Old 01-31-2008, 07:48 PM   #1
buccilli15
Member#: 109369
08 2.5i
Default Mystery hose disconnected, rough idle, P0457??
See my notes in the photo. That hose is dangling with a broken off plastic nipple.
Symptoms are low idle & P0457
What parts do I need to fix??
Thanks!
buccilli15 is offline   Reply With Quote
Old 01-31-2008, 08:07 PM   #2
jaxscuby
n00b Moderator
Member#: 10613
2002 USDM WRX
there is a solenoid below the intake.
the end with bolt would have connected
to one of the ends.
do you still have this stock solenoid?
thinks it is a purge valve..
Old 01-31-2008, 08:10 PM   #3
buccilli15
Member#: 109369
08 2.5i
to one of the ends.
I'm sure it's the stock solenoid. (I just bought the car yesterday)
SOunds like I will need a entire new solenoid then. Anybody have the specific name or a p/n?
Thanks again
Old 01-31-2008, 10:56 PM   #4
buccilli15
Member#: 109369
08 2.5i
Anybody else??
Old 02-01-2008, 10:23 AM   #5
quazimoto
Member#: 70395
Its the evap solenoid.I might have the whole system if your interested.It's the solenoid,vac T's,lines and one way valve.Just send me a PM for a price.The stealership is gonna charge you over $100 just for the solenoid.Part #16102AA300
Pics just to kind show all the parts you need.
quazimoto is offline   Reply With Quote
Rough idle, intermitent and rough cold starts... carter_wrx Pre-2002 Factory Turbo Powertrain 26 10-28-2009 01:03 PM
How Rough is a Rough Idle Go350zGo Factory 2.5L Turbo Powertrain 11 10-22-2009 11:28 PM
ROUGH IDLE SOLUTION by disconnecting a ground? subarwho? Factory 2.0L Turbo Powertrain 7 07-14-2006 03:48 PM
New Intercooler hoses, rough Idle... vale2489 Factory 2.0L Turbo Powertrain 14 03-23-2006 09:24 PM
thin vacuum hose causing rough idle? HubbieScooby Normally Aspirated with bolt-on Forced Induction Powertrain 9 01-23-2005 02:03 PM
Message Board Statistics All times are GMT -4. The time now is 01:21 AM.
