Old 02-05-2002, 08:23 AM   #1
ripGTS
Member#: 5567
2002 Subaru Wrx
Talking got my Titan motorsports downpipe have a question thou
I came home to find a huge box and inside a huge downpipe
looks good the construction seems to be good te only concern i have is that there is a flat surface right in front of the wastegate would this slow the flow?
ill post pics soon,
ripGTS is offline   Reply With Quote
Old 02-05-2002, 09:28 AM   #2
ripGTS
Member#: 5567
2002 Subaru Wrx
im thinking of returning this thing cause the more Stare at it the more i dont like that flat plate where the wastegate opens
Old 02-05-2002, 10:10 AM   #3
wRx14pSi
Member#: 6203
please get some pics.. would it bolt to a aftermarket catback?? i am interseted.
wRx14pSi is offline   Reply With Quote
Old 02-05-2002, 10:22 AM   #4
ripGTS
Member#: 5567
2002 Subaru Wrx
as far as i know it will bolt up to any exhaust that folows the wrx design
Old 02-05-2002, 01:24 PM   #5
lenyx
Member#: 8221
2011 Legacy 2.5i Ltd
Basically what you've got there is a downpipe that follows the stock design except it's what.. 3 inch? and catless.
The stock pipe has that flat spot too.. though can't remember if it's right at the flange or recessed like yours.
Nothing against titan motorsports.. they're absolutely great as far as customer service goes.. but I dunno if I'd want that design on my car. A wide mouthed downpipe (ala scoobysport) or twin pipe (ala vishnu et others) would seem to be a better choice.
lenyx is offline   Reply With Quote
Old 02-05-2002, 09:22 PM   #6
ripGTS
Member#: 5567
2002 Subaru Wrx
how much more power would the other design give?
Old 02-05-2002, 09:52 PM   #7
DannyGT
Member#: 6281
2002 Impreza WRX
Graphite Pearl - SOLD :(
Believe me thats a good DP, the stock is more of a WALL....at least that recess's back a bit, so it will still flow, plus it looks like its 3" and catless, you'll have plenty of flow.
DannyGT is offline   Reply With Quote
Old 02-05-2002, 09:55 PM   #8
lenyx
Member#: 8221
Well I think most would argue that with that setup your going to create turbulence and slow down exhaust flow.
Old 02-05-2002, 10:04 PM   #9
ripGTS
Member#: 5567
2002 Subaru Wrx
thats what i thought the bell design prolly flows better
Old 02-05-2002, 10:18 PM   #10
phxscooby101
Member#: 4355
I don't think the turbulence would cause all that much of a
problem running the stock turbo. even my turboxs downpipe
would have some also just cause theres know divider, but
that doesn't mean you would lose hp, with that size 3in
downpipe turbulence would be minimal, just my 2cts
also as long as the cat stays out of the downpipe flow will
be pretty close for any of the designs. later
phxscooby101 is offline   Reply With Quote
Old 02-05-2002, 10:33 PM   #11
snookem
Member#: 11438
ripGTS
check your email
snookem is offline   Reply With Quote
Old 02-06-2002, 08:25 AM   #13
BugEyed
Member#: 11756
2001 WRX Sedan
Wink
Hmm, this has been discussed before over the Stromung downpipe on this thread.
The basic conclusion is that it will work OK as the gasses coming from the wastegate are forced out at an angle as the wastegate penny doesn't open more than 45 degrees. However, the wide mouth or twin dump designs should be better.
Duncan
BugEyed is offline   Reply With Quote
Old 02-07-2002, 11:13 PM   #14
Bottle
Member#: 739
02 WRX
Midnight Black Pearl
If anyone is unhappy with the design of our downpipe send it back for a full refund.
I run this downpipe on my car and so do a lot of other people I have not heard one complaint until I read this post.
But again I stand behind what we make if you do not like it send it back.
Bottle
Bottle is offline   Reply With Quote
got my 20G today just have a question about it qazxswqazwsx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 27 01-25-2007 07:54 PM
Got my 07 STi and have a question wattpuppy Newbies & FAQs 19 10-10-2006 06:32 PM
Just got my exhaust manifold tapped... have a question? NewShockerGuy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 07-17-2006 11:20 PM
Pics of my Titan Motorsports Downpipe what do you think? ripGTS Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 02-07-2002 11:08 PM
titan motorsports downpipe Mr.Freeze Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-26-2001 07:53 PM
