Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 02-23-2008, 07:59 PM   #1
RideZX-6R
Member#: 134816
Default Who makes a EWG kit ofr the VF39 that re-connects into the downpipe?
I'm looking for a complete kit that will allow the EWG setup to re-enter the exhaust stream in the downpipe. I'd like to go EWG for the spool/power/response but don't want that wastegate dumping sound.
I know Helix and Grimmspeed both make kits but from what I've seen, neither have a downpipe with the kit that will connect the WG to them. So do I have to cut and weld or what?
RideZX-6R is offline   Reply With Quote
Old 02-23-2008, 08:09 PM   #2
jflexe99
Member#: 145303
2007 WRX TR
Crystal Metalic
F the EWG setup. Do what I am going to do, throw in some meth injection, will do WAY more
But I don't know any off the top of my head...most are atmospheric.
jflexe99 is offline   Reply With Quote
Old 02-23-2008, 08:11 PM   #3
RideZX-6R
Member#: 134816
I figured more is better so I planned on doing meth as well as the EWG
Old 02-23-2008, 08:13 PM   #4
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
Sorry man thats a custom request. Anyone that makes a turbo kit with Up/Down will , accommodate your needs, I should say any good vendor will. Your going to get more than if you kept IWG . I myself like the idea of plumbing back in but the gains are far less than 100% EWG.
Your missing his reasoning all you n0bs just tossing on a MEth kit in the blink of an eye.
4ST-AIR is offline   Reply With Quote
Old 02-23-2008, 08:15 PM   #5
RideZX-6R
Member#: 134816
So is it worth doing EWG at all if I'm going to plumb it back into the DP?
Old 02-23-2008, 08:21 PM   #6
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
Yes if you hate the raspy EWG as I do plumb it back in keep a big Spearco TMIC and you'll get the spool. You might want to kick the 39 for a 20G though you will love it.
Old 02-23-2008, 08:23 PM   #7
RideZX-6R
Member#: 134816
I'm thinking of kicking the 39 for a Dom 3.0R .... but not for a year or more.
So I just wanna maximize the 39 for now.
Old 02-23-2008, 09:28 PM   #8
jflexe99
Member#: 145303
2007 WRX TR
Crystal Metalic
I was going to grab a 20g...but for the price n all, I think the vf39 with meth inject will do just fine
Turbo is cheap to replace if anything happens. don't have to worry bout injectors and EWG setup
Only thing is 39 runs out of steam up top. But it will be GREAT for what I want, the corners
Old 02-23-2008, 09:30 PM   #9
RideZX-6R
Member#: 134816
I agree with this train of thought - lots of mid-range, as my car will be a lot of Auto-X and HPDE but first and foremost will be a STREET CAR/DD.
So I'll take mid-range on the VF39, over a big turbo with a little less mid but more top-end.
Old 02-23-2008, 09:57 PM   #10
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
You're in Allentown?? just have Area1320 do the recirc of the ewg
dangerousatom is offline   Reply With Quote
Old 02-23-2008, 10:47 PM   #11
akturbogti
Member#: 119474
05 Hummer H2
black
Grimmspeed makes an ewg uppipe that you can choose a ihi bracket for.
akturbogti is offline   Reply With Quote
Old 02-23-2008, 11:24 PM   #12
dangerousatom
Member#: 70710
Well like DUH! AREA1320 makes the brackets for Grimmspeed
Old 02-23-2008, 11:58 PM   #13
STIBungy
Member#: 51684
Uhhh, Helix does.
STIBungy is offline   Reply With Quote
Old 02-24-2008, 12:26 AM   #14
novacivic
Member#: 117980
2005 sti
wr blue
+1 for the helix
novacivic is offline   Reply With Quote
Old 02-24-2008, 12:27 AM   #15
Davenow
Member#: 23676
You want to re route it back in as far away from the turbo outlet as possible. You dont want it dumping back into the downpipe 6-8" from the turbo. You lose 90% of the gains of an EWG when you do that, leaving you with little more than (much) better boost control.
One of the big ways an EWG helps you make power by effectively reducing post turbo backpressure by reducing the volume of exh gasses that have to make their way through that pipe. When you route it back into that pipe, you lose most of that gain, and worse, you cause huge turbulance where it comes back in, which is aweful for flow, which also reduces the gains and effectively raises backpressure. This is why you want to put it back in further down the pipe, and at a very gentle angle.
Pick up a copy of "Maximum Boost" by Corky Bell, it goes into great detail why routing an EWG back into the exh is a bad idea, and how to minimize the negative affects if you have to do it.
Suffice it to say that routing it back in, that close to the turbo, and at a 90 deg angle, is the worst possible way you can do it. Seriously, Its an aweful design. Even moving that entrance 6" further down the pipe, and bringing it in at a 45deg angle would be 10 times better for flow. Best case scenario you would want it re-joining 24-30" down the pipe at a very gentle angle.
