Old 01-29-2008, 02:34 PM   #1
acemyles2.5i
Member#: 151012
2007 impreza 2.5i
urban
Subaru Banner perrin water injection kit
is it worth it????
acemyles2.5i is offline   Reply With Quote
Old 01-29-2008, 03:11 PM   #2
V8Slayer
Member#: 111565
2007 Legacy Spec.B
324hp/313tq EVOIII 16G
What other mods do you plan on doing to your car?
V8Slayer is offline   Reply With Quote
Old 01-30-2008, 01:19 PM   #3
tigerrider11
Member#: 160350
1999 Impreza OBS
from what i know, water injection is most useful if used along with forced induction such as a turbo. Im not too sure what it would do, if anything on an N/A engine.
dont hold me to it though
tigerrider11 is offline   Reply With Quote
Old 01-30-2008, 01:32 PM   #4
imprexaRS03
Member#: 145883
2008 wrx
psm
no i know for a fact you can pull quite a bitof horsepower out of water injection,my grandpa put one in his old ford truck and it worked good!
imprexaRS03 is offline   Reply With Quote
Old 01-30-2008, 03:27 PM   #5
sc00ter
Member#: 117767
2015 WRX (CWP)
3" TBE | DT Flex Fuel
Interesting.....
I'd like to learn more about this.
sc00ter is offline   Reply With Quote
Old 01-30-2008, 03:44 PM   #6
V8Slayer
Member#: 111565
2007 Legacy Spec.B
From what i've read, you can use water/meth kits on na cars with good results but it won't be as dramatic as if you were using it on a turboed car. If you go to snowperformance's website there should be some info on the na kits and what you should expect from it. I've wanted to do this for quite some time but have never really gotten around to doing it.
Old 01-30-2008, 03:45 PM   #7
Chad W
Member#: 77975
2013 BRZ
Basically it would allow for radically advanced ignition timing that would cause detonation with out it. I don't think you can expect and reasonable gains without being tuned for it.
Chad W is offline   Reply With Quote
Old 01-30-2008, 07:45 PM   #8
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
I thought meth injection was used for radical advancement, water injection just lowers the temps so you can up advancement just a little more. Obviously, you'd want meth, not just water...
I can see meth/h20 injection great for upped compression, but not that much advancement.
but if you run out of meth or h20, your engine is kaboom if the compression is high.
formula91 is offline   Reply With Quote
Old 01-30-2008, 11:46 PM   #9
Chad W
Member#: 77975
2013 BRZ
"radical" not being a specific technical term, it is definitely fair to say that meth can do more than water, but don't underestimate the improvements of water alone.
As far as running out goes, it is dangerous and I would never recommend to use to compensate for any physical changes...a NA car can pull timing and a Turbo car can pull timing and boost (on sophisticated systems)...but high compression and superchargers can be a real problem when you run out of meth/h2o
Old 01-30-2008, 11:47 PM   #10
Chad W
Member#: 77975
2013 BRZ
AEM: Water Alcohol/Water Injection Kits $370 Shipped! No Limit Motorsport Engine/Power/Exhaust 10 09-14-2008 03:26 AM
Perrin water injection Kit $450 obo 02WRX2.5 NWIC Private Classifieds 0 08-24-2008 10:02 PM
FS: PA Perrin PWI-1 Water Injection Kit New! RelentlessWRX Engine/Power/Exhaust 3 11-18-2007 11:11 AM
Perrin alchy/water injection kits and Aquamist Kits in stock Dyno Flash Engine/Power/Exhaust 0 07-21-2007 10:26 PM
Water Injection kit group buy $275 + shipping WRXTuner Vendor 'Group Buy' Classifieds 107 10-22-2003 09:45 PM
