Old 10-19-2009, 10:25 PM   #701
YZrider103
Member#: 148669
I have tried patching this a number of ways but no matter what i cannot get it to patch. I keep getting the error "Command Line Arguments... I have tried the normal instructions and then i tried doing it through the windows command thing and still the same thing. there are no patches on the rom only an open source tune any ideas?
YZrider103 is offline   Reply With Quote
Old 10-20-2009, 12:15 PM   #702
quazimoto
Member#: 70395
What ECU?
quazimoto is offline   Reply With Quote
Old 10-20-2009, 01:57 PM   #703
xswrex
Member#: 87255
2002 Impreza WRX
given up emptying PMs...
most probably it is related to the filename. Remove any spaces from the rom filename and try again
xswrex is offline   Reply With Quote
Old 10-20-2009, 04:02 PM   #704
quazimoto
Member#: 70395
Need wastegate compensation per gear!!
Old 10-29-2009, 01:52 PM   #705
psmBoXer
Member#: 90354
2011 STI
XSWREX - trying to send you a PM, but your box is full.
psmBoXer is offline   Reply With Quote
Old 01-19-2010, 11:38 AM   #706
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
Most deff looking into this...
rexworx is offline   Reply With Quote
Old 01-24-2010, 04:01 PM   #707
Ralliart4
Member#: 135927
2002 Impreza WRX RA
bump this up
Ralliart4 is offline   Reply With Quote
Old 02-06-2010, 07:08 AM   #708
_MFB_
Member#: 219676
09 Forester XT
Steel Silver
HI,
Can you finish the table merchgod didnt release for ecuflash/romraider?
Per Gear Compensation for Requested Torque, MY 08 - 10
_MFB_ is offline   Reply With Quote
Old 02-13-2010, 10:39 AM   #709
wrx_navy
Member#: 224290
2013 WRX STI Sedan
Dark Grey Metallic
apparently website is down... any word on when it will be operational again? i want this patch
wrx_navy is offline   Reply With Quote
Old 02-14-2010, 07:30 PM   #710
Scracho
Member#: 220449
2004 WRB WRSTi Stg2
Cobb, Invidia, Fujitsubo
Its up again! Can't wait to get this installed...
Scracho is offline   Reply With Quote
Old 02-15-2010, 02:15 PM   #711
bmw50021
Member#: 122393
02 WRX
THIS ^^^^^^^ +tenthousandbilliontrillion
bmw50021 is offline   Reply With Quote
Old 02-15-2010, 02:47 PM   #712
quazimoto
Member#: 70395
No fair the JDM 16 bits have it
Old 02-15-2010, 03:34 PM   #713
elevenpoint7five
Member#: 187798
04 2 liters of
AWESOME!
So flash a JDM ROM
Andy
elevenpoint7five is offline   Reply With Quote
Old 02-15-2010, 08:37 PM   #714
quazimoto
Member#: 70395
Don't want to deal with the AVCS DTC headache .
Old 02-15-2010, 09:40 PM   #715
Scracho
Member#: 220449
2004 WRB WRSTi Stg2
Care to elaborate on this?
Old 02-16-2010, 04:28 AM   #716
Tommi300
Member#: 238537
I get the theory behind the launch control by lowering the rev limit, this inturn cuts the fuel supply, is there any chance it could potentially damage the fuel pump? this combined with the 32bit flat foot shifting ie the same theory would that potentially cause fuel pump failures?
Does anyone reduce timing in the area's where LC and FFS sit ie 5500 across the load range?
just wanted to pose the question before i jump in and install it.
Cheers
Tommi300
Tommi300 is offline   Reply With Quote
Old 02-16-2010, 07:15 AM   #717
quazimoto
Member#: 70395
I will try to explain it. Basiclly because of the way the boost tables are set up the same wastegate duty cycle is applied regardless of gear/load. Boost is load dependent and 4th and 5th gear can apply higher loads sooner than say 1st or 2nd. For the most part,depending on tuning,boost control system and turbo,you generally will never hit max boost in 1st or 2nd. Subaru tunes the cars for 5th gear max boost. Most tuners tune for 3rd gear max boost so you see overboosting in 4th and 5th gear. Wastegate compensation per gear allows you to use different duty cycles depending on gear. Alot of wasgate duty cycle 1st and 2nd gets you much quicker spool and higher boost while less in 4th and 5th keep you from overboosting. It allows you to tune boost for each gear instead of just one gear.
Old 02-17-2010, 07:08 AM   #718
Tommi300
Member#: 238537
Cheers
Tommi300
Can anyone add any info for me pls?
Old 04-12-2010, 05:50 PM   #719
jet8300
Member#: 115844
02 WRX
99 Forester
I've been scouring the interwebs trying to find a way to get a hold of this patch. Seems as though the website is down?
jet8300 is offline   Reply With Quote
Old 04-12-2010, 07:10 PM   #720
elevenpoint7five
Member#: 187798
04 2 liters of
AWESOME!
I usually pull a few degrees for LC, but haven't done much with FFS so I wouldn't know.
I may have a copy of one if you let me know what ROM you need. The site is down more than it is up and it's really aggravating!
Andy
Old 04-12-2010, 09:55 PM   #721
420WRX
Member#: 27752
2004 WRX+Ver.8 EJ207
Yeah I had this working for an 04 USDM WRX .. Should still have the files around?
420WRX is offline   Reply With Quote
Old 05-17-2010, 09:40 AM   #722
Rabidbyte
Member#: 36039
2001 Impreza 2.5RS
Site is down again. Is this project done?
-G
Rabidbyte is offline   Reply With Quote
Old 05-17-2010, 10:33 AM   #723
elevenpoint7five
Member#: 187798
04 2 liters of
AWESOME!
His site is down every other day it seems. I have all of the free ones saved, if you need something shoot me a PM.
Andy
Old 05-18-2010, 04:38 PM   #724
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
So wait... is the Need wastegate compensation per gear available?
BeBop86 is offline   Reply With Quote
Old 05-19-2010, 12:12 AM   #725
Gamble_WRX
Member#: 234783
2004 STi
omg i dont understand, i downloaded it, and tried to patch it using the batch file and it says its no for my car, and yet the file name is the same as my ECU internal ID.
please someone with more experiance with this. help me. i really want this to work and dont want to spend 500$ on an accessport. i like my cable and laptop.
please pm me with any info.
Gamble_WRX is offline   Reply With Quote
Launch Control on 2004 WRX Doomsti AccessPort 18 11-16-2012 03:16 PM
Launch Control on 32bit ECU Nuke209 Open Source Reflashes 126 05-17-2008 10:49 AM
Help with wiring in launch control on an 05 WRX. Sir Wagon UTEC 2 03-07-2008 04:45 PM
Failed NY state Inspection because of Launch Control on UTEC? vipernj Engine Management & Tuning 2 01-24-2006 06:10 PM
utec remote switch launch control on 4eat topgrinder Engine Management & Tuning 1 03-27-2003 08:34 PM
