Old 02-04-2002, 09:26 PM   #1
RedlineRex
Member#: 10291
2002 Impreza WRX
WR blue pearl
Default How to wet sand?
I've noticed that there are a couple of scratches on my car that can't be removed by scratch removers...so i thought i might wet sand it out. Does anybody have any idea which sand paper to use and any tips on how do a professional looking job wet sanding the scratches and blemishes out? Thanx.
RedlineRex is offline   Reply With Quote
Old 02-04-2002, 09:51 PM   #2
RedlineRex
Member#: 10291
2002 Impreza WRX
WR blue pearl
bump....?
Old 02-04-2002, 09:58 PM   #3
metal man
Member#: 11653
2002 wrx
blue perl metalic
furst clean the suffice with water and wipe it down with a dry cloth to remove any durt or sand that might scrach your pant worse. Then take some 2000 grit sand paper, wet the paper
and the surfice and than sand light not to sand thrue the clear
make a cople of passes and then check to see if the scrach is gone. If you drag your finger nail across the scrach and it hangs
it probebly will not buff out. so don't keep sanding. jest get it close and buff it out with some 3M microfinishing compound.
good luck
metal man is offline   Reply With Quote
Old 02-04-2002, 09:59 PM   #4
JBPolkAudio
Member#: 5025
2004 STi
Here's a tip -- don't do it! Unless you know what you're doing, you'll probably create more scratches.
There isn't any mystery, however, in wet sanding. You just take sand paper and dip it in water. The reason people wet sand is because the grit is so fine that when you are sanding, the paint gets into the grit and clogs up the sandpaper. If you really want to, go ahead -- use an extremely high grit (5k - 10k) to really get those fine scratches out.
~JB
JBPolkAudio is offline   Reply With Quote
Old 02-04-2002, 10:02 PM   #5
RedlineRex
Member#: 10291
2002 Impreza WRX
WR blue pearl
Thanx guys...really good advice Anyone else have any advice?
Old 02-04-2002, 10:09 PM   #6
Ghomer1
Member#: 8091
2007 335i
Monaco Blue Metallic
Does wet sanding help with the spots that I touched up with touch up paint? I noticed no matter how careful I am, I can never get the touch up paint to set right in the hole. I was thinking about wet sanding to smooth it out, but I am wondering if it will cause the spot to show more because of the scratch marks. Did that make any sense at all?
G
Ghomer1 is offline   Reply With Quote
Old 02-04-2002, 11:37 PM   #7
SONofSAM
Member#: 8407
Exclamation
can this be done on CF hood!!!
Cuz mine got scratch up really bad
SONofSAM is offline   Reply With Quote
Old 02-06-2002, 05:29 PM   #8
TortoiseAWD
Member#: 5223
2002 Impreza WRX
Silver Metallic
Please be very careful if you decide to go forward with wetsanding . . . the UV protection of your clearcoat is concentrated in the top several mils of the layer. If you sand through that, the basecoat may start to fade or check, and the only fix then is a repaint. You might try searching the forums at http://autopia-carport.com (detailing forum); there have been some good posts there re: wet-sanding and the associated dangers.
Good luck,
Tort
TortoiseAWD is offline   Reply With Quote
How to Clean MAF 02 WRX RdRx02 Newbies & FAQs 10 06-02-2010 10:05 PM
So i need some headlights to be wet sanded and buffed knighter Mid Atlantic Impreza Club -- MAIC 6 12-18-2009 10:40 AM
had car wet sanded Chris Morgan Newbies & FAQs 7 01-16-2004 12:44 AM
Wet sanding and buffing subieworx Interior & Exterior Modification 12 01-14-2004 10:53 AM
wet sanding? krzyxkrean Legacy Forum 6 11-17-2003 01:02 AM
