Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 02-02-2008, 12:05 PM   #1
Pearly_Whites
Member#: 164714
2007 WRX TR
Satin White Pearl
Default Pioneer Avic-d3 nav issues
Im having issues with the navigation function. After I program a route and begin driving, the map only shows me where I've been, not the route that I'm driving on. This came out of my friends car and I've been told that I have to reset the system and calibrate my location.
I was trying to get onto Avic411.com but the site is websensed at work and I used all my quota time trying to search on there.
Does anyone know how to reset the system and calibrate?
Pearly_Whites is offline   Reply With Quote
Old 02-02-2008, 12:19 PM   #2
thedaddyb
Member#: 64374
07 WRX SWP *SOLD
03 2.5ts BRP long gone
hmm. that's strange. The unit will hard reset after being disconnected from constant power. (which would have happened during the removal/install process) There is also a reset button on the front of the face.
There may be something wrong with the unit. It should automatically update your location once it gets a valid gps signal.
thedaddyb is offline   Reply With Quote
Old 02-02-2008, 12:36 PM   #3
Pearly_Whites
Member#: 164714
2007 WRX TR
Satin White Pearl
i talked to my friend who works in CarFi for best buy and he said that my unit still thinks it's in my friends car. I mentioned that we already made the switch and he said there is still internal memory that doesn't get lost when disconnected from power
Old 02-02-2008, 12:47 PM   #4
v8eaterWRX
Member#: 108547
2013 RAM 2500 4x4
6.7l Cummins
^^^nope
The navi will reset when it gets signal again. I.E. you turn your headunit off and drive 10 miles away, under your friends theory the units internal memory would say that it is still in the same area so it would not update when a GPS signal is located. Although partially true (the part where it would still show the last powered on area) he is incorrect as the unit should update as soon as a signal is located.
I would start with making sure you connected your GPS antenna correctly.
v8eaterWRX is offline   Reply With Quote
Old 02-02-2008, 02:03 PM   #5
Pearly_Whites
Member#: 164714
2007 WRX TR
Satin White Pearl
you mean by plugging it into the back of the receiver? i'm pretty proficient in wiring. i don't think i explained his theory correctly, but from what i gleaned from his info, i just need to do a hard reset and recalibrate.
the whole nav system is acting funny though, no voice prompts unless i poke the flag thing on the screen and the map only shows me where i have been on my route, not where i am going. also, the way that the arrow is orriented makes it look like my car is driving backwards
Old 02-03-2008, 12:54 PM   #6
Pearly_Whites
Member#: 164714
2007 WRX TR
Satin White Pearl
fixed it. I had to do a hard reset with the button next to eject (pen tip reset button). then i went into map with the nav disc in, hit menu, and adjusted my current position to face the right way.
it is strange though because somethimes the arrow doesn't follow the road that i'm on and it goes off on its own way then jumps back to the road i'm on... wierd
Old 02-03-2008, 03:12 PM   #7
v8eaterWRX
Member#: 108547
2013 RAM 2500 4x4
6.7l Cummins
Mine will occasionally show me driving parallel to the road I am actually on then after a few meters jumps onto the road (shows me driving through field/houses/etc.).
I assume mine is because my VSS wire is not connected, however I am not sure as I have not driven anyones car that has one with the VSS wire connected.
Old 02-04-2008, 05:52 AM   #8
oburgslim
Member#: 126049
2002 wrb wrx-sold
06 SGM STi
I have the same issue,atleast im not alone in this. I have the Alpine blackbird 2 w/ W205 headunit and it does the samething once in awhile.I thought it was because of the cloudly weather we've been having lately but i don't know i will see once its clears up a bit. Besides thats the unit works wonderful
oburgslim is offline   Reply With Quote
Old 02-05-2008, 05:07 PM   #9
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
My D3 does that as well sometimes, but rights itself very quickly. I also did not hook up the VSS wire.
Tony
Old 02-05-2008, 06:05 PM   #10
teiva-boy
Member#: 22825
Hook up the VSS wire people. It's there for a reason... To improve accuracy.
teiva-boy is offline   Reply With Quote
Old 02-05-2008, 06:37 PM   #11
99 rs
Member#: 100994
2005 Acura NSX-T
2007 Outback 2.5i
I have the VSS hooked up and it still jumps off the road. Now having said that I fully understand that the VSS has NOTHING to do with the car jumping off the road. It's only for more accuracy while moving and not positioning. It's just the mapping software is off a little bit. I don't think it's the unit's fault, just the software's fault.
Old 02-05-2008, 07:12 PM   #12
teiva-boy
Member#: 22825
Or the company that Pioneer uses for the mapping... I know of a main road near me where the car is off by about 100 yds going across a mountain side according to the map..
Sadly, the map updates from Pioneer are far too sparse.. It seems to be the original release, an update 18-24 months later, then quiet until a replacement model comes out, and you are obsolete with a unit that will not get map updates anymore.
Linkage about VSS:
http://www.avic411.com/forum/viewtopic.php?t=11510
http://www.avic411.com/forum/viewtopic.php?t=7599
http://avic411.com/forum/viewtopic.php?t=6011 <-pay attention to the reference to "3D Hybrid."
FS : Pioneer AVIC D3 nav w/ Bluetooth and iPod cable DrnknZag NWIC Private Classifieds 48 08-22-2010 07:51 PM
Pioneer AVIC D3 - Nav/Bluetooth/iPod arco SCIC Private Classifieds 17 07-28-2010 12:43 PM
FS: Pioneer AVIC-D3 GPS Nav/DVD Player johnkimball SCIC Private Classifieds 4 04-01-2009 12:27 PM
FS: Pioneer AVIC-D3 6.1" screen, Nav, DVD & CD player Plus Extras! drcivic SCIC Private Classifieds 8 06-23-2008 05:44 PM
Pioneer AVIC D3 nav/DVD player PDXTuning Interior/Dressup/Audio & Security 8 06-13-2008 05:26 PM
