Old 01-31-2008, 12:23 PM   #1
blue subaru
Member#: 104265
2005 STI
BLUE
Default need help fast is dealer screwing me??
i brought my car into service to change the throw out bearing. i just got a call from the service manager and said that my clutch and flywheel is worn pretty bad and said that since it looks like abuse they will not change the flywheel and clutch under warranty. no labor cost cause the tranny is out already. they said around $750 for the clutch and flywheel. i told him i will call by 2 pm est. and tell him what i want to do, either get new parts or put the old ones back in. the car i a 06 wrx with 9 thousand miles. is he right? what should i do?
blue subaru is offline   Reply With Quote
Old 01-31-2008, 12:25 PM   #2
Suby666
Member#: 112870
06 STI
CGM
hows the car drive?
Suby666 is offline   Reply With Quote
Old 01-31-2008, 12:26 PM   #3
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
it is VERY obvious when a clutch as been "abused" vs normal wear
I can toast a clutch in a day if I try.....
You can find a clutch kit for less than $750 and supply them with your own clutch to save a bit on the cost....
Old 01-31-2008, 12:27 PM   #4
numbnuts670
Member#: 165030
Ask if you can see the clutch and the flywheel. if the flywheel has dark or black spots on it and the material on the clutch is almost worn or low, then they will not cover it because they can not bill subaru for it. either they are trying to milk you or you need to learn to drive the car better GL
numbnuts670 is offline   Reply With Quote
Old 01-31-2008, 12:42 PM   #5
blue subaru
Member#: 104265
2005 STI
BLUE
car drives good sometimes it is hard to engage into 2nd and 3rd
Old 01-31-2008, 12:44 PM   #6
Okeyd57
Member#: 113271
2006 STi
Obsidian Black Pearl
A fried clutch on an 06 WRX with 9000 miles ? I don't see how that could be anything but abuse ! And the tranny too ?
Sounds like you need to trade it in on an automatic !
Okeyd57 is offline   Reply With Quote
Old 01-31-2008, 01:00 PM   #7
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
nvm345
Old 01-31-2008, 02:18 PM   #8
flstffxe
Member#: 155358
2008 Forester
Steel Silver
here exedy is the OEM clutch. Here is their trouble shooting guide.
http://www.exedyusa.com/multimedia/s...rblshtng06.pdf
There are several things that can trash a clutch in a very short time. Other then assembly error, there is driver error. Go in and look at it and decide for your self, see what you think after looking at the guide.
here is a clutch kit
http://www.clutchcityonline.com/products/FJK1001.shtml
just have the flywheel resurfaced, ~$100-$200 on the high side, depending on the shop.
flstffxe is offline   Reply With Quote
Old 01-31-2008, 05:10 PM   #9
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Listen smart guy, you're making a lot of assumptions. Maybe he just started learning stick, I could see that happening with a powerful car.
And the tranny was out so they could service the throwout bearing, he didn't kill the tranny itself. Read more thoroughly next time.
They're overcharging you for the clutch, I'd get it from www.subarugenuineparts.com
Wiscon_Mark is offline   Reply With Quote
Old 01-31-2008, 06:05 PM   #10
PropBoyBlu
Member#: 148020
BugI WRX Wagon
Battle-Tested Blu
Same thing happened when my 03's trans let go. Everything was fine before then boom, no more second gear. After (reluctantly) saying it would be replaced under warranty, they said my clutch was broken and I had to pay for it. I said it wasn't broken before the transmission went, so it shouldn't be broken now, unless the transmission did it or you did it. Turns out the tech broke something when removing it. They replaced it free of charge and supplied the rental car. Carr Subaru FT(eventual)W
PropBoyBlu is offline   Reply With Quote
is the dealer screwing me? (saying I need new pads/rotors/bleeding of fluid) jaybert Brakes, Steering & Suspension 7 05-29-2008 03:48 PM
need help fast! help me get out of work snyper784 Off-Topic 10 10-17-2003 02:45 PM
Dealer screwed me! GooseMan Warranty Issues & SOA Problems 9 09-14-2002 07:22 PM
I am about to buy a spoiler, need help fast. Tell me which one you like better! STR8OUT Interior & Exterior Modification 43 06-22-2002 03:33 AM
Dealer screwed me over. What should I do? impretzel General Forum Archive 5 12-14-2000 11:59 AM
