Old 02-06-2008, 10:11 AM   #151
Benchmark Tuning
Member#: 154444
2008 08 STi, Typhoon
06 STi, 847-960-8676
Originally Posted by Tea cups View Post
The 16-bit ECU does not monitor the clutch switch (a separate module does and deals with cruise control but does not communicate with the ECU). The 32-bit ECU does, though, so FFS is possible, so you can use the clutch signal to enable/disable LC with a veh. speed threshold to switch between normal LC and FFS. However, we've found in testing LC/FFS for Enginuity that the ECU likes to pull timing due to perceived knock when FFS is enabled.
you beat me to it, I was just about to mention that the 32 bit ECU does have a clutch pedal switch that goes to the ECU.
Benchmark Tuning is offline   Reply With Quote
Old 02-06-2008, 10:15 AM   #152
djpast
Member#: 31016
2016 Focus RS (blue)
2005 WRX Wagon (white)
When will an enginuity (aka RomRaider) XML fix be released so us linux users can have a go at this?
djpast is offline   Reply With Quote
Old 02-06-2008, 10:53 AM   #153
AruisDante
Member#: 122365
2015 WRX STI Limited
Ice Silver
A pro you missed for ignition cut based LC is for nitrous users. They'll blow their engine right quick with a fuel based cut.
I agree though, 32bit LC should be done first before anything else.
AruisDante is offline   Reply With Quote
Old 02-06-2008, 11:10 AM   #154
Benchmark Tuning
Member#: 154444
if you run a clutch pedal enabled relay then your safe, that way when the clutch is pushed in the nitrous is disabled
Old 02-06-2008, 11:24 AM   #155
Barge
Member#: 62941
2004 WRX
Rally Blue
Originally Posted by xswrex View Post
A4TF520F patch is released, USDM WRX MY04
http://tinywrex.wordpress.com
Much thanks. I might have a chance to try it out tonight.
I'll let you know how it goes.
Barge is offline   Reply With Quote
Old 02-06-2008, 11:50 AM   #156
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
Donation sent, and you don't even have it for my car yet. Keep up the good work.
06rexwagon is offline   Reply With Quote
Old 02-06-2008, 12:13 PM   #157
t4nk
Member#: 129905
2005 WRB WRX
2003 F-350SD, 7.3PSD
I've got a 05 USDM, I downloaded the patch.. but my rom files are only 160k.. whats the deal?
t4nk is offline   Reply With Quote
Old 02-06-2008, 12:35 PM   #158
Benchmark Tuning
Member#: 154444
you will need to use EcuEdit to convert the file size from 160 to 192
Old 02-06-2008, 12:46 PM   #159
simon021
Member#: 157532
2002 MY03 EJ207 E85
Dom 1.5XTR Twinscroll!
how do you do that exactly? just open the rom in ECU edit and resave it or something?
simon021 is offline   Reply With Quote
Old 02-06-2008, 12:49 PM   #160
t4nk
Member#: 129905
2005 WRB WRX
that was going to be my next question lol
Old 02-06-2008, 01:27 PM   #161
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
File>File convert functions>convert 160 to 192
you don't need to do that anyway, ecu takes both these formats
Hyper is offline   Reply With Quote
Old 02-06-2008, 01:35 PM   #162
Benchmark Tuning
Member#: 154444
yep its that easy you don't even have to open the ROM file you just fo the the convert function and then click on the file you want to convert...the patch only works as they said for the larger file size 192k so even though the ECU will take both the patch will only work on the 192k file as stated in the how-to
Old 02-06-2008, 01:58 PM   #163
turboge
Member#: 35076
2004 507whp Wagon
I've updated my definitions for it on the XPT site, however it is only for the XPT maps and not for the default roms. The problem with updating them for all maps is that it is not enabled in a stock rom, therefore if you do not have it patched, the table will show up with corrupt data and could cause issues if it's not patched to begin with.
Tiny - Thanks for the 04 WRX patch! Can't wait for th 03 and upcoming 32-bit patches!
turboge is offline   Reply With Quote
Old 02-06-2008, 03:01 PM   #164
ExpO
Member#: 115819
2006 vf39 R0mRa1DeR
Darknessess Wagon
Xswrex, will these patches be compatible with the groundwork laid for enginuity/romraider RAMTune? I've read through all the threads on it, and it seems like LC is to be integrated.
