Welcome to the North American Subaru Impreza Owners Club Friday July 25, 2014
Old 10-22-2010, 05:29 PM   #751
matt1990
Member#: 219238
Sedona Red Pearl
I changed the size patched the file and set the rev limit delta and mph but when I go to test the lc my car just goes to my normal red line can anyone help
matt1990 is offline   Reply With Quote
Old 10-22-2010, 06:34 PM   #752
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
How did you set the parameters?
Old 10-22-2010, 06:55 PM   #753
matt1990
Member#: 219238
Sedona Red Pearl
I meant to say that I set my the rev limit delta to 3000(7600 normal) and speed to 5 mph but it still doesn't activate
Old 10-22-2010, 07:25 PM   #754
Member#: 51961
2005 STi
2012 WRX
You were testing it with the clutch depressed right?
Old 10-22-2010, 07:44 PM   #755
matt1990
Member#: 219238
Sedona Red Pearl
Yes I was
Old 10-22-2010, 08:59 PM   #756
420WRX
Member#: 27752
2004 WRX+Ver.8 EJ207
Were you at a perfect stand still or is it possible the car thought it was over 5mph?
I set mine to 15 just to be safe.
EDIT: Wait.. 3k? .. Seriously? Rev your car to 3k and slip the clutch out.. what happens? Would you call that a good launch? See? It needs to be at least 4k or it'll just bog?
420WRX is offline   Reply With Quote
Old 10-22-2010, 09:29 PM   #757
matt1990
Member#: 219238
Sedona Red Pearl
No I set the launch at 5600 but in the launch speed delta it's 2000 cuz it says in the overview to subtract from normal red line which is 7600
So 7600-2000=5600
Old 10-22-2010, 09:49 PM   #758
420WRX
Member#: 27752
I think the last time I was stumped on why LC wouldn't work it was a faulty gear sensor?
I'd go warm the car up..
after a bit of driving, stop,
put the e-brake on,
push the clutch in,
put the car in first,
Floor it for a sec to see if rev limit kicks in.
If not, shift to neutral,
shift to reverse,
shift back to neutral,
shift into first,
You may find the sensor is loose or flaky?
Don't forget to take e-brake off if rev limit works and you wish to try it.
Old 10-22-2010, 10:39 PM   #759
matt1990
Member#: 219238
Sedona Red Pearl
alright thanks ill try this in the morning before i head out to evo wrx day
Old 10-23-2010, 04:16 AM   #760
cant-get-enofe-subie
Member#: 217219
03 wrx
black
need help when i double click the patch it come up source file is corrupt at byte 0x2c040 (0xff expected, 0xc found... anyone know what is wrong or can help me
cant-get-enofe-subie is offline   Reply With Quote
Old 10-25-2010, 02:00 AM   #761
Member#: 217219
03 wrx
black
anyone willing to do this for me i would be greatful... been trying for weeks to figure this out and no one has helped me
Old 11-19-2010, 10:53 PM   #762
vaj
Member#: 59136
04/5 APRWidebody STi
EQ Tuned - Green/Meth
I just posted a similar question for my 32 bit ecu. tinywrex will patch this for $10 on the ch-roms website if you want to send it to him.
vaj is offline   Reply With Quote
Old 01-09-2011, 12:28 PM   #763
jrrevo1
Member#: 242735
99 Dodge Ram 2500
WRX totaled 6/25/12
ok so i have been fiddling around with this here and there for a few months and i keep coming up with the same problem.
i have a copy of my rom which is at 192k at a .hex extension and a copy of my .xml file as well. i go and run everything and all i get is the box above. i cant do anything from there with anything. i can paste in the data into the .xml and then open eculfash and its there but i get all the boxes with values in them other than zero.
any ideas?
jrrevo1 is offline   Reply With Quote
Old 01-09-2011, 02:03 PM   #764
Member#: 51961
2005 STi
2012 WRX
It doesn't look like you're running the patcher correctly.
