as the 2005 STi side feed injectors. This has been confirmed by part numbers. I'm not sure why enginuity reports one as 500 and the other as 520.
mickeyd2005 is offline   Reply With Quote
Old 01-31-2008, 07:28 PM   #10
Freon
Member#: 88322
2009 BMW 135i
I'm using stock latency values for modified STI side feeds.
Freon is offline   Reply With Quote
Old 01-31-2008, 07:38 PM   #11
06rexwagon
Member#: 114730
9.8@150
Stock maf scaling? If you want to leave the maf alone you have to change the latency.
Old 01-31-2008, 07:55 PM   #12
Freon
Member#: 88322
2009 BMW 135i
When I changed injectors I made no other changes to my car. I only changed the injector scalar. I never would have been able to tell.
I had bumped the injector latency up to help with the ... less than optimal Perrin GT rotated intake system. But I'm back to stock now with SD.
Old 02-01-2008, 12:19 AM   #13
wittmer25
Member#: 102970
2004 STi gt30r
I too run stock latency with good results. My scalar is set at 800.
Old 02-01-2008, 10:18 AM   #14
06rexwagon
Member#: 114730
9.8@150
I've yet to see an STi with a stock maf, running stock maf scaling, and 816cc injectors run stock latency without very large fuel trims at idle.
Old 02-01-2008, 11:04 AM   #15
wittmer25
Member#: 102970
2004 STi gt30r
My MAF isn't stock (BigMaf) and I have a ton of other mods and my car idles at 1000 rpms.
Old 02-01-2008, 11:07 AM   #16
06rexwagon
Member#: 114730
9.8@150
Exactly. You had to scale the MAF so that it would idle anyway because of the BigMAF. It's two ways of achieving the same result. We're both right.
Old 02-02-2008, 10:47 PM   #17
methaddict
Member#: 159738
2004 WRB STi
I'm using Utec but need to change the latency on my ecu in close loop with enginuity. I've had the Perrin modifieds in there before with a protune but I was getting misfire cels so I put the stockers back in. I'm maxing out the stockers right now with meth injection. Just waiting for my Tactrix cable so I'm not familiar with enginuity yet. Is the "scalar" injector scaling?
Old 02-03-2008, 11:15 PM   #18
bboy
Member#: 56468
04 Improved STI
Dirty White
Latency is just added to the pulse width so you either tune that in the MAF or the scaling. I see no reason to mess with latency. I've used 750 and 775 as the scaler for the Perrin or Kito Auto Sport mod'd sidefeed 820 cc/min injectors.
Old 02-03-2008, 11:42 PM   #19
mickeyd2005
Member#: 122595
2005 LGT Wagon
ABP
You're better off putting the correct latency in.
6000 rpm at 0.3 g/rev has the same amount of latency as 2000 rpm at 0.3 g/rev but it has 3X the MAF.
If you don't use the correct latency, then you're going to need to tweak every open loop cell especially the low load regions. The high load regions, of course, the latency has negligibl impact. The closed loop will be taken care of by STFT. If you're running speed density, this isn't a problem.
Besides, it is very easy to calculate the latency using a scatter plot or even a consistent high speed idle so I see no reason not to tune the latency correctly.
Old 02-04-2008, 12:15 AM   #20
R4ND0M_AX3
Member#: 67483
2005 WRX STi
correcting latency error with the MAF table is also not going to help you when your voltage swings. I've driven cars without functioning alternators before and would hate to have the car just stall immediately because the voltage continued to drop as the battery drained.
Old 02-04-2008, 01:00 PM   #21
06rexwagon
Member#: 114730
9.8@150
Well said. Funny how me trying to help the OP turned into a debate.
Old 02-19-2008, 08:08 AM   #22
methaddict
Member#: 159738
2004 WRB STi
I installed the Perrin modifieds in and set the injector scaling to 816cc by using Ecuflash. It was running extremly rich at idle, stumbling and barely idling, eventually stalling. WB afr's where between 22-23 @ idle. I left the latency numbers same as stock since it showed the same on Cobb's info sheet. At some point I also got a 2109 cel. What am I doing wrong?
Old 02-19-2008, 08:14 AM   #23
06rexwagon
Member#: 114730
9.8@150
Try the latency values I listed early in the thread. If that doesn't work you have an injector that is stuck. I just had this happen on a car with newly installed 816s. #4 injector wasn't firing and my a/f corrections were ridiculous. I got a misfire CEL.
Old 02-19-2008, 08:36 AM   #24
methaddict
Member#: 159738
2004 WRB STi
If an injector is stuck, what can be done about it? I'll also give your latency values a try.
Old 02-19-2008, 09:39 AM   #25
mickeyd2005
Member#: 122595
2005 LGT Wagon
ABP
If you have a stuck injector, you should be able to see it by logging roughness.
The modified injectors that I have seen need more latency. Even if the electric coil is the same, it takes slightly more time for flow to increase from 0 to 520 cc/min versus 0 to 816 cc/min.
Were your Perrin's straight from Perrin or were they previously used? Do you have the flow sheets?
Perrin modified sti sidefeed injectors 816cc methaddict Engine/Power/Exhaust 14 03-01-2008 08:28 PM
sti sidefeed latency settings for powerfc GShinji Pre-2002 Factory Turbo Powertrain 0 08-21-2007 06:32 PM
WTB: EcuTek reflashed STi ECU and Perrin Modified STi Injectors SupraScooby Private 'Wanted' Classifieds 0 11-06-2004 11:42 PM
Perrin modified STi injectors and Helix DP NIB turbohardtop Private 'For Sale' Classifieds 1 10-13-2004 09:57 AM
Perrin MODIFIED STI INJECTORS wrxstistunna Private 'For Sale' Classifieds 1 07-27-2004 06:46 AM
