Welcome to the North American Subaru Impreza Owners Club Wednesday June 1, 2016
Old 02-01-2008, 07:12 PM   #1
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
Default Anyone tow a car trailer with their Legacy ?
I'm thinking about picking up a trailer for my 98 Legacy L wagon... I would like to be able to tow my Impreza to and from shows and whatnot....
Its not that heavy, what do you guys think ???
IllNastyImpreza is offline   Reply With Quote
Old 02-01-2008, 07:21 PM   #2
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
It will pull it, but IMO its not gonna do it safely. If you try it upgrade at least your brake pads and reduce the tongue weight as much as possible.
ss
subysouth is offline   Reply With Quote
Old 02-01-2008, 07:57 PM   #3
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
tongue wieght ??
should I get a trailer with brakes??
My legacy already has upgraded brakes (WRX fronts) ... think thats enough?
Old 02-01-2008, 09:22 PM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Originally Posted by IllNastyImpreza View Post
tongue wieght ??
If you're not familiar with one of the most basic terms/concepts associated with setting up a tow vehicle and trailer, I highly suggest you stop now and do some research before you get yourself into trouble.
Patrick Olsen is online now   Reply With Quote
Old 02-01-2008, 10:16 PM   #5
MCarp22
Member#: 102684
2013 Impreza
Deep Cherry
I wouldn't try to tow 4000lbs of impreza and trailer with a Legacy. That's just not within what the car should do.
MCarp22 is offline   Reply With Quote
Old 02-01-2008, 10:17 PM   #6
aross
Member#: 831
11 Blurple WRX
03 BH MBP
With a 2.2? Nuts.
aross is offline   Reply With Quote
Old 02-01-2008, 10:25 PM   #7
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
seems we've got a whole lot of no no and no's...
Old 02-02-2008, 12:30 AM   #8
kidjoe
Member#: 120797
2004 Baja Turbo
I'd say no, my Baja hitch is only rated for 2400lbs. I wanted to do the same thing.
kidjoe is offline   Reply With Quote
Old 02-02-2008, 12:42 AM   #9
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Most unibody cars are rated for 2500-3000lbs of towing anyway...I don't think you'll be able to tow a car+trailer with it.
Better to just get a cheap tow vehicle if you're set on towing the Imp...
rougeben83 is offline   Reply With Quote
Old 02-02-2008, 01:12 AM   #10
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Yeah, get a used truck. The market on those is flooded, so I bet you could get a decent one cheaply.
Wiscon_Mark is offline   Reply With Quote
Old 02-02-2008, 07:27 AM   #11
legacy1907
Member#: 94024
05 WRX CGM
95 YJ Flat black
yea definately not going to happen.....dependinng on what trailer you are talking about....some full car trailers way up to 2-3000 lbs alone....add nearly 3000 more and you are looking at 5-6000 lbs......a full size truck is needed for that.....now if you plan on using a dolly and disconnecting the driveshaft everytime you want to tow then that may be a different story, but i still dont see that being very good for the tranny at all nor would it be easy for that motor to pull that kind of load
legacy1907 is offline   Reply With Quote
Old 02-02-2008, 12:50 PM   #12
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
bummer... With diesel prices these days its not even worth getting one. And gass mileage on big ol V8's is quite the suck
I guess I will end up just driving her to shows
what are you guys using to tow with ?
Old 02-02-2008, 12:56 PM   #13
legacy1907
Member#: 94024
05 WRX CGM
95 YJ Flat black
dodge ram lol....not quite a subie wagon tows greaat though
Old 02-02-2008, 10:14 PM   #14
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Quick Silver Metallic
Subaru rated my 99 Legacy GT (with the 2.5 litre motor) max. reccomended towing capacity at 2,500 Lbs. Your Subaru Legacy L Wagon (with the 2.2 litre motor) is likely rated for far less. A first generation Impreza has to weigh something in the neighborhood of ~ 2,800 Lbs. Add in the weight of the trailer and you are over 3,000 Lbs.
Yes you COULD tow your Impreza with your Legacy for short distances. However nobody on this board would really reccomend it.
