Welcome to the North American Subaru Impreza Owners Club Monday March 30, 2015
Old 01-31-2008, 02:20 PM   #1
wittmer25
Member#: 102970
2004 STi gt30r
Default getting misfire cel's on all 4 cyl
I need some help or ideas.
I just installed a built ej257 w/ 100mm pistons with a compression ratio close to 9.0:1 & cosworth cams & mildly ported heads. My car seems to be running well except that I get a lot of misfire cel's especially at low rpms. I haven't run the car hard at all because I am still breaking it in (<4500 rpms and boost below 5 psi). Mostly mild city driving. I have low ltft & stft correction percentages to by the way. My car seems idle well at 1000 rpms when its warm. I changed the idle maps so that it idles at higher rpms at each coolant temp range.
I haven't changed my timing maps yet and I am thinking this may be the problem. I was hoping that the increased compression ratio would offset loss of volumetric efficency due to the high lift cams at low rpm so that my timing maps might still be close enough in that rpm range. I am guessing the knock sensor is what detects the misfires like it does detonation. How does it know which one is occuring? Or are they considered the same? Should the base timing be reduced say across the board when compression ratio increases? I realize since I have the cams that the volumetric efficiency should slightly drop at low to mid rpm and rise from mid to high rpm. Based off volumetric effeciency, timing should be changed accordingly, right?
wittmer25 is offline   Reply With Quote
Old 01-31-2008, 04:15 PM   #2
Jon [in CT]
Member#: 2992
02 WRX Sedan
The ECU watches crank rotation speed very closely and if it decides the speed is too slow after a cylinder fires, it concludes that incomplete combustion has occurred and declares a misfire. The knock sensor is uninvolved with misfire detection.
Maybe you should try adjusting your AVCS intake timing.
Jon [in CT] is offline   Reply With Quote
Old 01-31-2008, 04:24 PM   #3
wittmer25
Member#: 102970
2004 STi gt30r
I also forgot to mention that I have a act streetlite flywheel and ATI dampener.... I guess these could also have some effect then on misfires. Can you give me an example of which direction to adjust the AVCS? More advance at low rpm, low load or less advance at low rpm, low load? Maybe a trend would be helpful. Before I installed my engine, I had my AVCS tuned to give me max advance at low rpm high load...tapering to zero AVCS advance at around 5500 rpm. I left the AVCS map stock below approximately 1.0 g/rev. This seemed to help spool my gt30r nicely. Like I said earlier, the engine "feels" smooth. It doesn't seem to hunt at all. But I logged cylinder roughness for each cylinder... it counted many misfires in each cylidner in a matter of minutes.
misfire in all 4 cyl eddiewouldgo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 04-19-2010 12:49 PM
Missfire on all 4 cyl. 04 sti trbowrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 01-29-2008 02:19 PM
All 4 cyl misfire, oil on all plugs InfamousDX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 12-09-2005 01:12 PM
Misfire In all 4 cyl...yet another thread... 4830DeuceWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 38 03-16-2005 02:16 PM
misfiring on all 4 cylinders tEkkGOD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 09-08-2003 09:26 PM