Davenow is offline   Reply With Quote
Old 02-24-2008, 01:43 AM   #16
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
Just go buy a "Twin Dump" dumppipe (x-force, ces, etc) that has a separate pipe for the wastegate gasses that joins back in at the end of the dump pipe.
Then modify it - cut shut the top where it joins the flange and join your ewg outlet pipe closer to where the "twin dump" wastegate pipe joins back in to the dump pipe. It should be a simple mod for an exhaust shop or a few hours job for a home modder with good welding experience.
It is much easier to understand what I mean when you see a pic of a "twin-dump" dump pipe - the following image is of the CES "twin-dump" dump pipe. The x-force is separated even further, but I could not find a pic on the net.
wrxsti.l is offline   Reply With Quote
Old 02-24-2008, 02:34 AM   #17
Davenow
Member#: 23676
THAT would actually really work well. By the time you do that work you could have just done the same to an HKS downpipe and a normal EWG setup.
But that pic shows exactly how the re-routing should be done. Far enough down the pipe, and a great angle.
Old 02-24-2008, 02:58 PM   #18
deebee8
Member#: 85437
2002 Wrx
Land of the dead
sorry, that wouldnt work well at all.
take your turbo out and look at the direction your wastegate will be opening up.
DIRECTLY INTO THE DIVERTER FLANGE. = no good
Your wastegate never actually fully opens. Thus your not going to get the same effect as a true EWG or even Bellmouth for that matter.
deebee8 is offline   Reply With Quote
Old 02-24-2008, 03:39 PM   #19
serendipity
Member#: 54597
08 'Busa, 08 ML63
10 Multistrada, 996 Targa
Clearly that went over your head. They're talking about taking that downpipe and modifying it so that your EWG plumbs into the divorced tube.
I'm with Davenow, though - that's not going to save you much time or effort over just plumbing your EWG into some other (cheaper) non-divorced downpipe.
serendipity is offline   Reply With Quote
Old 02-24-2008, 03:49 PM   #20
kb2spn
Member#: 28897
2004 STOLEN WRX STI
Blue/Gold
http://www.harmanmotive.com/catalog/...oducts_id=1064
kb2spn is offline   Reply With Quote
Old 02-24-2008, 03:52 PM   #21
deebee8
Member#: 85437
2002 Wrx
Land of the dead
Ahh, i see your point of view.
I think it would be way cheaper to buy an HKS downpipe, and mod it to have flange coming off it for the EWG.
Old 02-24-2008, 05:10 PM   #22
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
Buy any EWG up pipe
Buy an HKS downpipe
Have them make the dump tube go down to the bottom of the downpipe and route back in like the twin pipe in the pic above. That would be the best way. (obviously you could also just mod your own up pipe to go with the EWG instead of buying one)
Shouldnt even cost that much other than the EWG itself (those are expensive little buggers!)
The main point is to NOT route it back in right after the turbo, especially at the 90deg angle all those kits do it with.
And you would be suprised, those twin dump downpipe actually work ok. Not really any better or worse than a bellmouth though.
Heck, the HKS downpipe performs 90% equal to the best bellmouth DP out there. True story, seen it lots of times.
Defiant Autospeed is offline   Reply With Quote
Old 02-24-2008, 05:20 PM   #23
07EJ255
Member#: 133823
07 STI
WHITE
just buy the ewg/up-pipe combo with dump tube from grimmspeed and call it a day. For $570 i think its totally worth it. Im ordering that setup at the end of the week for my STI. Im going to be running that setup on the VF-39 + aps 3.5" turboback, prodrive BCS and accesport, car is going to be a beast. Have plans for more mods in the future but for the money i thinks its totally worth it
07EJ255 is offline   Reply With Quote
Old 02-24-2008, 06:31 PM   #24
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
That kit doesnt route back into the downpipe, which is what the OP wants.
Old 02-24-2008, 09:54 PM   #25
irascible
Member#: 159454
2006 WRX CGM
6SPD Cornfed GT30R
Originally Posted by kb2spn View Post
that kit is crap... you'd get better performance out of a stock setup. It's design is everything you DONT want to do with an EWG setup.
irascible is offline   Reply With Quote
Who makes 44mm EWG atmo UPs? verc Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 12-31-2007 01:46 PM
who makes a ewg up pipe for a 06 wrx ? devil doc Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 02-11-2006 02:03 AM
Can the MRT center pipe connect to the OEM downpipe macboat Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 05-04-2003 02:56 PM
who makes WRX body kits? FLUBYUx2 Interior & Exterior Modification 2 11-02-2001 11:29 PM
Anyone know who Makes this Body Kit? Dre2932 Interior & Exterior Modification 11 12-06-2000 12:40 AM
