Old 02-01-2008, 09:45 PM   #1
Subyroo2.5
Member#: 168129
2013 WRX
WRBP
Default sucking noise
Hey anyone ever heard of a little tiny sucking noise coming from the passenger foot well area? It happens when I just barely hit the gas. It kind of sounds like a little mouse squeaking....................anyone heard this?
Subyroo2.5 is offline   Reply With Quote
Old 02-01-2008, 10:07 PM   #2
marchul
Member#: 168890
1998 5 spd Forester
black
Maybe theres mice living in your car? Or maybe its a little vacuum leak (not sure if there are any vacuum lines around there). Or its just your intake and it just sounds like it is coming from there and you shouldnt worry about it.
marchul is offline   Reply With Quote
Old 02-02-2008, 12:25 PM   #3
onebaddx
Member#: 161224
1998 Subaru Forester
YES!!! I have this too, it's more under the hood but on the pass. side of the vehicle. I have a 98 Forester and when I'm out of throttle it goes away but as soon as I touch the gas you just hear this light sucking noise like a vacuum leak but I cant seem to find anything!! I was also told that the tranny in the foresters (5mt) whines a bit typically and it could be that as well......still fishing though!! lol.
onebaddx is offline   Reply With Quote
Old 02-02-2008, 03:00 PM   #4
RaceFaceXC
Member#: 165749
2007 No YELLING
on the bus!
do either of you guys has SRI setups? those make a sucking noise when you blip the throttle from idle...
RaceFaceXC is offline   Reply With Quote
Old 02-02-2008, 03:30 PM   #5
onebaddx
Member#: 161224
My Forester at this time is 100% factory stock aside from the exedy clutch.
Old 02-02-2008, 07:08 PM   #6
imprexaRS03
Member#: 145883
2008 wrx
psm
yeah i have the same problem...but i have a sri..and it sounds gansta B)
imprexaRS03 is offline   Reply With Quote
Old 02-02-2008, 07:25 PM   #7
marchul
Member#: 168890
1998 5 spd Forester
black
Definately not the tranny. Probably from the drainage hole in the snorkus, or there is a bad seal somewhere in the intake.
Old 02-02-2008, 11:29 PM   #8
RaceFaceXC
Member#: 165749
2007 No YELLING
on the bus!
if its an intake leak you should be able to locate it by spraying alcohol lightly on the outside of your intake with a spray bottle anywhere there is a seam or joint... if there is suction at any point the alcohol will evaporate quickly in the immediate area around the leak. Dont go spraying it in the filter or directly into the intake. I know you can chk for vac leaks on some cars by holding the throttle open slightly and keeping the rpm steady @ 2k or so for a few seconds (until vacuum stabilizes) and then releasing the accelerator quickly... if there is a moderate or worse vac leak the engine will usually fall past idle speed and stumble momentarily. Or you can stab the accelerator @ idle and if the engine stumbles before it accelerates then you may also have a intake leak after the MAF sensor or be running too lean for some other reason. These tests may not work on DBW throttle system since the ecu is controlling throttle valve position.
Old 02-03-2008, 01:02 AM   #9
Subyroo2.5
Member#: 168129
2013 WRX
WRBP
its a different noise than that.
Old 02-03-2008, 05:34 PM   #10
SeaofGits
Member#: 168224
1999 2.5 RS
Silverthorn
I never really understood why that thing was there in the first place. It is it really just to cut out some noise?
SeaofGits is offline   Reply With Quote
Old 02-03-2008, 11:52 PM   #11
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
Yup, it's a silencer for the intake.
Counterfit is offline   Reply With Quote
Old 02-03-2008, 11:57 PM   #12
SeaofGits
Member#: 168224
1999 2.5 RS
Silverthorn
Huh... seems kinda pointless to me
Old 02-04-2008, 08:11 PM   #13
RaceFaceXC
Member#: 165749
2007 No YELLING
on the bus!
