Old 01-29-2008, 11:57 AM   #1
snowb0ardin04
Member#: 94324
2000 2.5 RS
Question Acetone in Gasoline...good idea???
I have heard that it was a good idea to mix 3 ounces of acetone to 10 gallons of gas...for better performance and gas millage...because of the high octane...has anyone heard of this before???
snowb0ardin04 is offline   Reply With Quote
Old 01-29-2008, 12:05 PM   #2
cmiovino
Member#: 134005
2004 WRX Premium
I've heard it.
Some say it works, some say it doesn't... some even get LESS gas mileage.
The only thing I put in my tank besides gas is fuel system cleaner every year or so.
Old 01-29-2008, 12:46 PM   #3
flstffxe
Member#: 155358
2008 Forester
Steel Silver
this was on myth busters, However I think the out come was it didn't do any thing.
flstffxe is offline   Reply With Quote
Old 01-29-2008, 12:52 PM   #4
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
HamFist is offline   Reply With Quote
Old 01-29-2008, 01:08 PM   #5
DiscoGsus
Member#: 47646
0511 RallyBaja
DGM Sedan
On Mythbusters they showed it didn't hurt/stall the engine.
They didn't dyno or test anything.
Your car will burn cleaner when you add rubbing alcohol into the gas. (Like one 8oz bottle per tank.) Some people have passed sniffer emissions test with no cats by doing this. Some have also failed because the car burns too clean.
Another thing that you may or may not care about. Eventually alcohol will eat your fuel lines. But it will take a REALLY long time assuming the concentration stays low and you drive fairly often.
DiscoGsus is offline   Reply With Quote
Old 01-29-2008, 04:01 PM   #6
EdHilario
Member#: 137398
2004 Impreza 2.5RS
Just a rumor/myth.
If you want to, try it for yourself and see what happens lol.
EdHilario is offline   Reply With Quote
Old 01-29-2008, 04:11 PM   #7
V8Slayer
Member#: 111565
1999 Legacy 2.5GT
2007 Legacy GT Spec-B
How can you fail an emissoins test if your car burns too clean?
V8Slayer is offline   Reply With Quote
Old 01-29-2008, 04:26 PM   #8
flstffxe
Member#: 155358
2008 Forester
Steel Silver
The car model rated for a given range on the results, if you are out side that range you fail. High or low it doesn't matter.
The short answer
Old 01-29-2008, 04:34 PM   #9
06njsti
Member#: 150986
06 #001 LSB STi
can someone please give me info about that. my dad owns a shop where i can test this theory if someone is willing to do some research about how the cars numbers should read with/without the acetone? also can i test this theory in my sti?
06njsti is offline   Reply With Quote
Old 01-29-2008, 04:52 PM   #10
V8Slayer
Member#: 111565
1999 Legacy 2.5GT
Thanks for the explination.Its short and sweet but i understand what your saying.
Old 01-29-2008, 04:58 PM   #11
nickscooby12
Member#: 112583
2006 Wrx
I have added about 3 shots for 10gals to my wrx and it has not hurt it, but i cant say my gas mileage has improved either. But with an 18g it spools fast and eats gas so its hard to tell.
On performance it may help but the timing on the car is conservative so without any more timing or being closer to the limit it does not seem to gain anymore. But idle seemed to be smoother.
My buddy in a z28 camaro said it seem to help him so it may help but not that significantly.
if you have a dyno it would be interesting to see what results you get. but i think the gains are so small that it will probably be overlooked.
if you want performance you probably want to go with meth
nickscooby12 is offline   Reply With Quote
Old 01-29-2008, 06:09 PM   #12
06njsti
Member#: 150986
06 #001 LSB STi
yea i plan on going with meth in the near future, but how about the acetone as far as passing emmission test catless
Old 01-29-2008, 06:52 PM   #13
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
Old 01-29-2008, 06:57 PM   #14
06njsti
Member#: 150986
06 #001 LSB STi
wow, im not sure what you said but it sounds like you know what your talking about. i have to find out if the emissions will work on a gas powered car, I know they work for trucks that run on diesel but if it will tell me the difference between acetone gas and regular it would be greatly appreciated. I plan on running catless for the rest of my sti's career and im trying to pass emissions in 1 year
Old 01-29-2008, 08:13 PM   #15
nickscooby12
Member#: 112583
2006 Wrx
sorry i dont know anything about emissions. I live in Florida and we dont have emissions testing and also get 93oct gas.
Old 01-29-2008, 09:34 PM   #16
neomax
Member#: 54585
2013 WRX
I did a lot of research into the area of adding acetone into gasoline. The theory has existed since around the mid 1940's, so it is definitely not a new idea, just one that won't die.
