Old 02-02-2008, 03:41 PM   #1
nization
Member#: 159023
1997 Impreza Outback
Green
Default fuel economy
I'm having a real hard time finding exhaust systems for my car. I recently got rear-ended and the exhaust just broke off at the factory header/collector. I figured I'll take this opportunity to replace that with a better system, disregarding the cats if possible.
I have a 1997 Impreza Outback Sport with n/a 2.2L engine. I am pretty sure it's not the most common car to buy real performing parts for, but I think I want a quality equal length header and preferably remove the cats if I can confirm that will actually increase my fuel economy. Problem is, I haven't even found any sources for these pieces. Lots of cat-back systems, but that's not what I'm concerned with right now.
Any help/suggestions?
Thanks
Miles
nization is offline   Reply With Quote
Old 02-02-2008, 04:02 PM   #2
MotoFoxKDX1
Member#: 122817
2005 WRX
WR Blue
Well I'm not sure about the fuel economy with running no cats but recently I've done some work to my car which is a 2001 Outback Sport. Your not really going to find any parts that will be listed for just the OBS so look for parts for the 2.5RS in your year's range, later year's might fit as well but I don't know that for sure.
I recently just put on a cat-back exhaust the was for a 98-01 2.5RS and it fit fine. Only thing you will have to check for is the header's and see if they are dual port or single, I'm going to assume your's are single as that's what mine are and if that's the case you might have some difficulty tracking down a set of header's cause I know I am.
MotoFoxKDX1 is offline   Reply With Quote
Old 02-02-2008, 06:16 PM   #3
piker28
Member#: 22664
all depends on a couple things really. First what is your travel mostly? If it was all highway and no traffic id prob help a tad but the second you do stop and go it will sink. Also if you have the dreaded CEL on from catless than your car will be running richer than normal and well no bueno
piker28 is offline   Reply With Quote
Old 02-02-2008, 08:12 PM   #4
nization
Member#: 159023
Green
From what I've read, it sounds like I have the dual port as mine is a '97. I'm not specifically looking for OBS parts, but the hard part is 2.2L headers. I've seen most are for the 1.8 or the 2.5 and will fit the '95 model 2.2L...
I travel all day for work. some days it's 50/50 city/highway, and other days it's 20/80 city/highway. So most of the time, I am traveling on the highway, but not always, of course.
That's another thing I implied about on another forum, if there's a way to reprogram the ECU so that the CEL does not come on or anything. Ideally, I want to make the ECU happy with the catless system. Not that I want to destroy the enviornment, but they are 11 years old now and cats are known restrictions (at least, from everything I understand about them) and when they get old and fail they can cause stop up the exhaust even more so.
Old 02-02-2008, 08:17 PM   #5
piker28
Member#: 22664
to me it sounds like headers, stock cats and a catback would be the best route
Old 02-02-2008, 08:49 PM   #6
SilverSubie2.5
Member#: 136144
2010 STi
1) Just go check if they are dual or single port. I don't know for sure as I don't have a '97 Outback, but you can very easily tell by looking yourself.
2) As far as I know, there are no reflashes available that can get rid of the P0420, and since you can't be OpenSource tuned, that option is out as well. The only way you will be able to get rid of the P0420 is with the spark plug anti-foulers to back the O2 sensor out of the exhaust stream.
SilverSubie2.5 is offline   Reply With Quote
Walbro fuel pump decrease fuel economy? Diversion Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 09-03-2004 06:02 AM
XT Fuel Fuel Economy Eclipse2via Forester Forum 10 07-17-2003 05:18 PM
I think my fuel guage is messed up...or fuel economy GooseMan Service & Maintenance 6 05-02-2003 03:52 PM
AFC to improve fuel economy on MY00? Matt Monson Bay Area Impreza Club Forum -- BAIC 1 12-19-2000 10:47 PM
New Impreza's fuel economy Nemesis General Forum Archive 6 11-12-2000 05:22 PM
