Welcome to the North American Subaru Impreza Owners Club Tuesday March 31, 2015
Old 02-05-2002, 03:06 PM   #1
adamsrs
Member#: 3768
Default HELP! I cant read my gauges! Please!
Ok... so I got some Blitz BL series gauges. They look really great...one problem though.. they are in metric. Does someone have a conversion chart from Metric BAR to psi, and the same for my Fuel pressure. Thanks...Also when I turn my car off the fuel pressure gauge stays at 2 bar and doesnt fall for like 4 hours... is this how it should be? Thanks!
adamsrs
adamsrs is offline   Reply With Quote
Old 02-05-2002, 03:27 PM   #2
Jewbaru
Member#: 1994
2013 Impreza WRX
Default Re: HELP! I cant read my gauges! Please!
adamsrs
http://www.worldwidemetric.com/metcal.htm
2 bar is about 30psi, sounds right. It won't drop right away because the FPR is closed blocking fuel. The fuel eventually works it's way back to the gas tank, but very slowly.
Jewbaru is offline   Reply With Quote
Old 02-05-2002, 04:13 PM   #3
david2z4
Member#: 1838
2000 Impreza RS BRP
Vishnu Turbo/Tec3
give me your email address I will send you a great conversion program for converting anything to anything.
david2z4 is offline   Reply With Quote
Old 02-05-2002, 07:50 PM   #4
Buttsy
Member#: 2043
2002 Impreza WRX
WR Blue Pearl
It's not too bad if you remember the approximate values for atmospheric in a few units:
1 Atm=
100 Kpa
0.1 Mpa
30 in Hg
15 psia
760 torr (equal to 760 mm Hg)
My Autometer guage is psi on the positive side, but in Hg on the negative side, but then I just divide that by two and you get psi anyway. Not so bad.
Buttsy is offline   Reply With Quote
Help!!!!!!! I Cant Find My Override/programming Button For My 01 Rs BAMBOO Electrical & Lighting 2 09-12-2007 08:30 PM
HELP!!! i cant find my programming button on my 01' RS BAMBOO Car Audio, Video & Security 5 09-12-2007 05:43 PM
ALL OF MY STi FRIENDS PLEASE HELP....YOU GOTTA READ THIS !!!! PSI_2_HIGH General Community 27 02-23-2007 04:56 PM
Help me narrow down my problem please - Air leak or Turbo problem? Justin962 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 01-08-2006 02:45 PM
Help me set up my amp...please! :) TEKNOSYS Car Audio, Video & Security 1 02-28-2005 11:47 AM