Fact: Injector cleaners you put into your gas are 99% acetone and 1% of some of their dyes w/e.
Fact: Adding acetone into your gas is basically just raising your octane level
Results have been all over the place. I added 4.5oz of acetone per complete tank, the car ran smoother and I received any where from 2-4 mpg better per tank. This was consistently over the course of several tanks before getting lazy and not doing it anymore, which then showed 2-4 mpg decrease. I calculate my mileage at every fill up. Theres a real good wiki on it out there, that people post their own results. YMMV just remember that.
Other uses is adding a table spoon of acetone to a push mower and it will run smoother, longer, and get rid of that black smoke it blows out some times.
***IF YOU ARE GOING TO ATTEMPT IT, USE A FUNNEL OR REUSE AN OLD INJECTOR CLEANER BOTTLE, ACETONE WILL REMOVE PAINT IF IT TOUCHES***
neomax is offline   Reply With Quote
Old 01-30-2008, 12:16 PM   #17
06njsti
Member#: 150986
06 #001 LSB STi
okay thanks, so your saying instead of running injector cleaner a little bit of acetone will do the same thing? also im gonna calculate my highway mileage now that i updated my v2 AP and it has a fuel economy mode i will find out how it does on like 50miles of pure gas then 50mile w/ acetone mix. or something along them lines. i will calculate it and get some numbers up for you guys.
Old 01-30-2008, 01:26 PM   #18
alejo
Member#: 170081
2004 2.5RS
blue
that's nice to know. I guess acetone is a little cheaper than injector cleaner. Do you happen to know how much acetone do you have to add per gallon? cheers, congratulations on the research
alejo is offline   Reply With Quote
Old 01-30-2008, 01:41 PM   #19
06njsti
Member#: 150986
06 #001 LSB STi
i think i read 3.5oz for every 10 gallons. however neomax put 4.5oz per tank
Old 01-30-2008, 02:41 PM   #20
neomax
Member#: 54585
2013 WRX
it's 3 oz per 10 gallons, however i was really empty when i filled up with about 14 gallons. Again its all about testing. Some people have found better results with 2oz/10gallons, but don't go much over 3oz/10gallons.
also to note, that you have to compensate the ratio, because you may only be putting 5 gallons in at a fill up but your still putting x amount of acetone into a 15.9 gallon tank. have fun.
Old 01-30-2008, 07:52 PM   #21
mikndee
Member#: 169433
2010 wrx
rally blue
Originally Posted by HamFist View Post
Oxytane has been behind that myth the entire time, and no one ever believes it.
It was one of the less recent examples of how a twisted myth is more pervasive than the source of its existence. I could tell you straight to your face the entire story behind the entire acetone rumor, and no one believes me outside of people that have used Oxytane and finally understand it.
So, we just kinda left it at that and went about our business. What's funny is how many people still try to debate specifically acetone in gas and not the source of the rumor. Even if you tell them, they still don't believe it. The absolute 180-degree, about-face of people's opinions who finally understand it gets me every time. I went through the same thing when I finally saw it with my own eyes. Getting to work with that stuff in blended ethanol fuel showed me things I never thought possible with fuels.
The answer isn't acetone. The answer lies at the root of the rumor.
are we searching for the holy grail in the last crusade or something? what a cryptic answer. i feel like if i find the answer, i'll live for a thousand years.
mikndee is offline   Reply With Quote
Old 01-30-2008, 09:23 PM   #22
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
The truth to the rumor isn't acetone. There's controversy over the results because people can't seem to duplicate the mystery they heard about.
"If there's never any survivors, then where do the stories come from?"
Old 01-30-2008, 10:42 PM   #23
Blase
Member#: 54702
2000 impreza 2.5rs
brp
e85 ftw
Blase is offline   Reply With Quote
Old 01-30-2008, 10:42 PM   #24
Blase
Member#: 54702
2000 impreza 2.5rs
brp
e85 ftw
Old 01-30-2008, 10:43 PM   #25
Blase
Member#: 54702
2000 impreza 2.5rs
brp
ahh whyd it go twice. sorry
Random find - thoughts on acetone in gasoline to improve gas mileage???? Disoriental Off-Topic 7 05-09-2008 06:05 PM
Acetone in Gasoline? eaglewrx Newbies & FAQs 17 03-20-2007 05:04 PM
Acetone in gas, up to 35% increase in MPG? drfrink24 General Community 24 11-18-2005 11:24 AM
A game of good idea, bad idea in the Phillippines wolf8314 Off-Topic 1 03-10-2005 06:41 AM
225 in rear, 215 in front? good/bad idea? Keirik Brakes, Steering & Suspension 24 01-29-2001 11:52 PM
