Old 01-28-2008, 07:00 PM   #1
mikndee
Member#: 169433
2010 wrx
rally blue
Default stage 1, stage 2 ?
what would warrant an ecu upgrade and tune. ieg, stage 1 = cat back, cold air intake?. ieg, stage 2 = headers, hi-flow cat, cat back, lightweight pullys?. etc etc.... whats a good rule of thumb. also what would be the best, piggy back ecu, or new ecu?
mikndee is offline   Reply With Quote
Old 01-28-2008, 07:16 PM   #2
EvoSpeed
Member#: 155430
2008 Nissan
SE-R Spec V
Arent stage one, stage two for turbos. i may just be ignorant
EvoSpeed is offline   Reply With Quote
Old 01-28-2008, 07:19 PM   #3
rougeben83
Member#: 115154
2005 Outback XT
White on grey
none. All that "staging" BS is just marketing jibberish. For an N/A car you can go without an ecu tune even after all the bolt-ons you can think of have been installed...some even run more aggressive cams without it.
You can make more power with the ecu tuned on a DYNO, from adding just a catback all the way up to however wild you want to get. Of course, the rule of thumb is the more parts you add, the more gains you can get from that one dyno tune.
I think yours can be tuned using OpenECU or one of those software that has a free license and no need for a piggyback. If you really want a piggyback, Emanage & PP6 are probably the 2 most popular ones right now.
I think Ispeed still does ECU reflashes, but you'll need to contact them for your particular application.
rougeben83 is offline   Reply With Quote
Old 01-29-2008, 12:28 AM   #4
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
"Stages" are for 16 year old high school drop outs with nothing better to do than name things like "stages"...
Old 01-29-2008, 01:24 AM   #5
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
98 OBS-T, 91 Legacy SS
Jumping on the ignorance bandwagon here...
I thought only WRX's and STi's had reflashable ECU's until MY 08 where they finally used a reflashable ECU for the non-WRX's.
I'm open for correction on that of course.
PhilSine is offline   Reply With Quote
Old 01-29-2008, 02:29 PM   #6
mikndee
Member#: 169433
2010 wrx
rally blue
so stages are just bs i guess or for turbo's. so just bolt on some stuff and get it retuned on a dyno? can it be retuned without buying an aftermarket ecu?
Old 01-30-2008, 01:24 AM   #7
rougeben83
Member#: 115154
2005 Outback XT
White on grey
If your local tuner supports openECU, I think your 04 can be tuned with it. Their site just released the 2.5i/RS maps I think... Do a search for the thread here in this forum.
Old 01-30-2008, 12:52 PM   #8
LTracer
Member#: 167703
2005 '05 2.5RS 5MT
'10 Forester X Limited
05+ RS/I's have a 32bit ECU that can in fact be reflashed using opensource software and a tatrix cable.
Not sure on your MY 04 but I bit if you do some searching over at the opensource forum you should find an answer
LTracer is offline   Reply With Quote
Old 01-31-2008, 01:59 AM   #9
roninrider_9
Member#: 131591
06 stage 2 Wagon
i went with ralliteks PP6 and i love it, i agree with the stage crap to its all jibberish when it comes to NA's
roninrider_9 is offline   Reply With Quote
Cobb Stage 1, Stage 2 (STI) STiBoost25 AccessPort 12 07-05-2008 03:49 PM
2008 AMR STi - Stage 1 / Stage 2 AMR Proven Power Bragging 12 03-07-2008 05:12 PM
Question about Stage 1-Stage 2! itjustWoRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 06-15-2005 05:05 PM
Cobb Stage 1 - Stage 2 Shootout 50mph 3rd gear roll willguidry Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 144 06-08-2005 06:50 PM
Stage 1... Stage 2... Stage 3 hoku123 Newbies & FAQs 5 04-10-2004 07:51 PM
