Old 02-05-2008, 02:02 PM   #126
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Originally Posted by 06rexwagon View Post
I think everyone who uses this should consider giving the guy a donation. We've all been waiting for some time for someone to develop it.
+1!
If you want to see more ECU mods from him, thank him with some $ for what he's done so far.
Old 02-05-2008, 02:27 PM   #127
Barge
Member#: 62941
2004 WRX
Rally Blue
Did you get sent the A4TF520F rom yet? 04WRX. I think that's the latest.
I didn't see a patcher for that yet and that's what i'm currently using.
Barge is offline   Reply With Quote
Old 02-05-2008, 03:01 PM   #128
ExpO
Member#: 115819
2006 vf39 R0mRa1DeR
Darknessess Wagon
Originally Posted by xswrex View Post
yeah sure
Thats what I like to hear.
If you're accepting donations, let us know.
ExpO is offline   Reply With Quote
Old 02-05-2008, 03:10 PM   #129
xswrex
Member#: 87255
2002 Impreza WRX
given up emptying PMs...
it is in progress, maybe even tomorrow it will posted up
xswrex is offline   Reply With Quote
Old 02-05-2008, 03:12 PM   #130
xswrex
Member#: 87255
2002 Impreza WRX
of course i do!
you can find a donation link on my site on the main page and also in every patch post!
Old 02-05-2008, 03:26 PM   #131
Nuke209
Member#: 108089
2003 WRX
NF Performance
drop the 16bit and go for the 32bit, everyone is waiting for that
Nuke209 is offline   Reply With Quote
Old 02-05-2008, 03:33 PM   #132
fasterthanurwrx
Member#: 82734
No Lift Shift!
fasterthanurwrx is offline   Reply With Quote
Old 02-05-2008, 03:53 PM   #133
ExpO
Member#: 115819
2006 vf39 R0mRa1DeR
Darknessess Wagon
Patience, I'm sure there are plenty of people running 16bit that are just as eager as you.
Originally Posted by fasterthanurwrx View Post
No Lift Shift!
Already been done, soft throttle cut can be set in the throttle maps.
Old 02-05-2008, 04:00 PM   #134
fasterthanurwrx
Member#: 82734
I'm surprised I never saw any posts on this.
Old 02-05-2008, 04:56 PM   #135
ExpO
Member#: 115819
2006 vf39 R0mRa1DeR
Darknessess Wagon
So was I, check out some of gabedude's posts around here, thats where I found it.
Old 02-05-2008, 05:12 PM   #136
fasterthanurwrx
Member#: 82734
Oh, on nasioc. Will do.
Thanks
Old 02-05-2008, 06:29 PM   #137
Not-EWRX
Member#: 158043
2013 Wrx Hatch
Originally Posted by turboge View Post
I will be updating them when he has returned them. The new maps will be available once patched and completed. I've tested it on an 04 WRX and it works great.
Keep us posted Braden
Not-EWRX is offline   Reply With Quote
Old 02-05-2008, 07:36 PM   #138
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
You cannot assume it would work based on that argument. The only way i can tell you for sure is when i disassemble the ROM, i have already AUDM STi in the works but send in your ROM as it might be a different revision
np xswrex - thanks for the reply. I will email you the ROM tonight (to your gmail account)
Another thing, I noticed you enforce a fuel-cut rev limit for the launch control. Is it possible to change this to an ignition cut rev limit instead?
Lastly, it was mentioned that the original Enginuity launch control was capable of being set in the cabin/car - is this or something similar possible with your patched launch control?
An idea that comes to mind would be as so:
1. Enable the launch control in the ROM
2. If the demister switch is engaged the launch control rev-limit can then be set in real time via the shift-light adjuster
What do you think? Would that be possible?
Thanks again.
wrxsti.l is offline   Reply With Quote
Old 02-05-2008, 08:06 PM   #139
bigdweeb
Member#: 31035
13 Ford Explorer
14 ISM STi
Yes, both software uses definitions, for example, when you load up A4SGE10C, it'll look for the rom id in the definition and load up what it matches to.
Thing is, the rom id in both the patched and unpatched files are the same.
Unless there's another way around it, the only way I can think of, is changing the rom id and loading up the LC featured on the new rom id but inheriting from the original.