A vast majority of Impreza Owners dont buy thier cars for performance and anticipate modding and upgrading... They just want a reliable, driveable, very safe, and comfortable car. Part of that is quiet. The snorkus is a muffler for the intake and it does its job very well. I cant blame Subaru for using it and many other manufacturers use similar designs for the same reason. Subaru isn't trying to rip you off by stealing back HP or anything. Just an FYI for why its there. When I pulled mine i was suprised by how freaking huge it is. After seeing that i was impressed with how good the throttle response was with it in, especially being TBW.
Old 02-04-2008, 09:23 PM   #14
GC Guy
Member#: 154090
i pulled off the silencer from my 00 gc.
was wondering if i opened the scoop up during rain will water flood my engine? since the intake then is right under the scoop without the snorkus...?
GC Guy is offline   Reply With Quote
Old 02-04-2008, 11:30 PM   #15
RaceFaceXC
Member#: 165749
2007 No YELLING
on the bus!
GC guy - i think you will be alright.. chk out this thread for piece if mind.
http://forums.nasioc.com/forums/show....php?t=1439933
not exactly the same as you but i think there are a couple different hoodscoop setups with n/a motor
Old 02-05-2008, 01:29 AM   #16
GC Guy
Member#: 154090
RaceFaceXC- yea i read that thread, however it doesnt mention anything about a snorkus delete.
With the snorkus id feel confident in opening the scoop up but without, the intake is right below the scoop so im worried... (i ahve the regular 2000 RS hood/scoop)
whaddya guys think? (sorry to kind of jack the thread)
Old 02-05-2008, 01:47 PM   #17
EvoSpeed
Member#: 155430
2008 Nissan
SE-R Spec V
My SRI intake makes this noise. It kinda reminds of a turbo "whine" so I dont mind it much.
My guesses are that it may be:
From a vaccum line that has to make a weird bend to reach my SRI. Its not pinched but at the bent angle it is SLIGHLY restricted possibly making this noise. Will reroute and check back.
My fog light holes taking in air and whistling on something in its air flow.
OR... since i got my WRX hood my car tries to whine like a turbo to be cool....
EvoSpeed is offline   Reply With Quote
Old 02-05-2008, 09:26 PM   #18
RaceFaceXC
Member#: 165749
2007 No YELLING
on the bus!
its probably the latter... if i was your car i would make that noise. and the BOV noise too, really obnoxiously.
Old 02-06-2008, 11:36 AM   #19
EvoSpeed
Member#: 155430
2008 Nissan
SE-R Spec V
It does fool everyone and that was never really my intention. this morning the owner of cv auto repair came up to me out front of his shop and starts telling how my car (I assume he thought it was a WRX) is really fast. Telling me my CF hood loks great, what have i done to it..., am i gonna get a chip, am i gonna get it tuned on a dyno... etc.
But I guess its not his fault unless you know to look for a top mount or for 17" rims you would never know without looking under the hood.
The "turbo like" noises I get since i've installed my intake and hood, I assume are just whistling air but they sound like faint turbo sounds. "Ghosts in the system".
Old 02-06-2008, 03:31 PM   #20
Counterfit
Member#: 124254
"The Scoobinator"
Might as well get around to it:
"something something your mom joke something"
Weird Moaning noise coming from my front right axle area...? Flyin_Hayn Transmission (AT/MT) & Driveline 2 06-05-2010 02:50 PM
strange slurping, sucking, noise from fuel pump kh15 Newbies & FAQs 0 04-10-2010 11:00 PM
sucking noise??? wicked_wrx Factory 2.0L Turbo Powertrain 3 05-12-2007 04:07 PM
Sucking noise wicked_wrx Normally Aspirated Powertrain 0 05-12-2007 03:19 AM
sucking/squeaking noise after oil change scottlee Service & Maintenance 7 10-28-2001 09:47 AM
Message Board Statistics All times are GMT -4. The time now is 11:52 AM.