Open the command window, navigate to the directory, and run:
TinyPatcher.exe [file] patch.dif
Old 01-09-2011, 02:11 PM   #765
jrrevo1
Member#: 242735
99 Dodge Ram 2500
WRX totaled 6/25/12
but when it says press any key to continue it just closes the cmd box all together.....
or i get the error saying do not modify executable file name....
Old 01-09-2011, 06:07 PM   #766
quazimoto
Member#: 70395
Read the frigg'en thread/directions people. The file/ROM must named after the ROM ID. This will not work if the ROM is named "stupidstage2.hex"
quazimoto is offline   Reply With Quote
Old 01-09-2011, 06:40 PM   #767
Member#: 51961
2005 STi
2012 WRX
Because you're not running the command window, you're just double clicking the executable.
Start > Run > cmd
Old 01-09-2011, 08:37 PM   #768
jrrevo1
Member#: 242735
99 Dodge Ram 2500
WRX totaled 6/25/12
what the heck crawled up your butt? why dont you try to actually contribute to something here rather than complain about everything, as you seem to do with any of my tuning questions i have posted????
and yes i did rename it to the rom id of a4sgd10c.hex and it was 192k and i still get the error saying do not modify executable file name.
this is what is typed in after the directory was changed:
c:\documents and settings\administrator\desktop\lca4sgd10c>tinypatc her.exe [a4sgd10c.hex] patch.dif
and i get the above error...?
Old 01-09-2011, 09:19 PM   #769
jrrevo1
Member#: 242735
99 Dodge Ram 2500
WRX totaled 6/25/12
ok so i did some more reading and found that if your rom was an ap map that the tinywrex patch wont work is this correct? i am the third owner of this car so i have no idea what the previous owners did via tune oe what was tuned with. i have now since downloaded a stock a4sgd10c rom from scoobypedia and the patch worked the first time. any ideas?
Old 01-09-2011, 10:42 PM   #770
Member#: 51961
2005 STi
2012 WRX
Copy the tables from the old map to the patched stocker one by one. It sounds painful, but only takes a few minutes.
Old 01-09-2011, 11:04 PM   #771
jrrevo1
Member#: 242735
99 Dodge Ram 2500
WRX totaled 6/25/12
yes now that i got it to work thats what im working on now.
but does anyone have any more information about the the whole ap thing if its true or not?
Old 01-09-2011, 11:35 PM   #772
Member#: 51961
2005 STi
2012 WRX
It is, I wasn't able to patch my AP stage 2 map that I pulled off of the ECU with ECUflash. Had to patch a stocker and copy my tables in.
Old 03-17-2011, 09:08 PM   #773
02MillzRex
Member#: 206359
2005 WRX
CGM
Will the lc work on a Cobb stage 2 05 wrx?
02MillzRex is offline   Reply With Quote
Old 07-07-2011, 05:17 PM   #774
Redmed427
Member#: 254409
2011 WRX 5-door
LR
Could someone with more knowledge than me please let me know which ecu id patch i need to use for my 2011 wrx? It would be greatly appreciated
*EDIT* It seems there arent any '11 wrx patches available. Im going to see if i can work with him to make one!
Redmed427 is offline   Reply With Quote
Old 07-07-2011, 06:48 PM   #775
Member#: 51961
2005 STi
2012 WRX
Pull the map off of your car and open it in RomRaider or ECUFlash, it will tell you what the ID is.
Launch Control on 2004 WRX Doomsti AccessPort 18 11-16-2012 03:16 PM
Launch Control on 32bit ECU Nuke209 Open Source Reflashes 126 05-17-2008 10:49 AM
Help with wiring in launch control on an 05 WRX. Sir Wagon UTEC 2 03-07-2008 04:45 PM
Failed NY state Inspection because of Launch Control on UTEC? vipernj Engine Management & Tuning 2 01-24-2006 06:10 PM
utec remote switch launch control on 4eat topgrinder Engine Management & Tuning 1 03-27-2003 08:34 PM
