#1 |
Member#: 83801
Put a new cat-back on my car this past weekend with the spring kit, etc. I was not able to get the metallic cone gasket off the cat side and it is leaking. How do you get the gaket off? Heat? BFH?
Thought about a grinder but that was the reason I needed the cat-back. ![]() Edit - Sorry, it's a 2001 Legacy Wagon if that info is needed. Any ideas would be appreciated. Thanks Ken
#2 |
Member#: 71092
Vehicle:2005 2.5RS Wagon Regal Blue Pearl |
I stabbed at it for a while with a flathead screwdriver until it started to come apart. Then I used Vice-Grips to yank on the metal mesh inside until I finally gave up and came off.
#3 |
Member#: 155883
Vehicle:2005 Impreza 2.5RS bacon rage |
i took a chisel to mine with a hammer....pried it off of the cat after a few good whacks to get it seperated from the cat.
#4 |
Member#: 83801
Thanks folks. Was afraid that was what I needed to do, was just hoping that there was an easier way.
Time to break out the dead blow hammer and cold chisels! Thanks again. |
#5 |
Member#: 47646
Vehicle:0211 RallyWagon DGM Sedan |
The exhaust is either mild or stainless steel. The gasket is rusty layered lead/metal. Don't worry about it.
#6 |
Member#: 7101
Vehicle:00RS I want to fill your mouth with spiders |
#7 |
Member#: 165749
South East
Vehicle:2007 No YELLING on the bus! |
Heat is your friend.. the hotter you can get the pipe that is holding onto it, the easier it will come out. dont use too much heat though, a good propane torch on full should be fool proof and do the trick.. O2/acetylene could make a hole real quick if you are not careful.
| Thread Tools | |
| Display Modes | |
| FS: OBX Equal length header with magnaflow cat welded to mid-pipe. | NFJ79 | 1993 - 2001 Impreza Specific Parts | 8 | 12-04-2007 12:43 AM |
| TXS Hi-Flow cat and mid-pipe from their stealth-back | Leonardo | Private 'Wanted' Classifieds | 3 | 01-04-2005 01:28 PM |
| cat-less mid pipe?? | Rock_Strongo | Factory 2.0L Turbo Powertrain | 4 | 06-11-2004 06:27 AM |
| RS Exhaust parts: Borla Header, Stromung high flow cat, Stromung Mid-Pipe | AndyM | Private 'For Sale' Classifieds | 12 | 04-19-2004 11:26 PM |
| IL: I need stock downpipe to mid-pipe donut gasket. | Shaitiger | Private 'Wanted' Classifieds | 0 | 03-11-2004 06:26 PM |
