Old 01-30-2008, 06:04 PM   #1
tkvtec
Member#: 120024
2000 2.5 RS, '02 WRX
Sedona Red Pearl, PSM
Default Replacing a few parts, but have some ?'s
I have 96k miles on the car (I have a 2000 2.5RS, so a SOHC EJ25), I auto-x it regularly and want to get some things taken care of before the season starts.
I am looking at doing a few things very soon.
-Timing Belt
-Clutch/Flywheel
-LSD front Diff (OBX)
I've done some searching and read about a bunch of other things I'd like to replace while I'm in there. I've looked into sourcing the parts, but have run into a few questions.
Things to replace along with the timing belt:
-Cam Seals
-Front Main seal
-Water Pump and seal
-Thermostat and gasket - started sticking
-Thermostat housing - Is this something I should replace?
-Idler pulleys - How many are there? (Smooth, Cogged)
What type are they? (I've found single style bearing and double style bearing, and smooth rollers and also cogged rollers)
-Tensioner - Hydraulic or not?
Things to do when replacing the diff/clutch/flywheel:
-Rear main seal
-release and pilot bearings
-new seals for the axle stubs
-front diff carrier bearings - need to be pressed on the diff? Will this actually require a machine press?
Would a new input shaft bearing would be a good idea?
What about center diff carrier bearings?
I also have a small leak from the Steering rack coming from the control valve area...
Does anyone have any experience replacing/repairing a steering rack, in part or in whole? Could it possibly just be seals that need replaced?
Will definitely do the steering rack bushings while I'm in there
Any help is greatly appreciated
Oh yeah, part #'s and quantity needed for all parts welcome
tkvtec is offline   Reply With Quote
Have some ??'s on doing the rs to wrx swap yukon1 Alaskan Impreza Club Forum -- AKIC 20 05-27-2005 01:03 AM
turbo upgrade time but 1st some?'s RIGGS-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 09-16-2004 11:08 AM
anyone using the apexi avc-r? have some ?'s SWEETWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-18-2002 11:20 PM
Possible Impreza purchase, have some ?'s, need some help. STi2001 Normally Aspirated with bolt-on Forced Induction Powertrain 4 10-14-2001 11:10 PM
I have some ?'s FlyinSI Mid Atlantic Impreza Club -- MAIC 3 04-04-2001 02:46 PM
