Old 02-01-2008, 03:31 PM   #1
Toolz
Member#: 145568
2002 WRX Wagon
WRB :)
Default AFR logging with stock sensor?
Can some tell me the reason why the stock o2 sensor is not reliable? So logging ,A/F Sensor #1 (AFR) and A/F Learning #1 (%) are not useful in determining how lean/rich you are running?
Thx
Toolz is offline   Reply With Quote
Old 02-01-2008, 03:56 PM   #2
gabedude
Member#: 10108
07 STI
60Trim spun rod bearing
It is located pre-turbo is why. It is only accurate near stoich. The JDM twinscrolls are post turbo, but I have only tuned one of those and I used my own WB just because (time constraint).
Gabe
gabedude is offline   Reply With Quote
Old 02-01-2008, 04:34 PM   #3
mickeyd2005
Member#: 122595
2005 LGT Wagon
ABP
The 16 bit ecu O2 sensors are also different than the later ones used on 32 bit ecu. The newer type are referred to by Denso as Planar Wideband and theoretically would work post turbo like in JDM twinscroll applications but there are other factors that may affect its accuracy.
Since you have a 16 bit ecu, I don't think your O2 sensor would work that well post turbo regardless. This is based on the lambda vs mA chart that's included in Denso's paper.
mickeyd2005 is offline   Reply With Quote
Old 03-30-2008, 08:43 AM   #4
Toolz
Member#: 145568
2002 WRX Wagon
WRB :)
So are these values worth anything on stock sensor in determining rich/lean condition?
I am seeing 11.25 at WOT,with learning at -7.81 and then between 12.x - 14.x, at part throttle. But when throttle is let off showing zero in log it shows 23.x-24.x!?
Thx
Old 03-30-2008, 11:14 AM   #5
mickeyd2005
Member#: 122595
2005 LGT Wagon
ABP
The AFR Learning can be a problem. You should check that with a WBO2.
Old 03-30-2008, 12:55 PM   #6
Toolz
Member#: 145568
2002 WRX Wagon
WRB :)
Hey thanks for the reply, but can you explain please?
Thx
Old 03-30-2008, 01:14 PM   #7
mickeyd2005
Member#: 122595
2005 LGT Wagon
ABP
I don't know if your car has been tuned or not.
Most of the time, the WOT is tuned when AFR Learning D is 0% because the ecu was reflashed. Over time, the ecu will adjust AFR based upon what it learns from the 50-70 g/s range.
So, now you are running -7.81% less fuel than when you were tuned.
Old 03-30-2008, 01:42 PM   #8
Toolz
Member#: 145568
2002 WRX Wagon
WRB :)
I was running osecu Stg 1 map, now I am just running the boost values from stg 1 on the stock map. And recently started logging the AFR values, and was not sure how to interpet them.. or if they were even reliable.?
-7.81 means ecu is reducing fuel beause it is richer than the target?
Thanks again.
Old 03-31-2008, 12:16 PM   #9
98EJ20
Member#: 163184
98 Swapped Impreza
Red
The reason the stock sensor is not good to log is because it is a narrowband sensor. It is only accurate around the stoich areas. Like 15.5-13.5. Anything else and I wouldnt trust it.
98EJ20 is offline   Reply With Quote
Old 03-31-2008, 02:03 PM   #10
mickeyd2005
Member#: 122595
2005 LGT Wagon
ABP
That's not quite true.
Even if you put a WBO2 in the front O2 position, it would still be inaccurate due to the high exhaust pressure.
Jon[in CT] posted the technical paper for the 32 bit front O2 sensors. Theoretically, it can read down to AFR 11.
Old 03-31-2008, 03:21 PM   #11
Jon [in CT]
Member#: 2992
02 WRX Sedan
Here's the paper:
Development of Planar Air Fuel Ratio Sensor
The sensors were designed to distinguish air/fuel ratios down to 10:1.
Jon [in CT] is offline   Reply With Quote
Old 03-31-2008, 03:25 PM   #12
98EJ20
Member#: 163184
98 Swapped Impreza
Red
I did not know that. It definately doesnt read accurately though.
Old 04-03-2008, 09:54 PM   #13
rjacobs
Member#: 80127
wolfplayer has some tables to re-calibrate the front 02 to make it read very close to a wideband down to 11.8:1. This is for the 32 bit ECU's though so YMMV with the 16bit.
rjacobs is offline   Reply With Quote
had a question about afr, log attached kh15 Commercial ECU Reflashes 4 06-04-2009 07:07 AM
How to measure AFR accurately with stock exhaust system? (during tuning/WOT) TJRCS Engine Management & Tuning 8 12-31-2008 06:35 PM
Logs with and without rear 02 sensor inside hondaeater69 Engine Management & Tuning 2 02-15-2007 11:41 PM
afr logs carl s. Engine Management & Tuning 8 01-02-2007 10:49 AM
Logging with EcuExplorer and AFR? bmw50021 AccessPort 3 10-17-2006 07:52 PM
