Welcome to the North American Subaru Impreza Owners Club Tuesday March 31, 2015
Old 07-07-2011, 08:41 PM   #776
Redmed427
Member#: 254409
2011 WRX 5-door
LR
Originally Posted by the suicidal eggroll View Post
Pull the map off of your car and open it in RomRaider or ECUFlash, it will tell you what the ID is.
AE5I910L, tinywrex doesnt have a patch for it yet. Only the 2011 sti
Redmed427 is offline   Reply With Quote
Old 09-06-2011, 05:09 PM   #777
Jbwagon05
Member#: 265045
2005 WRX Wagon
Ok so i followed all directions for my 05 wrx except when i copy and paste the .xml thing right before the </rom> and try and save it it just says "access is denied" any tips to help me with this please?
Thank you
Jackson
Jbwagon05 is offline   Reply With Quote
Old 09-06-2011, 05:24 PM   #778
djpast
Member#: 31016
05 WRX Wagon
Thank you
Jackson
Is EcuFlash open? If so, close it, then edit the file.
djpast is offline   Reply With Quote
Old 09-06-2011, 09:30 PM   #779
Member#: 51961
2005 STi
2012 WRX
Thank you
Jackson
You might need to copy the .xml file to your desktop, edit it there, then copy it back. Windows can get weird trying to edit a protected file in-place, but overwriting it is usually straight forward.
Old 09-08-2011, 04:30 AM   #780
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
For all those that may have missed the instructions on how to prepare your ROM for patching:
Originally Posted by wrxsti.l View Post
OK I found a FREE solution to convert ROM images from 160KB to 192KB.
ECUEdit used to be FREE - so older versions released FREE can be used to convert the ROM image size without having to worry about time trial running out. Download and use it as follows:
1. Download the old FREE version of ECUEdit from HERE.
2. Extract the file.
3. Click "ecuedit.exe".
4. Once it opens, click "File" and then click "convert 160K to 192K...".
5. Now browse and locate your ROM image and then once selected/highlighted click "open".
6. It will now have converted your ROM image size to 192KB and saved the new 192KB ROM image in the same directory as your ROM - with _192 added to the ROM image file name.
7. Now you can follow the rest of the LC patch instructions to patch your ROM and add launch control for FREE
wrxsti.l is offline   Reply With Quote
Old 09-10-2011, 05:47 PM   #781
EROC263
Member#: 96887
Thank you
Jackson
Sounds like the same problem I was having. Try these steps..(if you're using Windows7)
Right click on the file> Properties> Security tab> Click "Edit" Button> Click Users> Check "Full Control" box> Click OK, then OK on the properties window to save and close the changes. Then you should be able to edit the file. Hope this helps with your problem.
EROC263 is offline   Reply With Quote
Old 01-29-2012, 05:22 PM   #782
i2cou4u2
Member#: 246455
2004 WRX Wagon
I am having trouble patching my ROM. I downloaded the patch for my ECU calibration ID and unzipped the file, I imported into the same folder a copy of my ROM and I am stuck there. I cannt seem to get the thing into the command prompt for the "TinyPatcher.exe [your ROM file name] patch.dif" to work. I am missing something here. Also how do I check to see if the image is 192k?
Thanks for the help
i2cou4u2 is offline   Reply With Quote
Old 01-30-2012, 09:59 AM   #783
quazimoto
Member#: 70395
99% of the time it's people simply not following the directions. The 192k is the file size. No offense, but if your having trouble trying to find the size of a file in Windows you might want to rethink using this patch. Depending on what view you have the file will either tell you right away (details/tiles view) or you can just place the pointer over the file (icons/list view).
quazimoto is offline   Reply With Quote
Old 01-30-2012, 04:40 PM   #784
i2cou4u2
Member#: 246455
2004 WRX Wagon
Ya.....I got it figured out. Thanks for the help.
Tom
Old 02-26-2012, 03:33 AM   #785
driftingrotary
Member#: 234715
2003 wrx
charcoal
there's 7 versions:http://www.ecu-mods.com/online/index...iewCat&catId=6
i have an 03 wrx... which one do i choose?? what is the difference between all of them?
driftingrotary is offline   Reply With Quote
Old 02-26-2012, 10:32 AM   #786
eminehart
Member#: 11205
2009 WRX
Dom3-e85-ewg
Find out what ecu's internal ID is you can see this displayed in ecuflash under ROM Info or when you open up your rom in Romraider. Then get the patch that matches your ecu.
The difference is the patches are ecu specific.
eminehart is offline   Reply With Quote
Old 03-23-2012, 01:45 AM   #787
03WRXer
Member#: 142905
Do you know if there is a patch for the v8 jdm sti ecu? I haven't checked my ecu's internal ID yet. Getting a cable soon.....!
I have a 2003 wrx with a version 8 JDM STI swap. 2004 JDM STI is a 16 bit ECU right?
Thanks,
03WRXer is offline   Reply With Quote
Old 03-23-2012, 06:05 PM   #788
elevenpoint7five
Member#: 187798
04 2 liters of
AWESOME!
I'm 99% positive there is one out there. Yes it's 16bit.
elevenpoint7five is offline   Reply With Quote
Old 03-23-2012, 11:32 PM   #789
03WRXer
Member#: 142905
Thanks. After I read my ECU and get the ID I'll look for one.