Jack (the Factory Five Cobra guy) and "KC" (on the "New England forums") both do a fair amount of trailer towing. Pretty much any long-bed pickup with a rated towing capacity of ~5,000 lbs, electric towing brakes, and a class III frame mounted Hitch would be well suited for the job.
Subarus are meant to be driven. Dont make yours a "trailer queen".
Jonathan is offline   Reply With Quote
Old 02-02-2008, 10:30 PM   #15
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
verry true.... but Its not really street legal
Old 02-02-2008, 11:48 PM   #16
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Well, if it's that important, buy a cheap old beater truck for the job.
Old 02-05-2008, 03:55 PM   #17
jey
Member#: 32503
2011 Tribeca
1995 Legacy Wagon
Gas mileage on anything (including a 2.2L Legacy ) is going to suck while towing. Maybe you can get a V6 truck?
jey is offline   Reply With Quote
Old 02-05-2008, 05:54 PM   #18
SubaruFan
Member#: 35649
2001 Legacy GT sdn
sand/gray
Lots of experience towing with my 2001 legacy 2.5 GT 5spd. Wife and I race sailboats we have a 1400lb 20ft racing boat with trailer and gear tips it around 2100lbs towing with a very low profile - top of the boat is about two feet taller than the Subaru roof line- boat it's self is fairly areodynamic. Going ultra light no extra bodies or gear keeping to around 2000lbs max the legacy tows well - drives well - stops OK but in 80+ degree heat the radiator is not big enough engine warms up on slight climbs. A friend as an Impreza with the 2.2 which tows the same boat - he's done the Grapevine at 35mpg again going as light as possible one person in the car minimal gear etc 1800-2000lbs max. No way would either engine haul more than 2500lbs in a safe manner.
SubaruFan is offline   Reply With Quote
Old 02-05-2008, 05:56 PM   #19
SubaruFan
Member#: 35649
2001 Legacy GT sdn
sand/gray
Gas milege with my small 600lb 16foot sailboat was around 25mpg with the 5spd 2.5 legacy gt. The Gas milege with the 20ft 2000lb boat is around 19mpg.
Old 02-05-2008, 06:07 PM   #20
greenspeed
Member#: 151248
00 Impreza 2.5RS
Whore Door
i say get a blazer...i towed a grand am once with that and it felt like i was towing a house...tow an impreza with a legacy imo would be risking sex with a 800lb women who only is willing to take the top...
greenspeed is offline   Reply With Quote
Old 02-06-2008, 12:15 AM   #21
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
best analogy yet
I think you officialy swayed me...
Old 02-11-2008, 03:37 AM   #22
JoKerNZ
Member#: 140342
1998 Legacy GTB JDM
traveled over 300 km (100miles) only one scary moment at bottom of a hill on a corner - tried to jack-knife a little (speed wobble BAD)
JoKerNZ is offline   Reply With Quote
Old 02-11-2008, 12:47 PM   #23
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
yeah thats not fun
Old 02-11-2008, 12:59 PM   #24
legacy1907
Member#: 94024
05 WRX CGM
95 YJ Flat black
how heavy is that trailer?
Old 02-11-2008, 01:26 PM   #25
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
'96 BrightonCoupeWRX-SR30
with reference to the price of diesel comment, My friend has a 93 chevy duramax which is beat to **** and still gets 18mpg consistently compaired to his 07 2500HD gasoline which on a good day might pull 10mpg.
Kawikid20o2 is offline   Reply With Quote
Towing a small trailer with a 2.0L WRX HankWest Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 27 07-30-2009 12:35 AM
Does anyone have a car trailer with a winch I can borrow? Crashsector Mid Atlantic Impreza Club -- MAIC 4 08-14-2007 09:22 AM
Towing - Does anyone tow trailers with their WRX 143paul Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 12-22-2003 08:04 PM
Anyone towing a small boat with their Impreza? wgb113 General Community 3 07-28-2003 11:44 PM
Anyone tow with their Legacy? rB5 Legacy Forum 4 07-08-2001 11:42 AM
