#1 |
Member#: 151996
while the car is at operating temp or cold? '05 sti
#2 |
Member#: 44034
NESIC
Vehicle:2006 Global Cooler Black |
I always check when cold especially cause that is when wear occurs the most.
I would check the owners manual. |
#3 |
Member#: 171031
South East
Vehicle:2004 Impreza WRX WRBlueee |
i would just doit when its cold to be on the safe side ;] .. my tranny oil is pretty low too .. lol.. maybe thats why my trannys funkeeed.
#4 |
Member#: 126684
Vehicle:02 wrx PLATINUM silver baby |
u should always check at operating temp, the fluid expands a little when it warms up so if u check it cold and add when it gets hot now ur over full. more so for an auto, but wouldnt be a bad idea for a man as well.
since this is a manual i dont see how there can be a lot of damage when cold since the gear oil get splashed around as soon as the car starts moving. theres no pump, valve body or torque converter the fluid has to make its way through like an auto. |
#5 |
Member#: 118209
Vehicle:2002 WRX Sedan |
nope, at least not ALWAYS. if the dipstick already takes into account cold fluid and is calibrated for it, checking it when warm will give you overinflated readings. Check the manual! If it doesn't specifically say warm then it more then likely is meant to be checked before it has warmed up.
| Thread Tools | |
| Display Modes | |
| Are you supposed to tip the room service people? | Fach | Off-Topic | 17 | 08-25-2004 11:51 PM |
| Is there an easier way to check the tranny fluid? | Hollidark | Transmission (AT/MT) & Driveline | 6 | 06-30-2004 12:38 PM |
| are you supposed to buy the boss a gift? | catass | Off-Topic | 34 | 12-15-2003 01:14 AM |
| How are you supposed to torque a fluid line? | Corn-Picker | Service & Maintenance | 5 | 01-02-2002 05:56 PM |