Old 04-16-2012, 10:32 PM   #790
crash#2
Member#: 112128
2002 wrx
sedona red pearl
on windows 7 the only option to save a rom file is as *.bin , *.hex it always loads as a .bin file. so how do i change it to a hex file to patch?
crash#2 is offline   Reply With Quote
Old 04-16-2012, 10:41 PM   #791
420WRX
Member#: 27752
2004 WRX+Ver.8 EJ207
More than 5 pages to read for free info that could save you some $$ ? Quick post a question at the end!
420WRX is offline   Reply With Quote
Old 05-04-2012, 06:00 AM   #792
99STM
Member#: 219160
2002 Impreza WRX
AW (6MT, E85, EWG, VF39)
Open the ROM in ECUflash, don't do anything with it. Just save it with ".hex" at the end. ECUflash saves ROM's as hex files by default.
99STM is offline   Reply With Quote
Old 05-04-2012, 06:16 AM   #793
99STM
Member#: 219160
2002 Impreza WRX
Originally Posted by Gamble_WRX View Post
"source patch is truncated or wrong patch used... byte 0x2ff30 does not exist!"
This is the same error code I am getting.
I have an A4SGC00C ROM and the A4SGC00C patch. The ROM is a 192kb image, and I renamed it "A4SGC00C.hex". I use the patch.bat file. I tried using the command prompt but I do not know how to navigate to the necessary file, I've never used command prompt before. It is a Windows 7 laptop if that matters.
Any help would be appreciated.
Old 05-04-2012, 08:01 AM   #794
quazimoto
Member#: 70395
Does the ROM open in Ecuflash?
Old 05-04-2012, 08:38 AM   #795
99STM
Member#: 219160
2002 Impreza WRX
Ok, I figured it out..kinda.
The reason it wouldn't patch is because when I changed it from .bin to .hex, I had to open the rom in ecuflash and then save it. Well ecuflash apparently saves it as a 160kb. so i converted it back to 192kb and got it patched.
NOW when i open the patched rom in ecuflash, the ONLY parameters it shows is the tiny wrex parameters.
EDIT: actually, it does this for all ROM's opened in ECUflash.
EDIT 2: got it figured out. I messed around in the options for ECUflash and got it working. I changed the rommetadata location.
Old 05-04-2012, 08:56 AM   #796
99STM
Member#: 219160
2002 Impreza WRX
Now when i go to "read from ecu", i don't get any selections of year/make/model. when you go file>options>rommetadata directory, what file do i need to open?
Old 05-04-2012, 10:09 AM   #797
99STM
Member#: 219160
2002 Impreza WRX
Originally Posted by matt1990 View Post
I changed the size patched the file and set the rev limit delta and mph but when I go to test the lc my car just goes to my normal red line can anyone help
Sorry to whore this thread. I got the previous issues fixed but now I am having ^ this problem. I set the LC RPM delta to 1500 and the speed cutout or whatever to 2mph. Flashed it to the car and nothing.
Not sure if it matters but when I opened the tiny wrex parameters in ECUflash, none of them were at 0.
Old 05-04-2012, 11:08 AM   #798
420WRX
Member#: 27752
The RPM setting is the redline for the launch so 1500 would be really odd. If LC was working, flooring the gas/holding it down with that value would cause the motor to bounce off a 1500RPM limit until you reach the speed cut or take your foot off the gas.
2mph for the speed cut means if the car is rolling forward at a pace of 2mph the LC will not kick in.
I set mine to 10mph so if the car for some reason thought I was still rolling a bit vs. stopped it'd still keep the RPMs nice n safe.
The only issue with a large speed cut, like anything over 20, is that you could be holding back the launch speed if the car needs more RPMs than your launch value (1500RPM).
I'd review the thread to read up on everyone's experiences but as I recall a launch value of 5200-5400 is conservative without being too low to work, and 5600 was the sweet spot for a perfect launch? I don't have time to go re-read..
I actually can't do jack to my current ECU (crazy rare JDM ECU for this MY of the EJ207) and had to leave all the controls with the local ECUTEK dealer who spent like 8hrs re-tuning the car on a dyno and at the end forgot to re-apply the base patches when he was done so no LC or any special features.. Fuuuu. ;p
Old 05-29-2012, 09:49 PM   #799
98imprezaWagon
Member#: 142548
05 WRX
Website has been down for a few days now. . Anybody have an idea of when it will be back up?
98imprezaWagon is offline   Reply With Quote
Old 05-29-2012, 09:50 PM   #800
WRXWTF
Member#: 257230
02 Silvia S15
GGP
does it have spark cut
WRXWTF is offline   Reply With Quote
Launch Control on 2004 WRX Doomsti AccessPort 18 11-16-2012 03:16 PM
Launch Control on 32bit ECU Nuke209 Open Source Reflashes 126 05-17-2008 10:49 AM
Help with wiring in launch control on an 05 WRX. Sir Wagon UTEC 2 03-07-2008 04:45 PM
Failed NY state Inspection because of Launch Control on UTEC? vipernj Engine Management & Tuning 2 01-24-2006 06:10 PM
utec remote switch launch control on 4eat topgrinder Engine Management & Tuning 1 03-27-2003 08:34 PM
