Old 01-31-2008, 08:27 PM   #1
Jonx1218
Member#: 158267
2002 wrx
black
Default fp red 7cm vs 8cm hotside
i tried searchign but never got an actual answer. i also called fp and didnt get much usefull info from them either. if anyone can tell me wat the difference would be up top / down low on these hot sides it would be greatly appriciated thanks guys
Jonx1218 is offline   Reply With Quote
Old 01-31-2008, 08:58 PM   #2
DZnutz
Member#: 91837
well if the maker is of no help then id probably stay away from their products
DZnutz is offline   Reply With Quote
Old 01-31-2008, 09:36 PM   #3
nhat
Member#: 140163
03 STi
hellaflunctional
if you've got a 2.5 go with the 8cm
http://forums.nasioc.com/forums/show....php?t=1399554
Originally Posted by Unabomber
No one on the planet earth knows the answer to your question. Ask here, ask in every forum, bump said questions all day/every day and no one will know. You need to understand that the ONLY thing that turbo manufacturers give is ultimate flow based on compressor wheel size. Will your 500 CFM turbo flow 500 CFM in your car? The answer is no. So in reality, a 500 CFM turbo is just a rough indication of power ability.
7cm^2 -----------------------------8cm^2
fast spool/low power----------slow spool/high power
This is your Chart of Salvation and contains the closest thing in the history of the world to what your answer is. The bigger question you need to concern yourself with is what exhaust turbine housing size you are talking about, vs. the 7 vs 8 cm^2 issue. Housing size plays a bigger role than 7/8cm^2. So buy a turbo based on housing, then fine tune that housing decision based on the variants of housings which are the figures above used in this example. Not all housings are 7 or 8 though as MHI turbos go up to 12cm^2.
And since you are local, you now owe me a beer.
fp green 7cm or 8cm? rebel1988us Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 02-28-2009 01:07 AM
FP Red 7cm or 8cm hotside??? BillMac Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 07-25-2007 04:00 PM
Almost new FP RED EWG with 8cm hotside. Peeblesmx445 Engine/Power/Exhaust 26 03-30-2007 03:03 PM
7cm Vs 8cm Help!! subbiedo04 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-28-2007 07:10 AM
fp red 7cm vs. 8cm railguy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 12-09-2006 04:48 AM