As in, are you running the same offsets for the values and code as the 16bit test releases?
ExpO is offline   Reply With Quote
Old 02-06-2008, 03:05 PM   #165
Nuke209
Member#: 108089
2003 WRX
NF Performance
did your speed threshold show up at 158mph and rpm delta as 12800rpm?
Nuke209 is offline   Reply With Quote
Old 02-06-2008, 03:15 PM   #166
xswrex
Member#: 87255
2002 Impreza WRX
given up emptying PMs...
my patches are compatible to stock roms (stock refers to factory program code, not the tune)
I have not seen any ramtune enabled rom, although i have asked for it from the enginuity team in the past in order to test and further develop.
Ie, are you running the same offsets for the values and code as the 16bit test releases?
sorry i dont get what you mean by this...which test releases?
xswrex is offline   Reply With Quote
Old 02-06-2008, 03:18 PM   #167
xswrex
Member#: 87255
2002 Impreza WRX
thank you
Old 02-06-2008, 03:40 PM   #168
.one lane
Member#: 114528
2002 Space Shuttle
Discovery
I know this is sorta off topic, but have you guys heard of gizzmo electronics? (http://www.gizzmoelectronics.com/Pro...Interface.html) They have launch control via ignition cut, and has the ability to do flat foot shifting.
Now according to gizzmo it's compatible with all subarus. So 16bit, and 32bit ecu are able to run this. My question is, since a 16bit ecu doesn't have that ability to monitor the clutch switch, is there a way to rig something up that would allow the ability to monitor it?
If this was covered already please excuse my no0b-ness
.one lane is offline   Reply With Quote
Old 02-06-2008, 04:26 PM   #169
turboge
Member#: 35076
2004 507whp Wagon
Donation sent as well!
Nuke - All of my roms show up at 0/0 for the defaults.
Old 02-06-2008, 04:44 PM   #170
Nuke209
Member#: 108089
2003 WRX
NF Performance
I meant, the unpatched ones.
Old 02-06-2008, 05:08 PM   #171
hurricane123
Member#: 121116
2004 WRX
v7 w/VF30
Tested and working on A4TF520F ('04 USDM WRX). Thanks xswrex!
Donation made!
Jeff
hurricane123 is offline   Reply With Quote
Old 02-06-2008, 05:33 PM   #172
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
I just had a thought (I know they are sometimes a little silly and outside the box )
I was looking through Enginuity and noticed a heap of other switches that are monitored - what if I was to use one of these monitored switches in place of the clutch switch?
ie. rewire the clutch switch to use one of the "not important" monitored switches.
wrxsti.l is offline   Reply With Quote
Old 02-06-2008, 05:45 PM   #173
ViscontiFlash
Member#: 154084
looks good !
ViscontiFlash is offline   Reply With Quote
Old 02-06-2008, 06:10 PM   #174
AruisDante
Member#: 122365
Ice Silver
In the wise words of turboXS with the UTEC instal and using the clutch switch for FFS...
Do not, under any circumstances, tap the UTEC clutch switch wires into the clutch
switch with the stock clutch wires still connected. Trust us, this will result in all sorts
of electrical gremlins that may well ensure your car never runs correctly again. If
you fail to heed this warning, you may as well douse your car in race gas and light it
off, because itís as good as dead. You think we are kidding? TurboXS has no sense of
humour. You have been warned.
In otherwords, **** with the clutch switch, kiss your car goodby.
Old 02-06-2008, 06:12 PM   #175
turboge
Member#: 35076
2004 507whp Wagon
Yes sorry, the unpatched rom will so 12800 / 158mph. DO NOT TOUCH these values with an UNPATCHED rom.
Launch Control on 2004 WRX Doomsti AccessPort 18 11-16-2012 03:16 PM
Launch Control on 32bit ECU Nuke209 Open Source Reflashes 126 05-17-2008 10:49 AM
Help with wiring in launch control on an 05 WRX. Sir Wagon UTEC 2 03-07-2008 04:45 PM
Failed NY state Inspection because of Launch Control on UTEC? vipernj Engine Management & Tuning 2 01-24-2006 06:10 PM
utec remote switch launch control on 4eat topgrinder Engine Management & Tuning 1 03-27-2003 08:34 PM
