Old 02-22-2008, 08:39 PM   #301
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
Originally Posted by xswrex View Post
WOOHOOO!
06rexwagon is offline   Reply With Quote
Old 02-22-2008, 11:08 PM   #302
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
I'm OK with not-free, so long as it's not-expensive.
I thought up a couple feature requests:
1) When cruise control is active, the accel/decel switches adjust the cruise speed, same as usual.
When cruise control is inactive, the accel/decel switches adjust the LC RPM.
2) Going a step further, you could hijack the cruise control enable button. It's useless, just have cruise control enabled all the time. My old BMW worked this way, it seemed weird at first, but now it seems silly to have an on/off switch for something that already has three ways to turn it off and two ways to turn it on. Pressing the cruise button could then be used to set the LC speed threshold, or something like that.
Old 02-23-2008, 12:16 AM   #303
Member#: 82064
2011 sti & evo ix
white
awesome work, lmk when it becomes available ill pay whatever for it
Ray@revitup is offline   Reply With Quote
Old 02-23-2008, 07:24 AM   #304
wuuusaa
Member#: 92894
2015 Wrx
sent pm xswrex
Old 02-23-2008, 09:13 AM   #305
xswrex
Member#: 87255
2002 Impreza WRX
given up emptying PMs...
IF it's going to have a price, it won't be expensive
and please oh please stop thinking!
xswrex is offline   Reply With Quote
Old 02-23-2008, 05:33 PM   #306
AruisDante
Member#: 122365
2015 WRX STI Limited
Ice Silver
When we say not expencive, are we talking over $20 or under?
AruisDante is offline   Reply With Quote
Old 02-23-2008, 06:20 PM   #307
Forsfed25
Member#: 135046
05 STi
Blue/Gold NEAWD.com
Say's your working on an 04 USDM STi rom as your first 32bit ecu prototype... If I'm not mistaken thats a 16bit ECU... The 05+ USDM STI ECU's are definatly 32bit though. I cant wait, thanks man.
Forsfed25 is offline   Reply With Quote
Old 02-23-2008, 06:24 PM   #308
06rexwagon
Member#: 114730
[email protected]
All USDM STi's are 32 bit.
Old 02-23-2008, 09:36 PM   #309
NSFW
Member#: 140444
05 Stage Free LGT
That good to hear.
Sorry though, it's a curse, I'm stuck with it.
Old 02-23-2008, 09:55 PM   #310
AruisDante
Member#: 122365
Ice Silver
I'm curious, are you attempting to implement FFS in the 32bit ECU's since they can see the clutch switch, or are you just sticking with launch control?
Old 02-23-2008, 10:23 PM   #311
mickeyd2005
Member#: 122595
2005 LGT Wagon
ABP
I think you can already implement FFS with some modifications of the tables.
mickeyd2005 is offline   Reply With Quote
Old 02-23-2008, 10:34 PM   #312
AruisDante
Member#: 122365
Ice Silver
You can, but it's TPS based and not very reliable. Having an acutal fuel/ignition cut between shifts is the proper way to implement FFS.
Old 02-23-2008, 10:49 PM   #313
NSFW
Member#: 140444
05 Stage Free LGT
Do tell... What mods to what tables?
Old 02-23-2008, 10:59 PM   #314
mickeyd2005
Member#: 122595
2005 LGT Wagon
ABP
The fuel cut control is there. You have to adjust your rev limit enable and disable and rev limit fuel resume boost.
The ignition cut is something a little more complicated, but you can implement it if you have a flattened DA table.
Actually, I wasn't thinking TPS. However, I do lower TPS as a soft rev limit. I think one tuner doesn't even lower it.
Old 02-24-2008, 04:07 PM   #315
bebeu
Member#: 43088
00 Impreza
Thumbs up
patches released
A4TE002B JDM STi MY03
A4TE002C JDM STi MY03
http://tinywrex.wordpress.com
Working very well on mine !
I set delta to 2500 in order to get a limit @ 5500 rpm
my car produce 0.4 bar !
Very good job m8 !
bebeu is offline   Reply With Quote
Old 02-24-2008, 04:56 PM   #316
crazymikie
Member#: 56321
2006 Honda El Camino
Green
I applied the patch A4SD900B patch and it works great! Thanks.
Has anyone experimented with how close to set the resume to the rev limit for best effect? I have my rev limit set to 8500/8400 RPM with a 3500 RPM delta. I'm wondering if trying something like 8500/8450 or 8500/8300 would be better.
I'll try to get a ideo later.
Mike
crazymikie is offline   Reply With Quote
Old 02-24-2008, 04:57 PM   #317
crazymikie
Member#: 56321
Green
I don't think it's possible without the ability to know whether or not the clutch is engaged.
Old 02-24-2008, 05:11 PM   #318
AruisDante
Member#: 122365
Ice Silver
Correct. There is no way to reliably know if a shift is in progess without a clutch switch monitor in the ECU.
Old 02-25-2008, 07:45 AM   #319
xswrex
Member#: 87255
2002 Impreza WRX
Default a new era begins...32bit LC is here
Old 02-25-2008, 12:12 PM   #320
NSFW
Member#: 140444
05 Stage Free LGT
Guys, we're hijacking xsrwex's thread here... MickeyD2005 has elaborated on the table mods over in the RomRaider forums, let's take this discussion over there.
And thank you xswrex for starting on the 32-bit stuff.
Old 02-25-2008, 01:31 PM   #321
AruisDante
Member#: 122365
Ice Silver
Gah, I need to get a hold of a tatrix cable
Did you implement it in the 32bit OS the same way you did in the 16bit, IE speed threshold based, or did you do it clutch switch based?
Old 02-25-2008, 03:57 PM   #322
xswrex
Member#: 87255
2002 Impreza WRX
for the moment it is implemented the same way as 16bit
Old 02-26-2008, 02:10 AM   #323
Benchmark Tuning
Member#: 154444
2008 08 STi, Typhoon
06 STi, 847-960-8676
I have a test car for that ROM...I will be getting in touch with you when I get back from out of town.
Benchmark Tuning is offline   Reply With Quote
Old 02-27-2008, 03:25 AM   #324
xswrex
Member#: 87255
2002 Impreza WRX
Old 03-03-2008, 09:34 AM   #325
2.5iSTI
Member#: 162585
2007 03 Evo w/2.3
Maybe I am missing it, but I cannot find the patch for the A4SG900C 02 WRX ecu or the 06 WRX A8DH201X. Any help is appreciated.
2.5iSTI is offline   Reply With Quote
Launch Control on 2004 WRX Doomsti AccessPort 18 11-16-2012 03:16 PM
Launch Control on 32bit ECU Nuke209 Open Source Reflashes 126 05-17-2008 10:49 AM
Help with wiring in launch control on an 05 WRX. Sir Wagon UTEC 2 03-07-2008 04:45 PM
Failed NY state Inspection because of Launch Control on UTEC? vipernj Engine Management & Tuning 2 01-24-2006 06:10 PM
utec remote switch launch control on 4eat topgrinder Engine Management & Tuning 1 03-27-2003 08:34 PM