I don't think it would be that hard to add. I would think: add a new variable in the XML for each CalID it's been added to. The new XML variable would contain the offset of where the custom code has been added in the rom and how many bytes long the code is. You'd also need something to check against, so maybe a calculated checksum you could match against for those bytes. When a supported rom is opened in the editor, it would read the bytes described in the XML and calculate the checksum. If the calculated value matches what's in the XML, the LC parameters are displayed/not greyed out. That's just off the top of my head, uneducated guess though. I could have overlooked some functionality as I'm not familiar with the codebase.
bigdweeb is offline   Reply With Quote
Old 02-05-2008, 08:23 PM   #140
AruisDante
Member#: 122365
2015 WRX STI Limited
Ice Silver
The LC is really just a hack that introduces a secondary rev-limiter that's speed dependant. It uses the factory rev limiter algorythm, which is fuel cut.
Correct me if I'm wrong.
AruisDante is offline   Reply With Quote
Old 02-06-2008, 02:35 AM   #141
xswrex
Member#: 87255
2002 Impreza WRX
yes i can, but you sure you want that?
Cons
-(maybe a pro cause it is cool) You know that you would have unburnt excess fuel going down your exhaust stream and potentially shoot some fireballs and flames Antilag style?
That would kill your cat in notime (if you have one that is )
-stress on the valvetrain
Pros
You might build a bit more boost with ignition cut
Thanks again.
1. Already done
2. This requires completely different code, so new patch
Not in my plans currently
ROM patches have nothing to do with enginuity or any other editor whatsoever!
Old 02-06-2008, 02:42 AM   #142
xswrex
Member#: 87255
2002 Impreza WRX
this is it
http://forums.nasioc.com/forums/show...3&postcount=28
Old 02-06-2008, 04:56 AM   #143
.one lane
Member#: 114528
2002 Space Shuttle
Discovery
I vote for antilag. I'll be your guinea pig.
.one lane is offline   Reply With Quote
Old 02-06-2008, 05:26 AM   #144
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
Cons
Pros
It's the unburnt fuel igniting in the headers that I am seekng
Not for the flames (although that'd be pretty cool) but rather for the benefit of helping the turbo to build boost while I'm stationary and ready to launch - exactly what I need for drags and racing with a small capacity engine and largish turbo
1. Already done
np. I guess a set, flash and forget option is just as good.
So what would it take to get an ignition cut based launch control patch happening
Because just like .one lane posted above:
Old 02-06-2008, 06:44 AM   #145
xswrex
Member#: 87255
2002 Impreza WRX
A4TF520F patch is released, USDM WRX MY04
http://tinywrex.wordpress.com
Old 02-06-2008, 06:54 AM   #146
xswrex
Member#: 87255
2002 Impreza WRX
..dbl post
Old 02-06-2008, 06:55 AM   #147
xswrex
Member#: 87255
2002 Impreza WRX
if i go into the hassle of doing ignition cut, i might as well do FFS, but without a clutch switch/signal that i can read through the ecu it aint happening. As i said i havent seen a clutch switch so far in the 16bit ecus or maybe i am not looking at the correct places...who knows...
I think the 32bit ecu implement a clutch switch it but i am not there yet
plus i am doing this on my free time, plus i get nothing for this so far...you get the picture
anti lag eh?
Old 02-06-2008, 08:07 AM   #148
gaveup
Member#: 116036
2015 WRX STi
anti lag eh?
PSH screw that. 32bit lc 1st
Once you get it, I'll gladly send you at least $50.
gaveup is offline   Reply With Quote
Old 02-06-2008, 08:38 AM   #149
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
in regards to 16 bit clutch switch, the JDM STI ECU has neutral switch signal that grounds/ungrounds, if it helps
they also inverted the switch starting on 2005+ models
Hyper is offline   Reply With Quote
Old 02-06-2008, 09:55 AM   #150
Tea cups
Member#: 103136
anti lag eh?
The 16-bit ECU does not monitor the clutch switch (a separate module does and deals with cruise control but does not communicate with the ECU). The 32-bit ECU does, though, so FFS is possible, so you can use the clutch signal to enable/disable LC with a veh. speed threshold to switch between normal LC and FFS. However, we've found in testing LC/FFS for Enginuity that the ECU likes to pull timing due to perceived knock when FFS is enabled.
Tea cups is offline   Reply With Quote
Launch Control on 2004 WRX Doomsti AccessPort 18 11-16-2012 03:16 PM
Launch Control on 32bit ECU Nuke209 Open Source Reflashes 126 05-17-2008 10:49 AM
Help with wiring in launch control on an 05 WRX. Sir Wagon UTEC 2 03-07-2008 04:45 PM
Failed NY state Inspection because of Launch Control on UTEC? vipernj Engine Management & Tuning 2 01-24-2006 06:10 PM
utec remote switch launch control on 4eat topgrinder Engine Management & Tuning 1 03-27-2003 08:34 PM
