Old 01-28-2008, 10:11 PM   #1
seps_wrx
Member#: 92455
Default Can you Jack an Impreza up using the Prodrive Diff Gaurd?
Gents,
I just got a Rear Diff Gaurd from Prodrive. The instructions say not to use it as a jack point. Does anyone here have the Prodrive Diff Gaurd and still jack the car using the rear diff?
Why would Prodrive put that on rally cars if the end result is you cant jack the car up by the diff anymore?
seps_wrx is offline   Reply With Quote
Old 01-28-2008, 11:27 PM   #2
Arctic Penguin
Member#: 119532
2006 WRX
they just dont want to be sued if it falls off the jack and kills you
Arctic Penguin is offline   Reply With Quote
Old 01-29-2008, 02:01 PM   #3
seps_wrx
Member#: 92455
Ok,
Do you own this part?
The reason why Im asking is because the 2 brackets that bolt the gaurd to the chasis under the car are pretty flimsy.
The other end of the gaurd bolts directly to the diff and I dont see that being an issue but these metal brackets at the other end might just bend.
In fact that may even be the idea so if a huge rock hits the gaurd, the brackets under the car bend, thus absorbing the impact.
Does anyone who actually owns this part have any input?
Old 01-29-2008, 03:01 PM   #4
Undepelo
Member#: 34960
What would baby
Jesus say of OT?
I have the thin Primitive one and lift it all the time. Just make sure you have something soft like wood or rubber between it and the jack.
Undepelo is offline   Reply With Quote
FS : FS:PA:Turbo XS/Swift/SPT/ bunch of random stuff. guesswhoou812 Tri-State Area Private Classifieds 12 07-06-2010 05:33 PM
can you cook an engine even if the gauge reads normal? ncarn8 Pre-2002 Factory Turbo Powertrain 14 02-20-2010 05:36 AM
Can you buy an iPhone in the US for use in Europe ? ZMANNH25rs Off-Topic 14 03-07-2008 11:35 AM
Can you do an ecu reset with the utec still plugged in? waitandbleed92 Engine Management & Tuning 4 03-31-2003 03:49 PM
