Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 02-12-2008, 11:57 AM   #251
xswrex
Member#: 87255
2002 Impreza WRX
given up emptying PMs...
Originally Posted by turboge View Post
Are those JDM roms 32-bit?
Also is there any way you could do a patch for A4SE700I? It's 2001/2002 ADM WRX.
nope, they are 16bit JDM roms
A4SE700I can be done, no prob. Email that ROM!
xswrex is offline   Reply With Quote
Old 02-12-2008, 12:03 PM   #252
xswrex
Member#: 87255
2002 Impreza WRX
Originally Posted by AruisDante View Post
Nope. Neither converts to the other in any base between binary to hex (IE Ternary, Quadrinary, Octal, etc). The only thing I can think of is that one is displaying the pointer to the address that the RPM detla is stored to, rather then the actual value.
dont waste too many brain cells thinking about this so hard now will ya
Old 02-12-2008, 12:09 PM   #253
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
Originally Posted by xswrex View Post
failed the XML exam
just a small typo mistake in the func_2val & func_val2 attributes, i put them the other way around
use this
Code:
<map name="LC RPM delta" type="1" active="1" help="" class="tinywrex patches" map_struct="" level="0">
			<data count="1" offset="#?????" storagetype="uint16" func_2val="[value]/5.12" func_val2="[value]*5.12" format="%.0f" metric="" caption="" desc="" inc="1" incb="5" incdata="0" incdatab="0" inc_dir="1" cols="1" view="num" color_dir="1"/>
		</map>
forgot to ask...did you change the "offset=#?????" to the correct addresses?
I was so excited that I didn't even bother reading the code, so the offset is still = #?????"
I corrected them according to the patched xml addresses from ecuflash xml
Hyper is offline   Reply With Quote
Old 02-14-2008, 08:28 AM   #254
xswrex
Member#: 87255
2002 Impreza WRX
i have a problem with my dev system, should be back in a couple of days
http://tinywrex.wordpress.com/2008/0...5-hard-drives/
Old 02-15-2008, 02:52 PM   #255
SubieStylez
Member#: 98709
2005 Impreza WRX 18g
EWG + Meth
So I followed all the steps on tinywrex, changed to 192k file and all that but the values that came up weren't 0 like the directions said they should be.. I dont think I did anything wrong installing everything. Anyone know what it could be?
SubieStylez is offline   Reply With Quote
Old 02-15-2008, 03:55 PM   #256
AruisDante
Member#: 122365
2015 WRX STI Limited
Ice Silver
Curses, you lost work on the 32bit ECU's? That's a shame
I'm curious, since the 32bit ECU's monitor the clutch switch, are you going to implement FFS on them?
AruisDante is offline   Reply With Quote
Old 02-15-2008, 04:16 PM   #257
fujiillin
Member#: 171344
2006 STi Wagon
Black HTA Green
+1
The current method of manipulating the throttle table works, but a rev limit activated by the clutch switch and exceeding the speed threshold would be ideal, and wouldn't require much coding at all.
fujiillin is offline   Reply With Quote
Old 02-15-2008, 06:04 PM   #258
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
Originally Posted by fujiillin View Post
... and wouldn't require much coding at all.
you say that almost like you have the faintest idea of what you're talking about.
Old 02-15-2008, 07:24 PM   #259
AruisDante
Member#: 122365
Ice Silver
I think he means relative to just adding in LC. It would really only require another 'if' section that would check if speed is above threshhold and clutch is pressed, use the FFS limit rather then the LC threshold.
I don't know how the ECU's opcodes, but it wouldn't require more then (assuming there's a Subtract command, nzp registers and 6 general pupose registers)
code :LDR R1, RevLimitLC ; Load R1 with Rev Limit for LC
:LDR R2, Speed ; Load R2 with current Speed
:LDR R3, Threshold ; Load R3 with the speed threshold
:LDR R4, ClutchSwitch ; Load R4 with the current state of the clutch switch, assumes 1 is pressed, 0 is not pressed
:LDR R5, RevLimitFFS ; Load R5 with the Rev Limit for FFS
:SUB R3, R2, R6 ; Subtract Threshold from Speed
:BRp FFS ; If speed is greater then Threshold, branch to FFS code
:Normal LC Code Here
FFS :SUBI R4, #1, R6 ; Test to see if cluctch is depressed
:BRn FFS ; Clutch is not pressed, loop back (to wherever it would need to go)
:Put FFS Rev Limit Code Here
That's about all it would need. But that's using totally made up op codes, so the 32bit ECU may not work like that at all, I honestly didn't look at it. And it assumes you can store easy pointers to the addresses of the info you need, AND that there are 6 general purpose registers, a rareity in the 32bit processors.
