Old 01-28-2008, 08:03 PM   #1
mikndee
Member#: 169433
2010 wrx
rally blue
Default octane
as long as im posting threads that are ignorant. well i usually put in 93 octane here in hawaii. but what would really be the difference if i just put in 89. the owners manual says to put 93/92. but seriously, obviously the higher octane the better the combustion right? but i kinda want better gas milage since 93 is like 3.50 a gallon on a good day. any ways to optimize gas and performance at the same time.
mikndee is offline   Reply With Quote
Old 01-28-2008, 08:12 PM   #2
oneLEADFOOT
Member#: 133283
2006 WRX TR
CGM
I might be wrong but I think it's a waste of money to put 93 oct in your RS. I had a near stock RS for 5 years and always used 87-89 with no problems.
oneLEADFOOT is offline   Reply With Quote
Old 01-28-2008, 09:40 PM   #3
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
The owner's manual should say to put in 87 if you've got a 2.5RS like your profile says.
Higher octane gas provides NOTHING but greater resistance to knock. If you're not knocking and the ECU doesn't have the authority to advance timing, then you get NOTHING from running higher octane gas. It just costs more.
Old 01-28-2008, 09:54 PM   #4
imprexaRS03
Member#: 145883
2008 wrx
psm
i never put 91 in my rs
imprexaRS03 is offline   Reply With Quote
Old 01-28-2008, 10:32 PM   #5
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
Waste of money unless you have higher compression, turbo, or mods that warrant using higher octane. You might ping a little more on steep hills, but generally it's not worth it.
~Josh~
Old 01-28-2008, 11:15 PM   #6
LTracer
Member#: 167703
2005 '05 2.5RS 5MT
'10 Forester X Limited
http://en.wikipedia.org/wiki/Octane_rating
Includes a good piece on tuning and how my power comes about from tuning and high compression. Williaty hit it on the head. Higher octane = more resistance to knock = potential for increasing compression/timing. If your '04 RS is stock you'll see very little (if any) tangible gains from anything above 87. Also, premium fuels contain the SAME amount of additives as 87 and haven't be shown to decrease carbon deposits or increase the longevity of the engine.
LTracer is offline   Reply With Quote
Old 01-29-2008, 12:34 AM   #7
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Does it really say Premium in your owner's manual?
rougeben83 is offline   Reply With Quote
No MTBE 91 octane vs. MTBE 91 octane wayoutwest Southern California Impreza Club Forum -- SCIC 40 08-31-2002 05:40 AM
Turboxs stage 2 power, 14 psi vs. 17 psi, 91 octane 93 octane Fubaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-06-2002 11:26 AM
Unichip Octane Requirements/Octane Boosters? 2002wrx1 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 08-18-2001 12:42 PM
