Old 01-29-2008, 05:56 AM   #1
renhoek
Member#: 71339
1995 WRX STi RA
1995 WRX STi LS1
Default Logger selections disappeared AND Load axis on maps now only go to 3.00 instead of 6.
Hi all. I've been checking out the old Enginuity site from time to time and see there are still challenges.....Thank goodness NASIOC can keep our life support systems going!
I rebuilt my laptop last week & downloaded the latest versions of defs, logs and enginuity & installed as per usual. I've got 2 issues now that I didn't have before & can't work out what I've got wrong. I even deleted everything & started again but no change. I'm hoping if I discuss the symptoms, someone will know what the prob is. Laptop is on XP by the way.
First, I re-scaled my maps a year or so ago to a load of 6.0. I checked they are still good via Ecuflash, and confirm they still go to 6.0 in Ecuflash. Enginuity only shows them going to 3.0. Why?
Second, if I fire up the logger, I can't see any selections in the left hand panes. No parameters, no switches and nowhere to select the LC1 which I could do before.
Plugging into the car's ECU does nothingto solve the prob., but at least the laptop is communicating with then ECU so no issue there. The car by the way is an 02 Aussie WRX.
Anyone got any clues to why it's doing this?
renhoek is offline   Reply With Quote
Old 01-29-2008, 06:53 AM   #2
phong
Member#: 10884
2002 WRX Wagon
As far the load goes the units in the newer definitions changed to g/s rather than (g*2/s), so basically what was 6 in the old units now equals 3 in the new units...If you update the ECUflash definitions the change will show up there as well. I too experienced this abrupt change when I updated at the end of the summer after not using Enginuity for a few months.
As far as your second problem what version of Enginuity are you using?
Dan
phong is offline   Reply With Quote
Old 01-29-2008, 07:05 AM   #3
parso_rex
Member#: 78984
2004 MY04 STI 2.5L
WRC Blue
remember the 16bit scale was 2*gms/rev versus the 32bit Ecus gms/rev (i.e it was effectively double) is this what you meant. Actually I think this was going to be or rather was standardised in the later releases. does that seem right
What version are you running ? one of the test releases yes ?
Cheers
Mark
parso_rex is offline   Reply With Quote
Old 01-29-2008, 07:06 AM   #4
parso_rex
Member#: 78984
2004 MY04 STI 2.5L
WRC Blue
hah beat me to it
Old 01-29-2008, 09:01 AM   #5
Tea cups
Member#: 103136
Yes, you were running some very old defs if it doesn't show g/rev (v. 2*g/rev). You are also using a old version of Ecuflash.
As far as the logger, for LC-1 support you'll need to run one of the test releases (see FAQ). If you get no parameters in the logger, then likely you do not have the correct COM port selected (see dropdown box). If you tried all the COM ports and still nothing, then you have a driver install issue. If it is win OS then go to device manager, plug tactrix cable in, look under ports for openport cable, select update driver, select a specific location, choose x:\openecu\ecuflash\drivers\ where x: is the drive Ecuflash is installed on.
Tea cups is offline   Reply With Quote
And here's why you take your car to a specialist instead of a general mechanic semabe Off-Topic 48 03-27-2006 07:37 PM
And now I go to Swiss jail... Reciprocity Off-Topic 68 03-19-2006 05:58 PM
I am going to drink a gallon of milk in one hour right now LIVE! Johnny Knoxville Off-Topic 87 01-06-2006 07:29 PM
So I've started waving to VAG drivers instead of scoobies... Layman Off-Topic 20 09-11-2005 02:30 AM
Philly: who wants to go to Mazda-rev-it-up 6/5-6/6 ? edkwon Tri-State Area Forum 6 05-07-2004 10:08 AM