Old 02-15-2008, 08:06 PM   #260
fujiillin
Member#: 171344
2006 STi Wagon
Black HTA Green
I'm in the process of disassembling my own rom to diy if I can find the time..
For xswrex, it would be a walk in the park since it looks like he's damn good at disassembly, following the ecu logic, and obviously coding.
I wasn't demanding anything, just a friendly suggestion.
Old 02-17-2008, 12:39 AM   #261
minerva1856
Member#: 79000
Ver8 EJ207
Where do I paste
<table name="LC disable speed(KMH)threshold" category="tinywrex patches" address="2D2D0" type="1D" level="1" scaling="VehicleSpeed(KMH)"/>
<table name="LC disable speed(MPH)threshold" category="tinywrex patches" address="2D2D0" type="1D" level="1" scaling="VehicleSpeed(MPH)"/>
<table name="LC RPM delta" category="tinywrex patches" address="2D2D2" type="1D" level="1" scaling="EngineSpeed(RPM)"/>
within ecu_defs.xml so that I may edit and view patched ecu's within Romraider? In this case A4SGE01C is my ID
Thanks
minerva1856 is offline   Reply With Quote
Old 02-17-2008, 12:48 PM   #262
Rogan
Member#: 142133
3 Jeeps
And a Saab
can a 160k rom be changed to 192k? if so, how?
Rogan is offline   Reply With Quote
Old 02-17-2008, 12:50 PM   #263
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
ecuedit will do it. Just download the trial. Go file->Convert->160-192
06rexwagon is offline   Reply With Quote
Old 02-17-2008, 01:16 PM   #264
Nuke209
Member#: 108089
2003 WRX
NF Performance
Originally Posted by minerva1856 View Post
Where do I paste
Thanks
It's a little more complicated than that for Enginuity
When I have some time tonight, I'll pm u
Nuke209 is offline   Reply With Quote
Old 02-17-2008, 05:43 PM   #265
minerva1856
Member#: 79000
Ver8 EJ207
Thanks I appreciate it.
Old 02-17-2008, 10:01 PM   #266
SubieStylez
Member#: 98709
EWG + Meth
So nobody knows?
Old 02-18-2008, 04:07 AM   #267
xswrex
Member#: 87255
2002 Impreza WRX
patches released
A4TE001I ADM WRX MY03
A4RM100G ADM STI MY03
A4SD900B JDM STI MY01-02
Old 02-18-2008, 04:12 AM   #268
Nuke209
Member#: 108089
2003 WRX
NF Performance
*whistles while waiting for the 32bit*
Old 02-18-2008, 08:38 AM   #269
xswrex
Member#: 87255
2002 Impreza WRX
patches released
A4TE002B JDM STi MY03
A4TE002C JDM STi MY03
Old 02-18-2008, 08:40 AM   #270
xswrex
Member#: 87255
2002 Impreza WRX
So nobody knows?
all i know is that if you follow the instructions it works!
Old 02-18-2008, 04:44 PM   #271
Spec V to Wagon
Member#: 129715
03 Wagon
Here is my 03 Wagon with Open Source Launch Control
Currently set at a low 3600
Spec V to Wagon is offline   Reply With Quote
Old 02-18-2008, 04:56 PM   #272
wuuusaa
Member#: 92894
2015 Wrx
+1
please hurry up
Old 02-18-2008, 06:02 PM   #273
Sko
Member#: 90396
2005 Legacy 2.5i
Brilliant Silver Metallic
Should do a vid watching your boost gauge ^_^
Sko is offline   Reply With Quote
Old 02-19-2008, 01:33 AM   #274
mickeyd2005
Member#: 122595
2005 LGT Wagon
ABP
Bump for some good work by xswrex.
mickeyd2005 is offline   Reply With Quote
Old 02-19-2008, 05:01 AM   #275
xswrex
Member#: 87255
2002 Impreza WRX
patch released
A4SD900A JDM WRX MY01-02
Launch Control on 2004 WRX Doomsti AccessPort 18 11-16-2012 03:16 PM
Launch Control on 32bit ECU Nuke209 Open Source Reflashes 126 05-17-2008 10:49 AM
Help with wiring in launch control on an 05 WRX. Sir Wagon UTEC 2 03-07-2008 04:45 PM
Failed NY state Inspection because of Launch Control on UTEC? vipernj Engine Management & Tuning 2 01-24-2006 06:10 PM
utec remote switch launch control on 4eat topgrinder Engine Management & Tuning 1 03-27-2003 08:34 PM
